Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - E38 (1995 - 2001)
Old 01-23-2013, 06:22 PM
rtgm1 rtgm1 is offline
Mein Auto: 2001 740il
soft close trunk issues
i have a 2001 740il that the trunk appears to be dead. The button wont open it either. I have to use the key. The sunroof is doing strange things too. All the fuses check out. Is this a GM or other module problem?
Old 01-23-2013, 10:04 PM
setconstr setconstr is online now
Mein Auto: 2001 740i sport 2006 m6
Re:
Try re-programing your key.......
2001 740i sport, Dinan upgrades, Bilstein's & H&R 2's , Zimmerman vented rotors, Akebono pads, HID fogs, BSW speakers and subwolfer, MKIV nav, Alpina Lip, OEM clear lights, 3m carbon fiber interior wood delete, 20" BBS, Fast enough for me
Old 01-26-2013, 04:23 AM
BMWFatherFigure's Avatar
Old School
Mein Auto: E23;E30;E38;R50;R55
Check for damaged earths and plugs.
Current:
Previous:
Old 01-26-2013, 05:22 AM
bmwoem1 bmwoem1 is offline
Regional Sponsor
Mein Auto: X3
Check the rubber grommet at the hinges... The wires fatigue after time and break or short circuit
Old 01-27-2013, 02:39 AM
Old School
Are the earths for the soft close and roof motor both in the boot (sorry Trunk)? It could be the common point.
Current:
Previous:
Old 01-27-2013, 11:50 AM
It takes five minutes to test, so, I'd first physically check the trunk / boot wire harness:
- How not to repair your bimmer trunk wiring loom (1) [ how to do it right (1) ]
Old 01-27-2013, 06:54 PM
Old School
Sort of like I said, wires, earth points and connectors. Repair wires with solder joints and shrink sleeve.
Current:
Previous:
Old 04-21-2013, 07:12 PM
tmmj918 tmmj918 is offline
Mein Auto: 2001 740i, 1991 318i
E38 soft close
Thanks for the advise, it works. I had a battery go dead and of course had the trunk opened to make the change, but now we are back in action.
HTML code is Off
