Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M Series > F12 / F13 M6 / M6 Gran Coupe (2012 - current)
F12 and F13 BMW M6 and M6 Gran Coupe Forum.
Old 01-16-2013, 12:19 AM
Ace535i's Avatar
Ace535i Ace535i is offline
Mein Auto: Xe
1250mi service
What occurs at the 1250miles service?
Old 01-16-2013, 11:02 AM
jettie1767 jettie1767 is offline
Send a message via AIM to jettie1767 Send a message via Yahoo to jettie1767 Send a message via Skype™ to jettie1767
Mein Auto: 2012 BMW M6
It's 1200 miles, not 1250. I was told not to exceed that 1200-mile limit otherwise it affects some sort of warranty/certification on the car. They replaced the differential fluid on mine plus some other things.
Current stable:
'12 BMW M6 Convertible San Marino Blue
'13 BMW X3 Space Gray
'13 Range Rover Sport Supercharged LE - Fuji White
Old 01-16-2013, 06:16 PM
Ace535i's Avatar
Mein Auto: Xe
Would you buy a used 2013 M6 with 1280 miles that has not had this service?
Old 01-17-2013, 03:02 AM
ard ard is offline
Resident Curmudgeon
Yes. 50 miles is not critical.
Anyone that is told it is an issue, and believes it, is in a conversation between two ______s.
You know how you tell a BMW employee is lying? Ask them to put it in writing- when they wont, it means they are probably lying. Just because "my dealer said" is not an excuse for nonsense.
Old 01-17-2013, 05:05 PM
If you're running it to the ground, why not? I switch cars every year or two so I follow what the manual says to avoid any issues when I go trade it in.
Current stable:
Old 01-23-2013, 04:49 AM
DreamerM6 DreamerM6 is offline
Mein Auto: BMW M6 F13
At the 1250 mile service they do software set which allows full potential of the engine and launch control is activated and car revs from 6800 to 7250rpm. things like that, also oils etc..
Old 01-23-2013, 06:56 AM
Ace535i's Avatar
Mein Auto: Xe
Does BMW consider a couple hundred miles over the 1200 miles service an issue?
What is launch control in these cars? Is there a button for this?
Old 01-23-2013, 10:07 PM
How to launch: Program your m button2 or 1 for everything to max setting.
1) Press the M button (the one programmed for max settings)
2) Hold brake lightly with left foot.
3) Press gear lever forward until racing flag appears.
4) Use cruise control speed dial to increase or decrease RPM.
5) When ready release lever.
