Old 01-24-2013, 11:58 PM
Taeksoo Taeksoo is offline
Mein Auto: 2013 335i Sedan
Engine breaking?
I'm no engineer (obviously) but just wanted to ask if this is right.
I noticed when I'm in Drive and braking my rpm goes down then up and then down then up.
It seems like it's down shifting while stopping.
I would have thought that this would waste more gas.
I'm just curious if anyone can explain why this is and why it would be more gas efficient? Or it's not gas efficient but help stop faster?
Sent from my SCH-I535 using Bimmer App
Old 01-25-2013, 12:20 AM
FrogmanF30's Avatar
FrogmanF30 FrogmanF30 is offline
Mein Auto: 2012 328i
The transmission downshifts while braking so that it's in the right gear when you accelerate again. Pretty standard.
Old 01-25-2013, 05:06 AM
d geek d geek is offline
diesel evangelist
Mein Auto: Volvo V60+ Volvo S80
Most modern vehicles cut fuel when your foot is off the go pedal. So even though you see the rpm's moving up and down you should understand that most of that is caused by the wheels turning the engine not vice-versa. Bottom line is that it does not negatively impact fuel economy.
Downshifting helps reduce brake wear and as pointed out above puts your trans in the correct gear for moving out again.
Old 01-25-2013, 09:32 AM
Alright that makes sense.
My last car was 12 years old before I got this so haven't notice this type of things.
Also, would this be bad for your transmission? I'm sure BMW has thought of everything and I'm sure it's ok but I'm just curious. My understanding is that if you have manual transmission and engine breaking would be bad on transmission. But then again this could be decade old fact.
Old 01-25-2013, 10:48 AM
diesel evangelist
engine braking is not detrimental to transmission service life- either manual or auto.
Downshifting a manual will not wear out the clutch or other components if done properly.
Old 01-25-2013, 02:14 PM
jlukja jlukja is offline
Mein Auto: '13 328i
Agree. I would add that, in this situation, the braking comes from the opposing force of the air (without fuel) being compressed by the pistons. Without fuel you have compression without detonation.
MY2013 328i, N26 / 300 / 4CG / KCDF / 2DW / 205 / ZDH / 302 / 3DZ / 403 / 494
Old 01-30-2013, 09:03 AM
spicytofu spicytofu is offline
Fungineer
Mein Auto: 2011 E92
Engine braking serves two purposes: to start off in the correct gear (not as likely since if you accelerate, it will downshift anyways) and most importantly, generate enough vacuum to apply braking pressure. You do need high RPMs to get good vacuum, but if RPMs are very low, you will get limited braking power. Notice your RPMs are not "true" engine braking and stays under 1500 rpm with each downshift. (in real engine braking, you will be hitting 2k+ with each downshift) Fuel is cut off under no load with RPMs are above a set threshold. The injectors will kick in under that threshold. You can see this by revving the engine and then, as the RPMs drop, you see a slight bounce 1k. Its not BMW specific, pretty much all cars do this nowadays.
Ordered 4/20/2011 - Delivered 4/20/2011
Has a little bit of this, some of that - a happy camper.
Old 01-30-2013, 10:35 AM
kpgray's Avatar
kpgray kpgray is offline
GasCompression
Mein Auto: 2014 335i M-Sport RWD
I just came out of an Acura TL to a 328i xDrive and I also noticed the engine drag seemed greater than my Acura. My Acura almost seemed to coast in comparison (or disconnect from the engine) when I let up the gas, my Acura would certainly would coast further upon deceleration, however, upon further investigation, BMW has a Brake Energy Regeneration System (link below) that shows it as one of the Performance and Efficiency items on the 3-series features and specs page. I notice when you decelerate, it takes just a moment after you release the accelerator (about the same amount of time you wait for the auto stop/start to turn the engine off at a stop light) and then you will feel a slight perception of the engine downshifting, I believe that is the regeneration system taking the momentum energy and using it to charge your battery. I have found that I can utilize the drag to coast into a red traffic light with less braking and not irritating the person behind me. I am not real familiar with the system, but I had inquired about the deceleration and was told by one of the experts from BMW at the local summer Olympic Drive event last year that is what I felt.
http://www.bmwusa.com/Standard/Conte...and_specs.aspx
Kenneth P. Gray
2014 Black & Tan 335i M-Sport/SAT/PP/TP/CWP/DAP/HK/403M
2010 Cadillac SRX Performance, Platinum Ice/Ebony (Wife's drive)
2014 Black/Tan 335i M-Sport/Sport Automatic Transmission/Premium Package/Technology Package
Cold Weather Package/Driver Assistance Package/Harmon Kardon sound/19" Wheels 403M HP tires
Old 01-30-2013, 03:09 PM
Thanks for all your input on this.
They do make sense. Like I said, I'm sure smart BMW engineer thought of everything in making an ultimate driving machine. It's nice to kind of understand some of them.
