Old 01-24-2013, 11:37 PM
Jimsterhipster Jimsterhipster is offline
Mein Auto: Z4
New top
2004 Z4 2.5....... Top was damaged, had replaced, they did a great job, but there is more cabin noise now. Any suggestions... Doesn't leak, seems tight. It has a head liner. Is it possibly not as insulated. Anyone else had the same problem and is there a way to cut down on road noise
Old 01-25-2013, 02:08 PM
chickdr chickdr is offline
Mein Auto: '06 M Roadster Imola/Blk
Did they use an OEM top?
Old 01-25-2013, 04:05 PM
Uber-Fritz Uber-Fritz is offline
Mein Auto: 2006 Z4 3.0i
Drive with the top down then
Seriously, it takes very little material sticking into the airflow to make a lot of noise. Look at the fit at the top of the windshield and around the side windows. Years ago I had the noise drop after replacing the top on an old Triumph. Looked to me like the only difference was the after-market top material was a whole lot smoother than the factory rag.
Old 01-27-2013, 09:18 AM
NewZee NewZee is offline
Mein Auto: 2008 Z4 3.0si Roadster
Did you try turning up the radio?
Seriously! Take a look at the fit between the windows when they are rolled up and the new top, if there is a gap there it can result in noise?
Good luck
Old 01-27-2013, 09:25 AM
And he's got a Triumph so he knows all about wind noise!
Old 01-27-2013, 09:33 AM
Yeah!!! Noisey, Smelly, Leaky, but I LOVE it!
Old 01-27-2013, 11:00 AM
Mein Auto: Z4
Good luck
Thanks, I'll check that out. I also have an Alfa Spider, and your right, the smell, wind and the noise is just part of the experience
Thanks again for your responses.
Old 01-27-2013, 01:58 PM
It is part of the experinece....
I often pine for my long lost TR8, grumpy old beast that it was. Less so for the Fiat that came before it.
Good luck with the top.
