Old 01-27-2013, 09:38 AM
Maine82 Maine82 is offline
Mein Auto: e46 330xi
Thank you for this thread, very nice info.
I went ahead and did this same thing to my e46 330xi and I have too much vacuum being created in the valve cover area, I can hardly remove the oil fill cap and I have valve cover gasket leaks developing.
I installed the PCV valve so that the intake can pull as much air as it wants, I was under the impression that this was the correct way to install it.
I believe that you are using this valve to actually limit the amount of air the intake can pull through the valve cover. If so, I have the valve backwards.
Can someone confirm?
Old 01-27-2013, 09:50 AM
eparayno's Avatar
eparayno eparayno is offline
Mein Auto: 2001 530i
Are you using the same threaded PCV as I am? The threaded portion should be pointed towards the intake.
Old 01-27-2013, 10:39 AM
I don't think so- Fram #FV263 with the threaded portion pointing towards the intake.
Old 01-27-2013, 10:44 AM
Is your valve reducing flow to the valve cover or to the intake?
Old 01-27-2013, 10:49 AM
eparayno's Avatar
Hmmmm....I thought I had too much vacuum at one point because my hoses started pinching but I was using heater line hoses which were the wrong type. I used beefy fuel line hoses made by Gates instead, purchased from Napa:
http://www.napaonline.com/Catalog/Ca...191_0395047484
Old 01-27-2013, 10:53 AM
eparayno's Avatar
Also shake the PCV vale. It should rattle when you shake it, that metal piece on the inside should look off center through the hole.
Old 01-27-2013, 10:58 AM
The valve shakes and is new, I can blow one way through it freely and the other way is much reduced.
Should it be installed to reduce vacuum at the valve cover side or installed to allow free vacuum from the intake to the valve cover?
Right now I am having difficulty removing the oil filler cap with the car running, it is far too much vacuum, which makes me think the PCV valve should be restricting vacuum to the valve cover, not allowing it.
Thank you for your help!
Old 01-27-2013, 11:11 AM
Yep- just did some research, pretty certain I have this backwards, basically an unrestricted loop from the intake to the valve cover.
Old 01-27-2013, 11:53 AM
poolman poolman is offline
Mein Auto: 525i station wagon
Noticing something as cold weather hit's around here--the PVC valve needs to be cleaned from time to time--I think the cold has something to do with more build up--I spray throttlebody cleaner trough the PVC while the car idle's--quick way to clean it out--
Old 01-27-2013, 01:17 PM
eparayno's Avatar
The PCV valve does restrict the vacuum. I hope you got all this sorted out.
Old 01-27-2013, 02:21 PM
I reversed the PCV valve and things seem better now. If I leave it at idle for a few minutes and then remove the oil fill cap some pressure does release, are you having the same thing occur? Vacuum present in the valve cover?
Old 01-27-2013, 03:43 PM
moots's Avatar
moots moots is offline
wat's dat noise
Mein Auto: '97 528i
there shouldn't be any pressure release when the oil filler cap is removed.if there is then the vacuum is not doing what it's supposed to.we need vacuum in the crankcase where the blowby gases is pulled up and out via the valve cover and into the intake manifold ti be reburnt.of crs this has to go thru the ccv.....or the pcv in yr case.
pls ensure you do not have pressure on the valve cover or something will blow eventually....
Fuelly
Old 01-27-2013, 04:03 PM
I misspoke, I should have said when I remove the oil fill cap I have a vacuum release- the valve cover is under negative pressure not positive.
Old 01-27-2013, 04:12 PM
moots's Avatar
wat's dat noise
Mein Auto: '97 528i
Fuelly
Old 01-27-2013, 04:35 PM
Just took a drive, oil is blowing out of the valve cover on the side and front of the engine.
Old 01-28-2013, 12:42 AM
luminmiller luminmiller is offline
Mein Auto: 530 In The Works
Time for a new valve cover gasket. Cheap and quick replacement.
Old 01-28-2013, 07:58 AM
I ordered a new vcg, i am just concerned i will blow it again with too mich vacuum.
Old 01-28-2013, 08:25 AM
The new VCG will be soft and flexible compared to the old one.
As long as you have the PVC installed correctly now and add sealant in the correct locations you will be fine. These engines can handle a pretty significant amount of vaccuum.
Old 01-28-2013, 05:16 PM
Took the valve cover off, gasket was like plastic. I will reassemble tomorrow and try again, I still am leary of the amount of vacuum that is being applied to the valve cover/engine, maybe I will try another PCV valve, that matches the one posted here.
Old 01-29-2013, 06:58 AM
coletrain777 coletrain777 is offline
Mein Auto: 528i
So...
I have read this thread several times and think this is a great idea! My question is... What is the exact routing of the hoses? I see that the line coming off of the front of the valve cover goes into the bottom inlet on the catch can, then the top line (which contains the PCV) goes down and under the intake... but what does it connect to? Are these the only two lines? I know that the dipstick vacuum port needs to be plugged, but does anything else need to be capped/plugged? I am ready to go to town to get the needed parts, just wanting to know the exact line routing setup to ensure that I have everything that I need. Thanks so much...
Old 01-30-2013, 09:59 AM
This is not my video- but it is the same vacuum that I am seeing in my valve cover upon release of the filler cap.
Are you guys having the same?
Old 01-31-2013, 07:41 AM
Mein Auto: 528i
Hose routing help please !!!
Old 01-31-2013, 09:06 AM
Connects to the same spot the CCV did............ Not sure how to explain it more?
Old 01-31-2013, 05:42 PM
champaign777's Avatar
Mein Auto: 2010 550i M Sport
re-read entire post
dump !
Why not to use the best of OE BMW CCV and just implement what was suggested by our GURU CNN long time ago
THIS :
If the Intake Manifold sits above the Valve Cover, then the design is simple.
Reuse OE CCV + implement CNN suggestion to have Manifold above the Valve Cover by another connector from Valve Cover to Manifold
You will have the best of both , - no oil coming into CCV due to U-turn and right vacuum pressure designed by BMW !
I would first try this SIMPLE solution before anything else !!
E39 4 ever
M54 GARAGE SALE
2003 530i 107k miles for SALE
Old 02-01-2013, 09:51 AM
Jason5driver's Avatar
Jason5driver Jason5driver is online now
Originally Posted by champaign777 View Post
re-read entire post
dump !
THIS :
You could accomplish what you are proposing by simply adding a Check-Valve at the hose from the Valve Cover, to the CCV.
