Old 01-09-2013, 04:01 PM
Irak1121 Irak1121 is offline
Mein Auto: 2006 Z4
Question Z4 2006
2006 z4
Hi guys, looking for help on a warning indicator battery light is on when car is started but then will go out after a few minutes.
Manual says alternator not charging . Battery not charging. However why would light go out then?.
Please help.
Old 01-09-2013, 06:03 PM
GA Z4 GA Z4 is offline
Mein Auto: 2004 Z4
Belt loose?
Old 01-09-2013, 07:34 PM
Droptop85 Droptop85 is offline
Mein Auto: 03 Z4 3.0i
Check your battery voltage before startup. Maybe your battery is weak.
Old 01-10-2013, 04:03 AM
Mikey48 Mikey48 is offline
Mein Auto: BMW Z4 3.0
Sounds like a weak battery to me.
Old 01-25-2013, 03:58 PM
Uber-Fritz Uber-Fritz is offline
Mein Auto: 2006 Z4 3.0i
I think a loose/defective belt is the most likely too. As the engine warms up and expands (slightly tightening the belt) and the alternator warms up and runs freerer, this may well produce enough output that the idiot light goes out. Second guess is the regulator isnt delivering the juice in the specified amounts. Good luck.
Old 01-27-2013, 09:29 AM
NewZee NewZee is offline
Mein Auto: 2008 Z4 3.0si Roadster
Hi!
If you have a volt/ohm meter you can check the voltage at the battery when the car is running. The alternator (voltage regulator) should be putting out about 14.3 volts. If you check the battery voltage with the car not running even a weak battery could show close to 12 volts because there is no draw on it. Like already suggested it could be a loose belt on the alternator, or a weak battery. You can get the battery checked at a auto parts store like Autozone. They can put a load on it and tell you if it's OK.
Good luck
2008 3.0si, Roadster, Premium & Sport package(s)
