330xi vibration- possible center driveshaft bearing, but no other issues
Hey all,
My 2003 BMW 330xi, 95,000miles, 6 speed, has vibration (no clunking) while under full acceleration, starting at 3500 RPM+ in any gear. I can't seem to figure out why, so I'd like to tap into all the knowledge of this forum! Last weekend, I did the following to attempt to fix the issue: 1) Replaced both front drive shafts w/ new aftermarket units purchased from FCP Groton. (originally thought that was the "for sure" issue, did have minor clicking while turning.) 2) Front and rear diff changed with Castrol synthetic 75w-90. 3) Replaced transfer case fluid with Redline D4. A few months ago, I installed new swaybar end links & lower control arm bushings (L & R) and had a recent mount and balance of winter tires. Everything in the suspension/brake department seems great. At this point I'm looking further into the drivetrain. From what I've read on various forums, it seems the center bearing (usually) only fails when something else (i.e. guibo/flex plate) has failed. I've closely inspected my flex plates and they seems to be in great condition, no movement of the bolts or shredding of rubber. My question is: Does anyone know of the rubber supporting the center drive shaft bearing simply going bad by itself? I currently suspect the center differential bearing bushing might be bad- it has a bit of movement when I grab it. However, I'm not sure what "normal" is, Should the driveshaft be rigid at that point? Or am I not thinking of something else that may be causing my issues? I uploaded a quick video at of my center bearing & rubber flexing when I grab and pull on it. I did not totally remove the exhaust or heat shield so I had to fight to get a camera in there. Thanks again for any insight into this issue! |
If the problem is related to rpm and not vehicle speed, I would think the issue lies somewhere other than the driveshafts/differentials. Motor mounts or trans mounts possibly.
I think you're right to be looking at the center differential. A vibration in my 2001 330xi that occurred under very light throttle at 45-60 mph was finally identified as being caused by that diff. It was gradually getting worse; first started being noticeable at 125K, was one reason I got rid of it at 145K, as replacing the thing would have been pricey.
Thanks floydarogers for the suggestion. I believe the vibration is only due to RPM because higher engine speeds creates more power, and whatever is causing this vibration only shows up under higher loads. It takes much more power to get a vehicle moving than to keep it moving. If I'm at a high RPM, but constant speed, there is no vibration.
I only know of the transfer case (which is in the center) and the front and rear differential. Regardless, how was the center differential diagnosed as the issue on your car? What I don't want to do is just randomly start replacing parts. That is a PITA, plus can end up being a lot of $$$ for nothing. When I changed my transfer case fluid it was pretty dark, but no chunks or metallic items came out that I observed. |
I guess I was lucky that it started manifesting itself after all that stuff had been done as part of "normal" 100K-120K maintenance. |
Thanks |
I can tell you that I have a *similar* problem where I get a vibration under load / acceleration, and it's definitely coming from the rear of the car. It also occurs most noticeably around 3,500-4000 RPM in 2nd gear. It's almost non-existent in other gears. I replaced the driveshaft center bearing and support last year and the rubber was indeed totally cooked, while the bearing itself was basically fine. The sound went away COMPLETELY for a while but now it's back, to a lesser degree. I was under there the other day and inspected the center bearing support; it was not torn, though it seemed to have a little more play than I thought it did when it was new. If there was an HD version I would have used it.
I think that torn rubber support was definitely causing the noise / vibration, but I am now thinking that play elsewhere in the system (motor mounts, trans mounts, diff mounts, etc) is wearing out the rubber support at a much faster rate than normal. So basically I ease off the throttle 10 % at that RPM and never hear it. If I have the exhaust off again sometime I might replace the support bearing assembly again and just ease off the throttle a bit at those speeds (I know, no fun). So if I were you, I'd maybe try replacing that and the driveshaft/transmission coupler (aka guibo) and see where you're at.... not to throw parts at it but those aren't too bad in the grand scheme of things. Last edited by 1972ford; 01-23-2013 at 06:44 AM. |
Multiple test drives, with riders and stethoscope. Inspections and stethoscope use on rack.
Same old, same old...
I put everything back together and was really not too surprised to find the exact same vibration under heavy acceleration issues I was trying to resolve. I was skeptical because the new center bearing/carrier had similar flex in the rubber to the unit I just replaced. It is apparent to me now that the bearing carrier rubber movement I thought was excessive was in fact normal. Quote:
Thanks all! |
No, didn't see any shavings. And I had the diffs/tranny fluids changed at regular intervals, too. I had my front diff break a tooth and lock up at around 120K; thinking that that contributed (bent shaft?) to the center diff going...
I know you are trying to avoid unnecessary parts replacement but it seems as though you are going about it in the correct fashion. As stated even shops have trouble diagnosing problems sometimes. I always take heart in the fact that I am able to change almost any part myself so I am saving the labor. Please keep us posted on how you make out with this problem as I am sure all XI owners are interested. Tommy T |
So you did replace the front axles? Since you said "both driveshafts" I'll assume thats what you meant. Did the vibration change in any way after the FCP axles were installed? IF it did its probably still the axles. Many have had issues with the aftermarket axles vibrations being a fair amount of those issues.
If you havent really changed your axles then: Quote:
GCoop | F1 Autohaüs Halogen Non-Projector LED Angel Eyes Review GCoop | Cluster Repair DIY--Clock and Odometer Knobs Last edited by GCoop; 02-09-2013 at 05:39 AM. |
Just a regrease should be all that is needed in that case. Its what I have done twice now. 130k on original axles.
| Tags |
| 330xi, bmw, e46, vibration |
