E90/E91/E92/E93 (2006 - 2013)
The E9X is the latest evolution of the BMW 3 series including a highly tuned twin turbo 335i variant pushing out 300hp and 300 ft. lbs. of torque. BMW continues to show that it sets the bar for true driving performance! -- View the E9X Wiki |
#26
Hesus, you can go blind doing that
#27
Current draw is about 1.4 amps more (using Ohm's law), well within the safe range of the wire's gauge, The headlight housings are metal, except for the access door (which would melt first) The diffuser and lens are both glass. I wasn't able to determine the composition of the ring or light pipe. The access doors don't feel warm even after being on for several hours. As a reference, my wife's hair dryer is 1875 watts so you can see how much difference 20 watts make heat wise. (20 watts = 11.8% of 1875 watts so you don't have to do the math) I'm not going to get into 'perceived' vs. actual light output (which should be expressed in lumens) due to output temperature. X output at 4300K will "look" like more 'light' then the same output at 3400K and colors will be more accurate at 4300K. An easy way to check light output (relatively) is with a SLR camera. Use manual mode and set the white balance for 'daylight' (5100K) and 'ISO' so you get a mid scale reading, say f 5.6 with spot metering on a light source. With the controls unchanged and at the same distance, check another light source. 1 stop increase is twice the reference light. A photograph will show where the light source is color wise in relationship to 'daylight'. It's your car, do what you want with it. I'm just trying to point out, there are options to expensive 'common' parts that need to be ordered. Just because we drive a BMW doesn't mean we should get a nose bleed because we need a 'common' part. And LED's do fail from impact shock. Ever have to replace your tv's remote after you've dropped it because a $.50 650 nm LED failed?
No matter how fast I go, there's always someone slower in front of me. JB4 PNP .... Love at every stomp on the go pedal! |
