Old 01-25-2013, 08:52 PM
Sir Daniel Sir Daniel is offline
Mein Auto: 2009 X5 4.8i
would 2012 LED head lamp fit into my 2009 model?
hi does anyone know if the newer model LED lamp would replace the yellow angeleye on my 2009 E70? Thanks~
Old 01-26-2013, 07:28 AM
tribecaX5 tribecaX5 is offline
Mein Auto: '11 X5 35d
They should fit. You may have to purchase extra adapter harnesses/plugs. After you retrofit, you have to recode in order remove the bulb out message. When I had a 2009, I retrofitted the tail lights with LCI tails (purchased at getbmwparts). Looked great. Took it to BMW and they removed the bulb warning for about $125. You could find people who can do the coding for a lot cheaper.
Old 01-26-2013, 08:59 PM
NoI4plz NoI4plz is offline
Mein Auto: A box with 4 circles
^ cant believe a dealer decided to remove a bulb warning. Usually they dont code, since they might become liable for unforeseen circumstances.
BMW and Mercedes Build Beta Products!
Lexus build Release Candidate Products!
Why does this matter?
CAUSE EVERY TIME someone says Lexus has better build quality, one should consider what Toyota their Lexus Engine and chassis platform comes out of and how long that part has been tested in the real world!
Old 01-26-2013, 09:01 PM
It should fit, but would require mods and coding afterwards (someone already mentioned it).
Are you scoring the entire unit for cheap, caz that would it make it worthwhile, since the best on the market (LUX angel eyes) are close to $200.
NOTE:
If your thinking of removing bulbs, that would not work, entire headlamp assembly would most likely work.
Old 01-26-2013, 09:15 PM
What liability? Go to every single dealer and they will remove the "bulb out" warning if you upgrade to LCI.
Let me explain, which I am sure you already know - when you upgrade from, let's say, halogen to LED, the bulb warning will come up because LED's draw a lot less power than halogens or regular bulbs. Therefore, the computer thinks the bulb is out when it is not. How could a dealer be "liable for unforeseen circumstances"? It makes absolutely no sense.
Old 01-26-2013, 09:59 PM
I honestly dont get the liability part either, as the headlight assemblies, are DOT approved, BMW designed parts, but thats the SA official policy on that lol and im ok with that. But im guessing the ok part stems with that fact I like coding, especially with the amount of info available here and on bmw coding soo...
