Old 01-23-2013, 08:26 PM
geeman geeman is offline
Mein Auto: 06 Audi A6
335is and intake
Hello all,
I've ordered a 335is. Does anyone have any experience or opinions about getting ONLY an intake with a 335is, and not an ECU tune, exhaust, etc? Does it provide any benefit? I've read that maybe not...
Old 01-23-2013, 08:33 PM
bear-avhistory's Avatar
bear-avhistory bear-avhistory is offline
2014 435M-Sport/MPPK
Mein Auto: 2014 435M-Sport/MPPK
The stock IS does not generate enough boost to make an intake system worthwhile. The factory CAI is more then adequate as delivered.
Kevin
CURRENT:
2018 BMW 440M-Sport MPPK/MPE 8ZF
2016.5 Mazda CX-5GT AWD
2016 Genesis Coupe R-Spec 6MT
2013 BMW 135is JB4 convt 6MT
2009 Ford Expedition 4X4 EL - 2009 V-Star
1998 Ford Ranger 4X4 Splash 5MT
FFR Cobra Mk-IV COYOTE 5MT Build Thread
470 WHP of BURBBLES
HOME FROM PAINT
Old 01-23-2013, 08:42 PM
vstM3's Avatar
vstM3 vstM3 is offline
Mein Auto: F80 M3
Enjoy it as is, great car! Why mess with a beauty
Current: 2015 BMW F80 M3
Retired: 2012 BMW 335is
Other: 2014 Mini Cooper
Old 01-23-2013, 08:59 PM
Orient330iNYC's Avatar
Orient330iNYC Orient330iNYC is offline
Flying monkey herder
Mein Auto: Daihatsu Terrios
This.
Stock intake is not limiting on a factory stock engine.
Sent from my GT-N7105 using Bimmer App
Past: 2001 330i ZSP/ZPP/Step
Past: 2004 S60R 6MT Sport
Past: 2013 335i 6MT ZMM/ZDH/ZTP/3AG/494/508
Present: 2016 F34 335i xDrive ZCW/ZDA/ZDH/ZTP/ZMP/2V5/5DL
Old 01-24-2013, 02:26 PM
BuraQ's Avatar
BuraQ BuraQ is offline
Moding is Addictive
Mein Auto: DCT 335is BQ Tuned
Originally Posted by geeman View Post
Hello all,
Stay with stock intake if you are not tuning
Old 01-24-2013, 07:16 PM
2Turbo 2Turbo is offline
Mein Auto: 335is
There won't be any real noticeable difference except being able to hear the turbos a little more.
Old 01-24-2013, 09:52 PM
Mein Auto: ///M
remap that ECU for an additional 80hp, best bang for the buck for a 335i
Old 01-25-2013, 01:52 AM
54 54 is offline
Trey
Mein Auto: 2009 335i coupe
i have a 09 335i and I did afe intake and rennart 2.5" exhaust, it made a bid difference. The afe intake is around 500, it does't make a 500 dollar diff by it's self. On the other hand the more air you give a turbo the happier it is.
Old 01-25-2013, 10:29 AM
vstM3's Avatar
Mein Auto: F80 M3
335IS is different
Old 01-25-2013, 10:46 AM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
An intake will definitely help you with hp/torque gains as well as throttle response. As others have mentioned, you'll also hear the turbo spool a little more as well. I'd recommend that you check out the aFe Stage 2 Intake System for your BMW 335is N54.
The aFe Stage 2 Intake replaces the factory air box which allows for increased air flow. This modification will be an improvement over the stock box and on a stock car. It is also a great compliment to a aftermarket exhaust systems as well as aftermarket tunes. Another feature of the intake is the 16 gauge powder coated steel heat shield. A heat shield makes sure that the intake doesn't use the hot air around your engine and only allows the intake to receive cooler air, which adds more power. Not only does power increase, but many have observed an increase in MPG.
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
Old 01-25-2013, 12:43 PM
SD ///M4's Avatar
SD ///M4 SD ///M4 is offline
(prev. SD335is & SDZ4MR)
Mein Auto: 2016 M4 Coupe | 2006 Z4MR
Originally Posted by vst335is View Post
335IS is different
Please explain what you mean by this statement. As far as engine performance, there is nothing different about the N54 engine between a 335is and a 335i except that BMW has increased the boost slightly to produce an additional 20 HP, plus the additional 7 second torque boost, all done with the ECU. It is the same physical engine, the only difference is in the ECU.
P.S. on our 335is the letters are in lower case.
- Tom
His: 2016 M4 Coupe | Sakhir Orange Metallic | Black Full Merino Leather | CF Trim | M DCT | Adaptive M Suspension | 19" Black Alloy Wheels | ZEC | ZLP | ZDB | MPE | ED 5/13/16
Hers: 2011 335is Couipe | Le Mans Blue Metallic | Black Dakota Leather | Dark Glacier Aluminum | 6MT | ED 5/12/11
Also His: 2006 Z4 Roadster (E85) | Interlagos Blue Metallic | Black Extended Nappa Leather | Carbon Leather Trim | Purchased 7/19/12
Old 01-25-2013, 02:24 PM
^^^^ And stock the 335i has even less need for an aftermarket air cleaner system then the 335is.
BMW underrates the 335is so the actual spread is more then the 20BHP in the brochure. The 335i typically dyno tests about 265whp or 305BHP. They advertise the 335i @ 300BHP. The 335is dynos, in my case @ 319whp or 367BHP. They advertise the 335is @ 320BHP
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
Old 01-25-2013, 04:16 PM
vstM3's Avatar
Mein Auto: F80 M3
agree I should have said 335is. I think what you mentioned in regards to performance makes it different than the 335i doesn't it? The new 335i does not have the N54 engine, it has N55 which is different. Also on the exterior is different, like the exhaust system, mirrors, front grill. All of these makes it different, at least to me
Old 01-25-2013, 05:41 PM
Don't think the N54 - N55 thing is material regarding a CAI because base they both dyno within a few whp of each other. That being said the N54 reacts much better to tuning than the N55.
Kevin
CURRENT:
470 WHP of BURBBLES
HOME FROM PAINT
