E30 (1982 - 1993)
Old 01-22-2013, 03:57 PM
Sir_nick742 Sir_nick742 is offline
New kid on the block
Mein Auto: Turbo e30 325e
Unhappy E30 m20 misfire, checked everything please help
Hey guys I've been having a issue with my 86 e30 325e turbo. The car generated a misfire.so yesterday I pulled the plugs and cyl. 5 plug was completely black and the others were fine. I checked the spark plug wire and cleaned the spark plug up. I checked fuel pressure and its good. I checked injectors and they're all clicking the same one doesn't sound different than the others. I don't know what else to check. The plugs are brand new.it seems like its not getting spark all the time or the injector is stuck open.
Old 01-22-2013, 06:05 PM
downhiller's Avatar
livin large
you didnt check the dizzy or the rotor. that would be my next step
Old 01-23-2013, 12:09 PM
Figured It out guys thanks
Old 01-23-2013, 06:10 PM
downhiller's Avatar
livin large
what was it
Old 01-23-2013, 06:35 PM
Spark plug wire was bad. It had spark but not enough. Since i saw it had spark i ignored it but I Found some brand new Bosch premium spark plug wires in the junkyard for $5 so i threw them on and car runs good now.
Old 01-24-2013, 01:02 AM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
should ohm at around 5kohms. not worth buying brand new imo, they are super expensive. you can replace 100 from a junkyard before breaking even with a new set. so you did the right thing
E30 above Sold
Last updated 2nd January 2014
