Old 01-24-2013, 10:20 AM
mlandry1 mlandry1 is offline
Mein Auto: 2001 325i
bad smell
just a little about my problem(e46 2001 325i) after taking long drives anything over 45 minutes there is a distinct burning smell (although hard to describe). The Valve cover casket and oil seperator were replaced just last year so I am ruling this out. There is no visible smoke coming from engine.....this smell has been noticeable for about 6 months now and I realize I can't ignore it much longer. I am in the dead of winter right now and will have to wait a couple of months b4 doing any work If anyone has any ideas as to what my problem might be I would appreciate any help thxs
Old 01-24-2013, 11:45 AM
SixPotPsyco SixPotPsyco is offline
Mein Auto: 320i se
Hi. I have heard the most common cause of a burning smell is oil leaking from the rocker cover. I wouldnt rule this out even though you say it was done. I have the same problem. On a long drive after stopping the front of the car really pongs of burning oil and I do have to top up about a half litre every 6 weeks. Im assuming a leak somewhere, and as Ive got no oil stains on the drive where I park I guess its seeping out somewhere onto something hot and burning off. From the info Ive read on here seems its most likely a leak around the top of the engine. Like yourself got bad weather here at moment, 6-8 inches of snow and minus 10 most nights.....its the UK lol so finding the time to get it sorted is tough right now. I would advise investigating this and if your topping up the oil like me then its certainly a leak somewhere. Dont ever assume a new part can be ruled out of any fault finding procedure. Also keep on searching the forums.....this site is invaluable for great advice. Good luck and keep us updated.
Old 01-24-2013, 03:21 PM
JKRIT JKRIT is offline
Mein Auto: '03 525i
+1 on valve cover gasket. I had one leak only 8 months after installing it during a vanos rebuild. Bad brand, I guess, although I can't remember which. When the engine is not too hot, feel for oil on the head above exhaust manifold ports 4-6.
Old 01-24-2013, 05:38 PM
Solidjake's Avatar
Solidjake Solidjake is offline
The one and only
Mein Auto: 2002 330i
Double check the VCG for sure. It can leak with the slightest gap.
_______________Going to Bimmerfest East AND West
Youtube - Electric Fan Swap/Aux Fan Removal - Projector Retrofit - E46 Bulb Guide
Old 01-24-2013, 10:09 PM
Generally it's oil seeping onto the hot exhaust.
Look there first (passenger side of the engine).
Old 01-27-2013, 02:27 PM
thank you all for quick response soon as weather warms up a bit will check out oil problems will keep all updated thanks again
