Go Back   Bimmerfest - BMW Forums > Everything Else > General Automotive Forum
All non-BMW car talk goes here...
Old 01-20-2013, 06:28 PM
mr_clueless's Avatar
mr_clueless mr_clueless is offline
Mein Auto: 2015 328i M-Sport
0 - 60 performance...does it get worse with age?
Does the best 0 - 60 time that a car can achieve get worse with car age due to wear and tear? Just like body integrity, shocks, and the like get affected with age, do engine horsepower and torque get reduced?
Every car I've owned for a long period of time felt slower by the time I had owned it several years. Is this just a perception thing (because I'm now used to a more powerful motor and it takes more to make me feel I'm going fast), or is there truly performance degradation?
If it gets worse, how much worse can it get?
2015 328i / M Sport / Alpine White / Coral Red / 4 DR / 6 MT / Rear Camera + PDC / Xenons / DHP / 56K+ Miles / Bought 10-30-2014
Old 01-21-2013, 02:19 AM
Andrew*Debbie's Avatar
Andrew*Debbie Andrew*Debbie is offline
resU deretsigeR
Mein Auto: Leaf Tekna
Generally yes.
How much and how soon varies widely. Maintenance or lack of, may contribute. Other things, like a worn suspension, can also increase 0-60 times.
Many of the latest BMW engines are flat rated. That means the ECU software limits maximum HP and torque across a wide RPM band. In that case, it is possible that the engine software will make up for engine wear. At least initially. At some point the motor will loose enough compression that there isn't anything engine management software can do.
Electric cars are different. The motors don't wear in the same way. Brushes might wear, but those are easily replaced. Range will degrade as the batteries age though.
The models and equipment (standard and optional) illustrated in this post reflect my misunderstanding of vehicles supplied by BMW AG to the German market. In other EU member states, the truthyness of my posts may vary. Please ignore this post. Subject to change.
Old 01-24-2013, 08:56 AM
Michael Schott Michael Schott is offline
Moderator
Mein Auto: 2017 VW GTI Sport MT
HP will diminish over time as parts wear. I remember a Top Gear episode where they bought used luxury cars like A BMW 850, etc. These cars were about 20 years old if I remember correctly. They took them to a dyno and found they had lost significant amounts of HP. Something like 25%. Proper maintenance could minimize this issue.
Also, car magazines often do long term tests. Typically 40,000 miles. When retested most of the cars are slightly slower than when first tested.
Old 01-24-2013, 09:28 AM
That makes a lot of sense. I have found that as my cars age, I find myself having to rev them harder to get power. It helps to know that there is real loss of power and that it's not just me getting used to it and wanting more.
Old 01-24-2013, 09:55 AM
usaret usaret is offline
Mein Auto: A Gamma Goat
It's not just you. The loss of power comes from ring and cylinder wear that causes the ring gap to open up and lower compression. Frequent oil changes and not lugging the engine are the best bet for long life.
Old 01-24-2013, 10:05 AM
I think I've been slack with respect to oil changes following BMW's recommended schedule. Right now the car needs 1-2 additional quarts every 15K miles.
