Old 01-25-2013, 06:36 AM
dredreson dredreson is offline
Mein Auto: 2000 BMW 323i
How do these prices sound to you?
2000 bmw 323i
PARTS
Fan clutch $300
Water Pump $99
Belt $50
LABOR
2 1/2 HRS $230
Sent from my SPH-D710 using Bimmer App
Old 01-25-2013, 07:06 AM
vandyboy vandyboy is offline
Mein Auto: 01 325i automatikgetriebe
Prices seem high - the mark-up must be enormous, unless they are getting parts from the dealer. The OEM fan clutch and OEM belt are less than half your listed prices on Pelican Parts. And Pelican has two good WPs (Graf or Saleri) for $44 to $55.
The labor rate of $92.00 per hour is about average for a good indy garage. See if they will let you bring your own parts and start shopping around on the sites recommended on this board.
Old 01-25-2013, 10:25 AM
halltristan's Avatar
Bimmer Enthusiast
Mein Auto: 325i and X3
Very high prices. It's standard for a shop to mark up parts by 30% but not by 100%. Every part you have listed you can find for half price online and auto part stores.
And, at least in my area, labor is usually 60 an hour.
Member No. 470379
Old 01-25-2013, 10:43 AM
MalibuMafiaV's Avatar
TheMalibuMafia
Mein Auto: E60 M5 & JB4+ 335i
Wow that's awesome labor charges. Here in cali my good price is $85 an hour. If I didn't know the owner of the shop it would be $115. And at my Masi shop it's $135 an hour.
TheMalibuMafia.com
BMW 2006 M5 - REALLY LOUD
BMW 2007 335i. Single Turbo 6266.
BMW 2006 M3 - stock - SOLD
Old 01-25-2013, 10:52 AM
I knew I smelled a pig , smh. Thanks guys.
Old 01-25-2013, 11:28 AM
Scottji's Avatar
Scottji Scottji is offline
Mein Auto: 2004 325i
$95 is the going labor rate in so-cal. But it's not so much the rate to me as it is the time quoted. Don't think that job should take 2.5 hrs.
Old 01-25-2013, 11:42 AM
TannerT TannerT is offline
Mein Auto: 03 330ci 3pdl 89 325i
Ohhh that must me the gold plated fan clutch and carbon fiber belt. Very nice peices
Sent from my PantechP9060 using Bimmer App
[SIGPIC]s[/SIGPIC]Formula SAE "Speed is Sexy"
Old 01-25-2013, 12:10 PM
christopherr117 christopherr117 is offline
Mein Auto: 323Ci E46
Make sure that the fan clutch they install is OEM. I had mine replaced last year on my 323 with an aftermarket one that was "up to spec" according to the manufacturer of the part and the distributer of the shop that I went to. The clutch allowed for wobble and resulted in flying fan blades that took out my expansion tank, radiator, hood, and obviously obliterated the fan at the cost of about $1k to fix. just a lil heads up.
Old 01-25-2013, 12:24 PM
Ok...now Im nervous about ordering my own parts.
Can someone point me to the correct parts? I see on pelican parts that they have two types of water pumps, one with a metal impeller and another with 'composite' impeller ..what does this mean...and which is the best for my vehicle?
Old 01-25-2013, 12:29 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Mein Auto: 2004 325 Convertible
Order from here, and call Max if you have any questions. He is a site sponsor, has great prices, and offers free shipping on orders over $45. Many here use him.
http://www.oembimmerparts.com/BMW_E4...rts_s/1863.htm
Old 01-25-2013, 12:34 PM
jhurless jhurless is offline
Mein Auto: E36
Other than the fan clutch, that quote is on the more reasonable side of BMW quotes. The labor rate is about right, time is correct. The problem I see is that the shop is quoting a water pump and no other cooling system components. Typically with E46 if the water pump has failed, chances are the tank, hoses and t-stat are about toast too. This shop doesn't sound like a BMW specialty shop, and their labor rate backs that assumption.
My advice would be to take it to a good local Bimmer shop and get another diagnosis there. And to comment on something mentioned above, I do not recommend you try to bring your own parts. That's like bringing your own steak to a restaurant. Most shops will be insulted, just so you know.
Old 01-25-2013, 12:43 PM
Scottji's Avatar
I hate to disagree, but I'm going to. I think most mechanics won't do a complete overhaul due to one part failing, unless the customer specifically asks for it. The "DIY" way of doing things is that we'd might as well just do it while we're there. Most mechanics don't do it this way -- they just fix the part that's broken.
Also, my indy has no problem with BYOP (bring your own parts) so long as they're reputable.
Old 01-25-2013, 12:46 PM
Solidjake's Avatar
Solidjake Solidjake is offline
Zero. Leaks.
Mein Auto: 02 330i 6MT
Clutch costs $90 for Sachs which is OEM
http://www.autohausaz.com/search/pro...2@Fan%20Clutch
Pump is $55 OEM Saleri
http://www.autohausaz.com/search/pro...8@Water%20Pump
Belts cost $27 for both
http://www.autohausaz.com/search/pro...20Drive%20Belt
Total is $172 for parts.
Belts and clutch you can DIY with very simple tools.
Old 01-25-2013, 01:16 PM
Coochie_Bandit's Avatar
Coochie_Bandit Coochie_Bandit is offline
Mein Auto: 540
M k
K
Old 01-25-2013, 01:17 PM
Solidjake's Avatar
Zero. Leaks.
Originally Posted by Coochie_Bandit View Post
M k
K
? huh
Old 01-25-2013, 01:56 PM
There's two belts?
Old 01-25-2013, 02:04 PM
Scottji's Avatar
Originally Posted by dredreson View Post
There's two belts?
Old 01-25-2013, 02:06 PM
Scottji's Avatar
Sorry, that was rude.
You have a longer main accessory belt that runs your water pump, power steering, alternator, etc., and a belt that sits in front of that which powers your A/C compressor.
With an e-50 torx or big hex socket and breaker bar, takes a few seconds to change (once the fan is out of the way).
Old 01-25-2013, 02:34 PM
Lol...I can admit that I don't know **** about cars. I can do your Calculus, Physics and Organic Chemistry homework though.
My mechanic claims that my failed fan clutch caused my belt to break. Is this possible?
Old 01-25-2013, 03:09 PM
SJBimmer's Avatar
It is possible. Where in South Jersey are you? If you are far enough South I may be able to recommend someone.
Old 01-25-2013, 03:10 PM
Mein Auto: E36
Which is why I suggested a specialty shop, because they would know that E46 BMWs require a cooling system upgrade around 100k miles consisting of the tank, hoses, water pump and tstat. Otherwise you fix one part and come back two weeks later to fix another.
Cherry Hill area.
Old 01-25-2013, 03:14 PM
SJBimmer's Avatar
Cherry Hill area.
Too far for you to travel unfortunately. I am in the Stone Harbor, Avalon area. Unless you want to take a road trip.
Old 01-25-2013, 09:12 PM
Mein Auto: E36
It is unlikely that it was the fan clutch. If your water pump seized, it would cause the belt to rub against a non-rotating pulley and burn up. If the water pump bearing blew out, it could cause the pulley to throw the belt. While it is possible the fan clutch is bad, that is not the most likely cause of your problem.
Old 02-02-2013, 11:14 AM
Parts took forever to come in from autohausAZ.com, I should have had it expedited. Sheesh. I'm taking the parts to my mechanic on Monday, I hope this guy doesn't try to say that the parts are wrong.
2000 BMW 323i, these are definitely the correct parts, right?
