Old 01-27-2013, 10:44 AM
jcard412 jcard412 is offline
Mein Auto: BMW Z3
Ignition key warning sound
2000. Z3. 2.3
The warning chime that sounds when leaving the key in the ignition (when the door is open) no longer works.
Any suggestions on fixing this?
Thanks for any help.
Old 01-27-2013, 03:15 PM
Blacklane Blacklane is online now
Mein Auto: 1998 Z3 Roadster
It could be a defective or disconnected warning chime. It's mounted next to the driver's knee on the side of the center console. I seem to recall that you can reach the connector through the shifter boot hole for the manual transmission. It also does the headlight warning, so if that is inoperable, I would suspect the warning chime.
Old 01-27-2013, 03:33 PM
Mein Auto: BMW Z3
Thanks Blacklane
I'll check it out
