Old 01-24-2013, 05:23 AM
pepe65's Avatar
pepe65 pepe65 is offline
750li 745i
Mein Auto: 745.750.x5.350z.ram1500v8
Need some input... car broke down
Fellas, so the other day Im chuggin along and I lose my steering around a pretty sharp turn. Almost wrecked the car but managed to get it into a lot. After I pulled in I got dynamic drive fault, trans failsafe, abs parking, check engine, generator fault ect... the car is on its way to the stealer and Im just curious what could have happened... is it the unregistered battery? I've had it for over a year and had no issues. Could it be the serpintine belt? How much could I be looking at money wise? Thank you guys.
Sent from my SAMSUNG-SGH-I747 using Bimmer App
Old 01-24-2013, 05:48 AM
Db750's Avatar
Db750 Db750 is online now
David
Mein Auto: E63 M6 & E92 335i
Sounds like either a battery or alternator issue. I had the same problems with my M6 and it was alternator.
2008 E63 M6 - Black Sapphire - Sepang Bronze Full Merino - Carbon Fiber Trim - Alcantera Headliner - SMG - HUD - Soft Close Doors - Comfort Access - Individual Audio w/Sat and HD Radio
2009 E92 335i - Black Sapphire - Black Dakota - Burl Walnut - Sport - Premium - Cold Weather - Navigation - L7 - Comfort Access - Smoker's Package
Member: BMWCCA #471614
Old 01-24-2013, 07:17 AM
Rookie2008's Avatar
Rookie2008 Rookie2008 is offline
Mein Auto: BMW 745LI/ F02
+1 did you hear any rattling or smell something funny?
Old 01-24-2013, 07:54 AM
pepe65's Avatar
750li 745i
No smell man. Car was really shakey to start and knocked hard . No sound but it was only 15 degrees. Any thoughts on cost?
Old 01-24-2013, 07:57 AM
Rookie2008's Avatar
Alternators run about $1000.00 at the dealer an the labor around $500.00 at a good Indy. If you shop around you can find a remand alternator for around $350.00 to $500.00. Or try Auto zone maybe like $700.00 or so.
Old 01-24-2013, 08:01 AM
Rookie2008's Avatar
Battery will cost less then $300.00 if I rem,ember correctly. Try sears an make sure its a AGM battery type 46 I do believe. Plus you must register it. Good luck.
Old 01-24-2013, 08:17 AM
pepe65's Avatar
750li 745i
Thank you rookie. I am crossing my fingers its just the battery.
Old 01-24-2013, 10:34 AM
Db750's Avatar
David
It's probably your battery since you didn't register it. You can check on realoem to find the price of the alternator. Mine was replaced under warranty, but I was thinking the parts cost was around $700.
Here is a video I took when my car started going crazy. I was on the highway 150 miles from home. I got some of the same messages as you along with the steering wheel being hard to turn. Pay close attention to the speedometer as well. Pretty scary going 80 mph and having this happen.
http://i1090.photobucket.com/albums/...71F889887C.mp4
Edited the terrible curse words out of the video.
Old 01-24-2013, 11:24 AM
pepe65's Avatar
750li 745i
Thanks for the help db. Scared the crap out of me. I believe the dealer said something about it being $600 IF it is infact the battery.... that seems really high for just a battery...
Old 01-24-2013, 11:41 AM
Db750's Avatar
David
Yeah that's very high. You can buy the battery at autozone. Just make sure it's the proper AGM battery as rookie said. Find an Indy to register it.
Old 01-24-2013, 01:57 PM
MakaveliFaison's Avatar
MakaveliFaison MakaveliFaison is offline
Mein Auto: Bmw E64,E65,Chrysler 300c
If your belt breaks same thing happens. Did u pop the hood and look? If not alt
650i sport hud asanti af132
Old 01-25-2013, 07:19 AM
pepe65's Avatar
750li 745i
So I just heard back and $900.00 for the belt and battery. Does this sound right??
Old 01-25-2013, 07:20 AM
Rookie2008's Avatar
From the dealer... Yea that could be right but it would have been cheaper if you purchase the battery an belts an went to an Indy to have repaired.
Old 01-25-2013, 07:21 AM
Rookie2008's Avatar
Battery take little to know time to swap. Paper did mines in the parking lot of sears an registered it in mins
Old 01-25-2013, 07:22 AM
pepe65's Avatar
750li 745i
Problem is AAA took it to the dealer which is over an hour away. I'm not familiar with any indys that know bmws.
Old 01-25-2013, 07:25 AM
Rookie2008's Avatar
I would say yes then cause you cant really predict what the dealers will charge, just know it will be HIGH.
Old 01-25-2013, 07:30 AM
pepe65's Avatar
750li 745i
Thanks for your help rookie.
Old 01-25-2013, 08:28 AM
Db750's Avatar
David
Check here for reputable independent BMW shops:
http://www.bimrs.org/
Old 01-25-2013, 12:35 PM
Lace_Up Lace_Up is offline
Mein Auto: BMW 745Li
Same thing happened to me every morning or when it was cold. Turned out to be the Alternator. Bought mine from www.rockauto.com.
Old 01-25-2013, 11:03 PM
Keif Keif is online now
Master Tinkerer
Mein Auto: 2007 Alpina B7
+1. If you're hearing a dull (and possibly loud / somewhat violent) knocking/thunking, you're likely looking at an alternator. Mine did that then seized up...had my alternator rebuilt for around $200 at the nearest alternator shop, threw on new belt in place of burned up belt, all was good.
Sent from my SCH-I605 using Bimmer App
White 2007 Alpina B7
Supercharger clutch/bearings (check DIY), sunroof seal, quarterto8's 6000K angel eyes, bumper side mounts
Black 2002 BMW E66 / 745Li (sold)
KW v3's, blue angel eyes, 8000K headlights & HID fogs, rebuilt alternator, sunroof seal, CCVs, NGK Laser Platinum plugs, sway bar bushings, battery, timing & valve cover gaskets, valve stem seals, guibo joint, mechatronic sealing sleeve, trans fluid, alternator bracket mounting gasket, sanded headlights...
Old 04-16-2013, 02:23 PM
07jace750li 07jace750li is offline
Mein Auto: 750li
My generator fault sensor came on but the car still running fine is that the altenator or battery issue???
