TPMS spazzing out - Bimmerfest - BMW Forums
Old 01-24-2013, 05:41 PM
civicrtype1 civicrtype1 is offline
Mein Auto: X5
TPMS spazzing out
So my TPMS for my front drivers side wheel went off (tire pressure low) last Saturday, which I had assumed to be from the temp changes recently. So I checked all 4 tires which the pressure in each were 56psi. Apparently this is too high according to the specs on the door. So the service dept decreased the pressure to 40 and the same thing happens. Has anyone else received they're X5 with waaaay too much tire pressure and have this issue? I just purchased my 13'X5d 3 weeks ago and pretty salty about this.
Old 01-24-2013, 07:46 PM
AutoUnion's Avatar
AutoUnion AutoUnion is online now
Mein Auto: Deutsch Automobil
You know you can calibrate the TPMS in the iDrive right? Set it to a pressure you want and then reset it in the iDrive...
Old 01-24-2013, 08:14 PM
jashearer jashearer is offline
Mein Auto: Holden Wagon & Sedan
I don't think he'd want to keep it at 56 psi... unless they are E load range tires
Notice any difference in ride, 56 psi is way up there, had to be hard as a rock, even for runflats.
Jay
Rover - 2013 Holden Commodore SV6 Sedan
Clark - 2013 Holden Commodore Sport SV6 Wagon
Brumby - 1955 Holden FJ Ute
Old 01-24-2013, 08:57 PM
Penguin Penguin is offline
Mein Auto: Z4 and X5 Diesel
Jay
As an aside, 56 psi is a sign of bad prep by the dealer -- I believe the vehicles are shipped with high pressure in the tires and they are supposed to be adjusted downward as part of the dealer prep process.
Old 01-24-2013, 09:06 PM
DCC DCC is offline
BMW Fan
Mein Auto: '02 Z3 M Coupe
He is in Texas, dealers here are not the greatest...
If he is in Houston, its even worst...
2016 320i Sedan
2011 M3 Sedan
2002 Z3M Coupe
Old 01-25-2013, 03:37 AM
Mein Auto: X5
Lol. Agreed. Yes, the ride is a huge difference. I've tried many times resetting in Idrive, but the darn low tire keeps coming back on. 600 miles on it and already this crap. Ugh
Old 01-25-2013, 07:25 AM
Kzang Kzang is offline
Mein Auto: 2015 X5 ///Msport 35i
Originally Posted by civicrtype1 View Post
So my TPMS for my front drivers side wheel went off .
I'm curious to know how you got your TPMS to tell you which tire was low in pressure or did you just check each tire and determine the front driver side was low manually?
All my tires light up yellow when one tire is flat..
2015 X5 Msport Space Grey
Old 01-25-2013, 08:21 AM
finnbmw's Avatar
finnbmw finnbmw is offline
Mein Auto: 2010 & 2012 X5 35d
Bad TPMS sensor?
Old 01-25-2013, 05:36 PM
Mein Auto: X5
It actually highlighted the front left tire yellow and said "Front left tire low" on the Idrive.
Sure enough, the TPMS monitoring system finally said "malfunctioning" today and started flashing. So much for the foreign object in my tire theory from the dept after my reiteration of the malfunctioned TPMS.
1-Me
0-Stealership Service Dept
Old 01-28-2013, 11:09 AM
1-Me
May I ask which model year X5 you are speaking of?
Thanks.
Old 01-28-2013, 11:13 AM
From his original post
"I just purchased my 13'X5d 3 weeks ago and pretty salty about this."
This torques me off more than a little since this feauter was available before mid 2011 production builds and now appears to be back...
Jay
Old 01-28-2013, 11:20 AM
Jay
And my 2013 X5 35i does not have this feature...
I guess the 2013 Diesels are considered the newer generation? I wonder if they have the graphic speedometer / dash as well?
Old 01-28-2013, 11:32 AM
Production dates from both of you would be good to have. Maybe they had another "running engineering change" which re-instated the feature.
Jay
Old 01-28-2013, 11:46 AM
E46_Ci E46_Ci is offline
Mein Auto: 2005 325Ci + ZPP/ZSP/ZCW
I just bought a 2007 X5 3.0Si and it calls out which tire is low in the iDrive. Highlights Yellow or Red and the others stay Green.
After taking delivery of it, the TMPS was "spazzing out" for the Right Front Tire - kept going between malfunction and low pressure (gonging every 5-8 seconds)... took it to BMW dealer and they found that when the VW dealer we bought it from put new tires on, they either broke or just didn't replace the TMPS sensor in that wheel.
Alpinweiß 2005 325Ci
Spacegrau 2007 X5 3.0Si
Old 01-28-2013, 11:54 AM
Jay
My production date was in April 2012.
Old 01-28-2013, 01:02 PM
NoI4plz NoI4plz is offline
Mein Auto: A box with 4 circles
For readers
Established info:
07-Late 2010 individual tire monitoring
Late 2010-present tire monitor indicates tire pressure low, but no individual status displays
Op: 2013 diesel apparently has individual tire monitoring again?
BMW and Mercedes Build Beta Products!
Lexus build Release Candidate Products!
Why does this matter?
CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world!
Old 01-28-2013, 02:50 PM
RockChips RockChips is offline
Mein Auto: 2008 X5 3.0si
My 2008 has individual tire monitoring.
Score 1 for the pre-LCIs
Old 01-29-2013, 09:54 AM
Yeah this is weird..
My 2007 and 2010 E60 ( 5 series ) both had individual tire pressure monitors..
My 2013 E70 does not...
