E36 (1991 - 1999)
Old 01-22-2013, 08:12 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
The plug you have is broken. As said above it should have quite a few more threads. At this point, you're best to drop the oil pan, make CERTAIN that the loose piece isn't broken off and rattling around in there, then see if a shp can either helicoil your current pan, or at least tap it then match the new threads with a new drain plug.
The Evolution of a Lady
“This is the fast lane, folks...and some of us like it here.”
--Hunter S. Thompson
Member of the Non-M Bumper By Choice Club
Old 01-22-2013, 08:23 PM
yxd0018 yxd0018 is offline
Send a message via MSN to yxd0018 Send a message via Skype™ to yxd0018
Mein Auto: 328i
saw the other thread about leaking oil due to whacked thread on the oil pan. I don't know if the thread on my oil pan is screwed up.
http://www.bimmerfest.com/forums/sho...d.php?t=438499
Old 01-22-2013, 08:24 PM
jonesin's Avatar
The Canadian Prick.
Or don't listen. Your call.
Old 01-22-2013, 10:21 PM
ZeGerman's Avatar
ZeGerman ZeGerman is offline
Warm Leatherette
Mein Auto: 1998 BMW 328is
This guy... A bit dense.
1998 BMW 328is
1966 Pontiac GTO
Old 01-23-2013, 10:36 AM
john kaminski john kaminski is offline
Mein Auto: 1994 325i
You definitly are missing part of the drain plug and it is trash. Hope some of that didn't get to your oil pump causing the noise on start up. Check the threads in the oil pan for damage. You may need to run a tap through the tthreads to clean them up. You may try to bend a wire and fish it through the hole and seeif you can pull back any metal from the plug or maybe get a small magnet in there. When I ran a tap to clean up my threads I poured back my old oil and let it drain through to clean out any metal from the tap. Also look at your oil filter carefully for any metal that might have been pumped to it. Good Luck.
Cheap Trick
Old 01-23-2013, 12:56 PM
Mein Auto: 328i
OMG, the mechanic said to take out oil pan, he has to lift the engine and labor cost $600. The oil pan itself cost another $600. Luckly the broken screw is still in the hole and mechanic is able to get it out. I'm surprise with part of hole blocked, the oil comes out smoothly.
I was stupid to pay $85 to get a computer code reading. I heard from the board that autozone gives a free reading? My previous shop at jersey city doesn't charge for code reading but I was not thinking straight. After all, he only charge $10 to get broken screw out and I gonna reuse the original oil.
However, since there is some oil leakage, my o2 sensor is not activated. Here are the codes: 233,234,222,50,209,212,216. Where can I find more info about each code and implication?
Mechanic will charge 1hr labor to clean the oil first then try to find leakage. Is it reasonable? He said it's a must but I'm not sure.
Old 01-23-2013, 01:04 PM
jonesin's Avatar
The Canadian Prick.
http://www.pelicanparts.com/bmw/tech...Pan-Gasket.htm
You do NOT have to lift the engine, you do however, need to remove the front suspension.
Old 01-23-2013, 03:08 PM
Hectorml07's Avatar
Hectorml07 Hectorml07 is offline
WYKDBMR
Mein Auto: BMW E36
Wow! Mechanics these days! I changed my oil pan a while back myself and it only cost me around $80 that was for new oil and used oil pan I took off from a car at the junk yard...my neighbor lent me an engine hoist so I lucked out. Good thing he is gonna be able to take it out though.
Autozone does not let anyone rent their scanners or check codes for free anymore. I tried yesterday and they said they didn't do that anymore. However, pepboys does it for free . As far as the codes have u tried Google to search them??
WYKDBMR
Old 01-23-2013, 03:23 PM
ZeGerman's Avatar
Warm Leatherette
If the mechanic can safely extract the remainder of the bolt with the pan installed, why would he need to remove and/or replace the pan? Once the plug is out, couldn't you just use a helicoil to fix any damaged threads and go from there?
1998 BMW 328is
1966 Pontiac GTO
Old 01-23-2013, 03:27 PM
E36 Phantom's Avatar
E36 Phantom E36 Phantom is online now
King of the Ballers
Mein Auto: Dreier, Fünfer & Siebener
That's a CA thing, AutoZone does still do it in other states from what I hear.
And personally I'd rather rent an engine hoist for $30 and lift it off the mounts a bit than disassembling the suspension.
Edit, Karl, I think we're talking hypotheticals here. His mechanic just told him that's what it would have been if he hadn't been able to extract. Common psychological trick so people feel like if he wasn't such a great and honest mechanic they would have really paid a ton elsewhere, and thus they're more likely to bend over without lube for the future rapage that will follow, without questioning if it's really the best and most efficient solution because they feel he's a great guy.
Sent from my LG Revolution 4G using BimmerApp
Chad // 2001 BMW 740i M-Sport // 2000 BMW 540i Sport // 1997 BMW 328i Premium //
E38 16" Style 5 Basketweaves, M52 Parts, and New Gaskets/Seals for Sale!! PM for info. .
Originally Posted by SlimKlim View Post
You're a derbanana
Old 01-23-2013, 03:28 PM
petriej's Avatar
petriej petriej is offline
Cruising 280 Top Down
Send a message via Skype™ to petriej
This.
GGC BMW CCA #443004
Join the BMW CCA!
Originally Posted by EnserioJose View Post
Sorry. I'd imagine Seattle is a-hella-nother country.
2005 X5 4.8is Le Mans/Black/6spd Steptragic
1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012
2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011
Old 01-23-2013, 03:55 PM
Mein Auto: 328i
after plugging new drain plug, the engine noise happened once at the start. Will closely monitor it now.
Old 01-24-2013, 02:39 PM
Mein Auto: 328i
Heard the scanner in autozone can only read part of code. The full scanner cost 10k+.
Argued with boss but he changed the item description. Now he said it took mechanic 1 hr to get things done so he will charge 1 hr labor. I guess there is a life charge to maintain profit margin. But I won't pay for the oil cleaning labor to find the leak under the car. What do you guys think?
Old 01-24-2013, 03:11 PM
B1MM3R's Avatar
B1MM3R B1MM3R is online now
Jesse Moon Bayne
Mein Auto: '93 ///S50 powr'd 318is
Yea in va its still free.
And I think thats how im going to do the oil pan gasket when I do it, alot less work IMO.
Jesse
Part out.
http://bimmerfest.com/forums/showthr...67#post7418867
"Cassie"///Mpowered 93 318is 5speed (95 m3 swap).Vaders..Bavauto short shifter..dinan cat back..sways..3.23lsd..tms chip..staggered dsII's...BCracing coilovers..F&R strut tower bar...M3 brakes..x-brace..AFE CAI
Stock 2004 X5 3.0i (Wifes)
E30 87 325e
Old 01-27-2013, 12:46 PM
Mein Auto: 328i
I've oil changed every 5k miles with 5w-30 full synthetic oil ($35 for 7 qt). It usually last a year since we don't drive a lot. After reading pelican's article about oil change and I'd like to know if I should switch to 5w-30 walmart super tech conventional oil ($15 for 7qt) at every 3k miles or use full synthetic every 3k miles? Mechanic told me that even synth oil can last longer, it's cheaper insurance to change often. I also heard BMW can develop issue with conventional oil.
I have 2.5 qt full synthetic left, I should NOT mix with conventional oil in the next oil change, right?
Old 01-27-2013, 01:04 PM
Nicky3 Nicky3 is offline
Mein Auto: 96 328is
You heard wrong! Conventional oil is fine, especially with 3k OCI's. Thats what was in the car when it was made. And, what is the purpose of using synthetic oil and changing it every 3k miles? You didnt want to buy a new oil drain plug but now you want to pay for a synthetic oil change every 3k miles? Someone please help me out?
Old 01-27-2013, 01:33 PM
jonesin's Avatar
The Canadian Prick.
Dino oil is fine, synthetic oil is better. Synthetic wasn't used originally because in the 90s it simply wasn't as prevalent as today.
OP, if you go with synthetic, changes every 5000 miles is perfectly fine.
Ed.
Sent from my U8651T using Bimmer App
Old 01-27-2013, 04:01 PM
Mein Auto: 328i
Thanks, I will stay with synth for every 5k miles.
