rear hub-inner race - Bimmerfest - BMW Forums
Old 01-27-2013, 05:18 PM
firehawk17 firehawk17 is offline
Mein Auto: 97 528i
rear hub-inner race
simple quick question about replacing the rear hub...i got the write ups on the procedures and everything im ok with that.... im stuck on the inner race part..not on how to remove it but I wanna know is there a new inner race already installed in the new bearing or is that a separate piece that needs to be bought? thanks in advance
Old 01-27-2013, 06:49 PM
pleiades pleiades is offline
Mein Auto: '99 5-spd
Bearings have an inner and outer race between which the balls are sandwiched. The inner is the steel jacket forming the bearing's inner bore. Because it's typically press-fit onto something (the flange) it gets mangled and "peels" off with the hub flange when you remove the bearing from the flange with a puller or splitter or other methods. It's not a "part" per se, more like metal scrap that's in the way and has to be removed before you can install a new bearing on the flange.
Old 01-29-2013, 11:42 AM
Mein Auto: 97 528i
ok cool.. i didn't wanna be stuck at that junction...thanks a lot for your response..
Old 01-29-2013, 12:38 PM
cn90 cn90 is offline
I explained the whole thing in the REAR bearing DIY:
http://www.bimmerfest.com/forums/sho...d.php?t=566786
Take your time to go through the 1st photo.
Old 01-29-2013, 01:12 PM
Mein Auto: 97 528i
yes your DIY is what i've been reading and looking over many many times..lol im sure i'll look it over again before i actually do it.. but i just wanted to be sure on the inner race part.. but seems all is clear now guess its more studying before the final..
Old 01-29-2013, 04:08 PM
Look at the drawing carefully as if you are an engineer, then it will be clear to you that the hub is mated to the INNER race, which consists of 2 separate parts (1a and 1b) in the photo.
The "1b" part comes out with the hub. This "1b" part needs to be removed.
When you get the new bearing, look at it, the only thing that prevents the Inner race from falling out is the seal! The inner lip of the seal hugs around the Inner Race, preventing it from falling off.
Once installed, the force of the Axle Nut will clamp the hub against the Inner Race then against the very edge of the half-shaft. It is like a sandwich.
I will give you a multiple-choice exam later to make sure you know the stuff lol.
PM me your cell number and time/date you plan to do it. This way if you run into problems, you can call me for online help.
Old 01-29-2013, 07:36 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
FTW Trump 2020!
Mein Auto: 2001 540i/6
Here is my epic journey of changing e rear wheel bearings.
http://forums.bimmerforums.com/forum....php?t=1835577
Fronts took an hour, rear took a whole day each they were so stuck.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
