E46 (1999 - 2006)
Old 01-24-2013, 04:54 AM
1972ford 1972ford is offline
Function over fashion
Mein Auto: 325xiT
E46 vs E83 cold start. And the winner is...
At about -10 degrees this morning, my wife's x3 had a rough time starting this morning, she cranked it for 5-10 seconds 3 times before it finally fired! Slllooowww cranks, too, and the battery was new in June. My trusty wagon fired right up like it was 65 degrees. Except that it didn't reach normal operating temp for over 20 min. But I am NOT impressed with the cold starting performance of the x3!
Old 01-24-2013, 05:12 AM
jdauria jdauria is offline
Mein Auto: 323Ci & X3 3.0i M-Sport
I have both as well, X3 i guess are prone to cold weather startup issues. I read a lot of threads on people having a real hard time. It was snowing this morning in VA, about 2 inches or so on the cars, decided to take the X3 to work today for AWD purposes. I usually leave the key in position 2 for a couple seconds to let the fuel lines open up before crank. Have you tried that?
I haven't had any issues with cold starts, granted its not -10*F like you
#465420 National Capital Chapter
My Progress Thread
2000 323Ci | TiAg | Gray | ZSP | ZPP | AFE | UUC | Eisenmann | Koni | ACS Type III | Coby Wheel | 330 Brake Swap w/ BMW Performance Rotors
2006 X3 3.0i M-Sport | Silver Grey | Terracotta | Navigation | Premium Pkg | Cold Weather Pkg | AFE |
Old 01-24-2013, 06:04 AM
Brobby87's Avatar
Brobby87 Brobby87 is offline
The Arch Bishop
Mein Auto: 2003 325i, 1986 535i
I do this every time and we've had subzero temps here in Iowa all week. It fires up every time.
Old 01-24-2013, 06:25 AM
Glad to hear it works. It seems that the X3 fuel lines/pump/regulator or something isn't so robust. It needs time to prime.
My Progress Thread
Old 01-24-2013, 06:43 AM
Mein Auto: 325xiT
We'll try that tomorrow morning. Though it seems like the fuel system should have been primed plenty by the 2 or 3 attempts at starting it before it did finally fire. This car has cranked relatively slowly with ANY cold weather, the cranking speed is directly correlated to the temperature. The e46 might crank a LITTLE slower but nothing like the x3. I've read a few of the cold start issue threads but for one, but as long as it starts I'm not going to get too worried.
Old 01-24-2013, 06:56 AM
Check out the E83 section for cold start issues, and possible solutions.
My Progress Thread
Old 01-24-2013, 11:05 AM
Fast Bob's Avatar
Fast Bob Fast Bob is offline
Keeping it surreal
In extremely cold weather, having a (heated) "battery blanket" and a heated oil dipstick are about the only thing that will make a real difference.
This is one area where AGM batteries have an advantage.
The road goes ever onward....
(R.I.P. Jever)
Old 01-25-2013, 06:10 AM
Mein Auto: 325xiT
What do you suppose the difference is between my car and the X3? They're parked next to each other outside. The X3 is an '07, mine's an '01. Is the N52 3.0l engine higher compression and therefore harder to turn over? Or is that a crazy theory? My engine also has 80,000 more miles on it. The X3 maybe has more electrical stuff, but the e46 isn't exactly electrically simple. It also doesn't appear to lack for cranking amps, it just turns slowly.
As far as battery heat, I suppose a trickle charger would also help keep the battery warm. While there isn't an issue with the charge on the battery, it would serve the purpose of keeping it a little warm, right?
Old 01-25-2013, 06:21 AM
lgr122 lgr122 is online now
Mein Auto: BMW e46 1,9l M43
What kind batteries do they have?
Maybe your e46 just have more spare capacity and e83 is designed tighter to the limit?
Generally increasing battery capacity can help any car in cold start, but some kind heating device can be even better.
Old 01-25-2013, 08:24 AM
Fast Bob's Avatar
Keeping it surreal
I would speculate that the X3`s electrical system presents a greater load to the battery, resulting in slower cranking. Keeping the battery warm insures that the electrons inside the battery are flowing freely, providing a quick reaction when you turn the key.
(R.I.P. Jever)
Old 01-25-2013, 09:39 PM
In Russia I saw one old man who was taking his battery inside his apartment every night and then bringing it back in the morning. Maybe bit extra trouble that way also, but i'm sure he didn't have too big problems about starting his old car.
