Old 01-22-2013, 10:17 PM
TXSTYLE's Avatar
TXSTYLE TXSTYLE is online now
The Entertainment Guru
Send a message via Yahoo to TXSTYLE
Mein Auto: 750i (F01)
Taking The Mistress In For 60k Service... Suggestions?
What to definitely check for?
What to Watch out for from the stealership for **** I don't need???
BigMarcus ~ EVO 4G LTE
Old 01-23-2013, 06:52 AM
First_745Li's Avatar
Mein Auto: 2003 745Li
You probably dont need anything they would try to sell you.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-23-2013, 06:55 AM
TXSTYLE's Avatar
LOL! My advisor already knows NOT to ask me for unwanted crap. Just gimme the essentials!
What about you? Did you have a 60k service??
~ Big Marcus
Old 01-23-2013, 07:22 AM
I'm not sure what the previous owner did so I'm chipping away at it slowly. I haven't been driving her that much.
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-23-2013, 02:12 PM
Carboy7's Avatar
Carboy7 Carboy7 is offline
Teenage BMW Enthusiast
Mein Auto: MB S500/750Li Individual
If you haven't serviced the transmission then I would definitely do the transmission oil change. Check if the mechantronics sleeve is leaking
I had a whining water pumped replaced during this service, too.
2008 BMW Individual E66 750Li (Azurite Black Metallic/Rust Brown Merino Leather)
BMW Individual Composition Package
Luxury Seating Package
Convenience Package
Adaptive Ride Package
Comfort Access
HD Radio
Night Vision
Active Cruise Control
Rear Ventilated Comfort Seats
Rear Entertainment Package
2006 Mercedes-Benz S500 W220 (Flint Grey/Charcoal Nappa Leather)
Keyless Go
Electronic Trunk Closer
Old 01-23-2013, 10:46 PM
TXSTYLE's Avatar
Thanks guys.
She's up there. Awaiting to hear the damage....
Old 01-24-2013, 08:29 AM
TXSTYLE's Avatar
I an really digging the new 5. I already liked the way it looks. But it drives and handles well. Even though it's built on the e65 platform, it feels and is much smaller inside. Even though the length and width are about the same.
Also one of the absolute strangest and still not used to it... The engine completely shuts down when you come to a stop fit more than a couple of seconds! Efficiency Dynamics I thinks its called. I wonder how much gas that really saves.. .
ID:	359040   Click image for larger version
ID:	359041   Click image for larger version
ID:	359042   Click image for larger version
ID:	359043   Click image for larger version
Old 01-24-2013, 08:36 AM
So it would shut itself off at every light? and I guess it starts back up when you hit the pedal? Me likey though
'11 328i
'03 745Li
'03 Acura TL-S
'02 Infiniti QX4
Old 01-24-2013, 08:42 AM
TXSTYLE's Avatar
It's neat but unnerving.
kudos for all the technology...
~ Big Marcus
Old 01-24-2013, 09:04 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
Yes that's true, my friend was driving one as a loaner an he was tripping when he 1st notice it.
Old 01-24-2013, 09:43 AM
7Rage 7Rage is offline
Mein Auto: 2007 750Li
lol.. the hybrid escalade does that.. took it for a test drive and was like wtf....
Old 01-24-2013, 09:44 AM
I have the maintaane plan til 100000 miles... can i get them to do tranny oil ...i have about 67000 miles and i need to take it in for engine oil next week... would like tranny and spark plugs done....
Old 01-24-2013, 01:35 PM
Busurfer's Avatar
Busurfer Busurfer is offline
Honey Badger 2.0
Mein Auto: '08 750Li
I would check or perform the following (assuming you have not already done so):
1. Drain and fill transmission, replace pan, filter and bolts.
2. Replace Mechtronics sleeve whether it's leaking or not.
3. Replace oil sensor.
4. Check for head gasket coolant leak and weep hole leak.
5. Check water pump (mine went at 75k). If you need to replace it have them replace all the hoses, tensioners, o-rings and oil sensor while they have the front end off.
6. Check for oil leaks on the air pump for the brakes and whatever the oil filled shock that assists the roll is under the radiator, I had both of those start leaking before 70k.
7. Drain and fill the rear differential. Mine was still pretty clear when I did it at 65k but it's still better safe than sorry.
Life is too short for bad tone or crappy cars.
Old 01-24-2013, 01:42 PM
KeyserSoze819 KeyserSoze819 is offline
Mein Auto: 07 750Li
About the 5. Just had a loaner for 4 days 2013 528x it was slow and the handling was awful. I was thinking about getting the 5 in M sport but the drive was so bad and the car so small inside and seats uncomfortable I changed my mind. Plus the leather is cheap feeling. I guess the only way to get it is 550 M sport with comfort seats or get preowned 750i M sport for similar price. FWIW
Old 01-24-2013, 02:32 PM
Carboy7's Avatar
Your dealer will probably charge you a couple hundred dollars. However, if the mechatronics sleeve is leaving, then changing the oil would cost around $120
Convenience Package
Comfort Access
HD Radio
Night Vision
Keyless Go
