E34 (1989 - 1995)
again, lighting issue
so last night I notice..
Neither my fog lights, nor my high beams work, fuses look great what could eb the issue? the lkm? |
Yes, the LKM would be suspect.
Steve Calypso Red 1992 525i with 170K miles 1991 735i - Sold 1992 525i - Sold 1995 325is - Sold 2000 528i - Sold
![]() 1995 525iA 250k mi Shifted Performance E34 2006 325i/6 48k mi 2003 350Z 87k mi Shifted Performance 350Z Garden State Euros |
TRy contacts, plugs and earths first. You might strike lucky.
seems a little tooooo coincidental to be a poor ground
used friends lkm, and it did not work.
I know his high beams and fog lights work, as mine worked in his.. |
try grounds. check wiring. i know that the wires to the lights are thin and can be worn and frayed by road debris.
Grounds? ROFL!!! Try all the plus and wires, as per my first post. Relays, sockets and connections. Isn't this where I came in? still ROFL!!
UGh, so..
I had one bad high beam bulb, changed it and everything works. |
great that you solved this. the fog lights dont turn on unless the headlights are on so that makes sense. but seems strange that the other headlight died when the bulb on the other side went out.
I agree, one dead bulb shouldn't take out the whole lighting circuit unless there is a ground off.
I discovered I scream the same way whether I'm about to be eaten by a great white shark or if a piece of seaweed touches my foot. |
GROUNDS !!!!! Woo hoo !!!!!! STILL rofl !!!!!
You are certainly a very well grounded individual FF
Not all of my friends would agree with you, but thanks!
I should have mentioned that the pun was intended
I need all the compliments I can get, intended or not!!
On ya
