Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 01-23-2013, 11:55 AM
dbs600 dbs600 is online now
Mein Auto: 2011 750LXi Individual
Cold Weather Startup Q's
I’ve come across conflicting info on best practices when starting cars in cold winter weather. It is best to start up and drive off or to idle and warm up for a few minutes before driving off?
Otherwise, I’ve had my car for two years and don’t recall this in the past, but has anyone else noticed a deeper grunt to the engine / exhaust in cold winter weather and a somewhat ‘heavier’ steering feel?
Thanks.
Old 01-23-2013, 12:13 PM
al7oot al7oot is offline
BiMMER4EVER
Mein Auto: 750Li F02
I just start the car and wait until the rpm low to 750 or 500 rpm and move. but while i'm moving i drive the car gently under 2500 rpm for like 10 minutes.
Old 01-23-2013, 01:04 PM
Great; thanks!
Old 01-23-2013, 04:13 PM
ChrisF02's Avatar
ChrisF02 ChrisF02 is offline
MCHTSCHNL
Mein Auto: 2013 750i
The manual says you can drive it immediately. But out of habit I wait 30-45 seconds before putting it in gear.
2013 BMW 750i - Coded, Executive, Lighting, Cold Weather, M Sport, M 303 Wheels, 5% Tint, Conti DWS Tires, 3M Bra, Front DE Plate.
Old 01-23-2013, 06:24 PM
Thanks, Chris!
Old 01-24-2013, 05:38 AM
Juffe Juffe is offline
Mein Auto: F01 730d
I have a 730d and as you might guess, it's pretty damn cold here in Finland during winter time, occasionally -20 degrees Fahrenheit and below.
I never wait when driving off. Obviously it's a good idea to avoid high rpm's for a few minutes, but BMW's are built to last, even in arctic conditions
F01 730dA & e90 325xiA & F650 GS
Ex:
e65 730dA LCI Individual
e61 530dA LCI Edition Sport
e90 318iA
e60 530xdA LCI
e39 530dA Touring M-Sport
e46 316iA
e39 530dA Touring
e39 523iA Touring
e30 320i
Old 01-24-2013, 08:23 AM
-20 deg F? Wow!
Old 01-24-2013, 12:36 PM
chrischeung chrischeung is online now
Mein Auto: 2012 ActiveHybrid 7 SWB
Do you have an engine block heater? Does that help a lot?
2012 ActiveHybrid 750i ED
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 01-24-2013, 07:33 PM
Cdnrockies Cdnrockies is offline
Mein Auto: X5 35d; 750Li; IS F
+1
We've seen that temp semi-regularly as well.
Curious if you've had any issues with the Adblue delivery like we have experienced on both our X5 and past ML320?
Originally Posted by dbs600 View Post
-20 deg F? Wow!
That's mild, where we lived in January of '08 we saw temps of -67 F with the windchill.
Also curious to know the answer to this. Block heaters are not available according to BMW Canada.
'11 750 Li Xdrive Alpine White
'10 X5 35d Space Grey
Old 01-24-2013, 07:43 PM
Originally Posted by cdnrockies View Post
that's mild, where we lived in january of '08 we saw temps of -67 f with the windchill.
What!?
Old 01-24-2013, 10:15 PM
Mein Auto: F01 730d
I normally have had engine block heaters in my cars, but in this I don't. I get bored easily with my cars and swap them about once a year and haven't gotten around to have a heater installed...
Electric pads attached to engine block are not that efficient compared to Webasto diesel heaters, but several hours of heating with electric heater can heat the coolant somewhat. The weird thing about OEM Webasto is, that it doesn't heat the engine, only the cabin.
Ex:
e90 318iA
e60 530xdA LCI
e46 316iA
e39 530dA Touring
e39 523iA Touring
e30 320i
Old 01-24-2013, 10:22 PM
Mein Auto: F01 730d
Originally Posted by Cdnrockies View Post
+1
This is a well recognized brand to be recommended to you, my Canadian friend:
http://www.padheaters.com/
It heats the oil instead of the coolant.
Ex:
e90 318iA
e60 530xdA LCI
e46 316iA
e39 530dA Touring
e39 523iA Touring
e30 320i
