Old 12-04-2009, 05:20 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64,E65,Chrysler 300c
Replaced seat belt tensioner
ok, today i took off old tensioner and put new one on which was easy but then i went to put on belt and for some reason it was kinda loose, then i figured out they gave me wrong size belt, so then i went and got the belt size that was originally on the car when i got it and now the belt is still just a lil bit loose, i was wondering if there is a way to tighten the belt more or ?. cuz i was getting a squeal when i tapped on the accelerator before i replaced tensioner, now i get a squeal when idle and no squeal when i step on accelerator. unless i really hit it. need help, thanks.
Old 12-04-2009, 05:36 PM
petener999's Avatar
petener999 petener999 is offline
Mein Auto: 750i, x5 4.6is, E46 M3
What brand of belt did you buy?
Old 12-04-2009, 05:44 PM
bmw74me bmw74me is offline
Mein Auto: 750i
yes all you need to do is in the tensioner itself there is a plug you need to pull out and that will release the spring making the belt stretch and tighten up.... i had the problem and after a while we figured out that you need to pull that plug from the tensioner (it seems that plug is part of it but its not... its made to make you life easer .....hope that helps
Old 12-05-2009, 03:06 AM
Thanks, is the plug on the tensioner itself?
Old 12-05-2009, 09:43 PM
Thanks I located the plug and wut do ya know, it solved the problem, thanks
Old 03-11-2011, 09:06 PM
DFEL750I's Avatar
DFEL750I DFEL750I is online now
Mein Auto: 750I
Bringing this old thread back to life. Got an error message today. After clearing the error with INPA it comes back immediately. Looks like my passenger seat belt tensioner needs to be replaced. This looks like it should be easy enough to do but I'm looking for guidance from anyone that has done this before or have any useful advice to offer.
Old 03-12-2011, 08:03 AM
Tkrtape12 Tkrtape12 is offline
Mein Auto: 745i,FX35,951,ML55
Oddly enough my lite came on last week...is there a DIY for this doesn't sound to hard.....Thanks for any tips you can give....PM
03 745I
87 951 T BLACK
05 FX35 RED
04 ML55 BLUE
08 TrailBLAZER
91 300 ZX TT SOLD
05 A8 SOLD
07 LAND ROVER SOLD
Old 03-12-2011, 05:04 PM
sebi750's Avatar
sebi750 sebi750 is offline
Mein Auto: bmw 750 li
what kind of error message do you get?
Old 03-12-2011, 11:28 PM
Not sure of exact wording ...but Ithink it's like tensionor needs replacing...then a little red lite with a seatelt through it..I'll check in the AM for exact wording...PM
03 745I
87 951 T BLACK
05 FX35 RED
04 ML55 BLUE
08 TrailBLAZER
91 300 ZX TT SOLD
05 A8 SOLD
07 LAND ROVER SOLD
Old 03-15-2011, 07:20 AM
SEBI...Message said Fault in Pass-Restraint syatem affecting airbag belt tensioner or belt force limiter fastner and continue to wear belts...Please contact nearest Stealerhip....PM which tensioner and is there a DIY? Thanks in advance PM
03 745I
87 951 T BLACK
05 FX35 RED
04 ML55 BLUE
08 TrailBLAZER
91 300 ZX TT SOLD
05 A8 SOLD
07 LAND ROVER SOLD
Old 05-01-2011, 12:40 AM
resistro resistro is offline
Mein Auto: 740
Fault in Pass restraint belt tensioner or belt force limiter
Did you ever fix this problem, I got the same thing in my 2003 745.
Old 01-24-2013, 04:15 PM
Mein Auto: 740
Got it fixed. I just had to reset it with my scanner. So far so good.
