BMW Coding and Programming
Discuss coding options and features on your BMW here. |
#76
check the attached file. Now i´m waitng for the second part of the vin. Regards 160D-35160-0127(28)EEP(PPPPPPP).BIN.pdf |
#77
i´m thinking in the next steps
Could some body help me with this: Quote:
Regards Last edited by mateforrest; 01-27-2013 at 08:49 AM. |
#78
Thanks to all people; and **** the bmw coding mafia!!
#79
Amen to that.
![]() - 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC - 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11) - BMWCCA #446923 - flickr® |
#80
The first priority is to clean up the VIN and make the KOMBI working with your car ![]() I realized that the KOMBI was on a F01 car. Do you believe it will be working with your F10? |
#81
F01: Detalles de F01 F01 730d Limusina, Europa F01 740d Limusina, Europa F01 740dX Limusina, Europa F01N: Detalles de F01N F01N 730d Limusina, Europa F01N 730dX Limusina, Europa F01N 740d Limusina, Europa F01N 740dX Limusina, Europa F01N 750dX Limusina, Europa F02: Detalles de F02 F02 730Ld Limusina, Europa F02N: Detalles de F02N F02N 730Ld Limusina, Europa F02N 750LdX Limusina, Europa F06: Detalles de F06 F06 640d Gran Coupé, Europa F07: Detalles de F07 F07 530d Gran Turismo, Europa F07 530dX Gran Turismo, Europa F07 535d Gran Turismo, Europa F07 520d Gran Turismo, Europa F07 530d 155kW Gran Turismo, Europa F07 535dX Gran Turismo, Europa F10: Detalles de F10 F10 520d Limusina, Europa F10 520d ed Limusina, Europa F10 525d Limusina, Europa F10 525dX Limusina, Europa F10 530d Limusina, Europa F10 530dX Limusina, Europa F10 530i Limusina, Europa F10 535d Limusina, Europa F10 535dX Limusina, Europa F10 M550dX Limusina, Europa F11: Detalles de F11 F11 520d Touring, Europa F11 525d Touring, Europa F11 525dX Touring, Europa F11 530d Touring, Europa F11 530dX Touring, Europa F11 535d Touring, Europa F11 535dX Touring, Europa F11 M550dX Touring, Europa F12: Detalles de F12 F12 640d Cabrio, Europa F12 640dX Cabrio, Europa F13: Detalles de F13 F13 640d Coupe, Europa F13 640dX Coupe, Europa |
#82
Ok i have change to FF the two memory address, the short and long vin.
But how to continue?... Before install it could some one tell me how to use the tool 32 software? Regards |
#83
I am not sure you need Tool32. If you install in car, add 6WA to VO, and VO Code KOMBI, it may take VIN at that time.
#84
Ok tomorrow i will try. But, what do you think about the set to FF the two memory addresses ? Thanks |
#86
Shawn, is there a need to ensure the production date is set to a certain timeframe?? I am not sure about this, but just checking.
#87
If it was me, I would blank the Short VIN too , but maybe the short VIM comes from the Long VIN, so when it is powered up and coded, it could be the Short VIN updates to match.
#88
Regards |
#89
I think 6WA became available with HUD beginning 0311, so I think to VO Code KOMBI with 6WA, the Production dates needs to be >=0311.
#90
So did the VO coding do the trick?
#91
no works.......
![]() It's to late, tomorrow more info |
#92
I think is impossible, i don´t know what can i do.
i erased the vin, but it does not work. ![]() my advice is not buy a used Speedometer still. Regards |
#93
@hamfei, any ideas? What Tool32 .prg may work?
#94
Shawn Thanks million for all your help.
This is the proof of vin erased: No CAFD. And this problem: com.bmw.esys.domain.psdz.PsdzException: Failed to get CAFs for SWE "swfl_000003c1-004_054_006". [C111] at com.bmw.esys.domain.psdz.Psdz.getCafsForSWE(Psdz.j ava:2088) at com.bmw.esys.domain.svt.SvtLogic.getCAFsForSWE(Svt Logic.java:395) at com.bmw.esys.gui.svt.SvtCompareController.callActi onGetCafsForSWE(SvtCompareController.java:695) at com.bmw.esys.gui.svt.SvtTargetView$ActionGetCAFFor SWE.doActionPerformed(SvtTargetView.java:549) at com.bmw.esys.gui.AbstractView$AbstractGuiProgressA ction$1.init(AbstractView.java:389) at com.bmw.esys.gui.component.DialogProgress$2.constr uct(DialogProgress.java:136) at com.bmw.esys.gui.component.SwingWorker$2.run(Swing Worker.java:145) at java.lang.Thread.run(Unknown Source) Caused by: KIS error: Die technische Einheit 000003C1 konnte in der KIS-Wissensbasis nicht gefunden werden. Timestamp: Thu Jan 31 23:32:05 CET 2013 SessionId: default ErrorCategory: SYSTEM_ERROR ID: 1283 Class: com.bmw.psdz.uc.LogicImpl ExecutionContext={category=KIS, ecuid=(UNKNOWN,?)} at com.bmw.psdz.uc.LogicImpl.getCAFsForSWE(LogicImpl. java:1173) at com.bmw.esys.domain.psdz.Psdz.getCafsForSWE(Psdz.j ava:2085) ... 7 more Please friends, any advice? |
#95
This is a good start.
The VIN is showed as 00 but i'm not sure if it's correct. To me, a empty VIN should be all FF. Maybe you emptied them in a wrong way... If you have already written FF, you may consider recording the new VIN by using Tool32. Go to Tool32, load KOMBI??.prg (i've uploaded komb01.prg coming with the ecu folder of F10 data files), then, you will see the command as c_fg_xxxx. First, try c_fg_lesen to see if you can read the VIN out. It should be showed as all FF. Then, use the command c_fg_schreiben to write the VIN back. Note that you need to input a 18 bit VIN which means an additional checksum bit after the normal 17bit VIN. I hope the above steps help. Good luck! |
#96
Hamfei, how can i calculate the checksum bit?
Regards |
#97
You should be able to find it from the vo file. In E platform, you can read VO through NCS and get the 18 bit VIN. I have no idea about F platform in E-SYS. Maybe you should check the VO xml file...
#98
Hamfei, with my actual Kombi could i do this? c_fg_lesen to see if you can read the VIN ? with this i supouse that i can see the VIn 18 bit. is correct?
#99
I have a Checksum calculator. I will upload and send you a link in a few minutes as soon as I locate it.
#100
Ok. I have PM'd you the link. Good luck!
