Old 01-27-2013, 08:19 PM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
knocking on 89 gas
Guys, I've been running 89 in my car since I bought it. Rattles somewhat depending on throttle. I have done just about every tune up item possible. Plugs, CCV system, O2's, cooling system, fuel filter, DISA valve. What else in gods name can be causing it? I thought the car has a Knock sensor and 89 under "normal" conditions would be ok. If I run 93 it goes away. I know the answer I'm going to get... run 91+. but a stock car like this under a watchful eye and in great shape should run on 89 w/out rattle. Is my Knock sensor bad? No CEL.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
Old 01-27-2013, 08:31 PM
Andreas540i's Avatar
Andreas540i Andreas540i is offline
Mein Auto: 1997 BMW 540i
Its tuned to run 91+ by running 89 it will probably have knock. The guys at BMW know what their doing. They tuned it for 91+ because they can get more power from it. If you really MUST run 89, you could try calling dinan or another tuning company and get it tuned for 89. The cost for manufactured tunes from them are 300+, so if you are trying to save costs it will be cheaper to run 91 than to keep modding to try to get it to run 89. If you live in a place where 91 is not available, might still be cheaper to buy your own gas tank and have 91 delivered to your driveway.
1997 BMW 540i
Old 01-27-2013, 08:36 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
What does the gas cap say? There s/b a minimum octane listed.
Old 01-27-2013, 09:07 PM
my boss doesn't like paying for 91. When I'm "persoanlly" driving 93. business 89. I've run my 335i on 89. no knock. I just don't romp it.
Old 01-27-2013, 09:46 PM
champaign777's Avatar
try kerosin
its cheaper
Old 01-27-2013, 09:58 PM
Mein Auto: 1999 740i
Not sure what the I-6 comppresion ratio is but im assumming its around the same as the V-8's. With a 10:1 compression ratio you need to run Super unleaded, or add an octane booster/anti knock additive.
Old 01-28-2013, 06:12 AM
tmvE39/E53/Z32's Avatar
Mein Auto: Dinan //M5, Dinan 4.8iS,
Pay for the difference when using it for business. It's your car after all. The difference should be about $5 ea tank.
2000 Dinan S1 //M5 (my DD), 06 DINAN E53 4.8iS (wife's DD), 90 Straman Z32TT (my pride & joy ride)
Gone, but not forgotten: 01 E53 3.0i, 01 525i Sport, 03 DINAN 540i MSport, 01 //M5 and 91 Z32TT
Old 01-28-2013, 06:21 AM
DHoang's Avatar
DHoang DHoang is offline
Gearhead
Mein Auto: '98 528i, '82 323i
Something's wrong w/ your car if you can't run 87 oct. w/o it knocking.
My car runs perfectly fine on regular gas 87 oct.
i think you're right w/ suspecting that your knock sensor is not working right.
It's supposed to detect knock and send a signal to the computer so the computer can retard the ignition to prevent knocking.
http://www.bimmerfest.com/forums/picture.php?albumid=4132&pictureid=24642
Old 01-28-2013, 06:35 AM
FiveDriver's Avatar
FiveDriver FiveDriver is offline
Mein Auto: 1999 528i Blue/Tan
The difference in price per gallon around here is .20 cents, at most. On a 15 gallon fill-up -- that's $3. On top of a $50 transaction.
My car runs much better on Super. You might be able to get away with 89 octane in warmer weather, but is it worth it ?
I run Super and don't think twice about.
Old 01-28-2013, 07:24 AM
I still think there is something wrong with the knock sensor on 89. 87, ok fine.. yeah. but 89? eh... something is not right.
Old 01-28-2013, 07:57 AM
JimLev JimLev is offline
Mein Auto: 540/6, '16 Highlander XLE
Have you tried different brands of fuel?
2000 540/6 Slightly tweeked...everywhere
Old 01-28-2013, 08:02 AM
pshovest pshovest is offline
BMW CCA 69606
Mein Auto: '10 535i '08 X5 '00 528i
Ditto. I run 89 in (3) e39's year round without any difficulty or any audible knocking.
Perhaps noises are VANOS or exhaust rattle.
Old 01-28-2013, 08:15 AM
ninetyseven1 ninetyseven1 is offline
Mein Auto: 1997 540i
When I had a vacuum leak, it made the car knock. Check all hoses. Mine was the hoses that came off of the MAF boot and went to the front of the intake. There are like 3 hoses there.
Old 01-28-2013, 08:16 AM
a bad MAF could cause this too.
Old 01-28-2013, 08:17 AM
Unplug the MAF and drive it and see if you still hear knocks. Keep in mind though that when coming to a stop your car could stall out with a disconnected MAF sensor. Also, your traction control will not function.
Old 01-28-2013, 08:20 AM
Also, the knock sensor wiring corrodes. I unplugged one of mine from the black electrical box on the intake and looked inside the connector. There are four small wires inside the actual connector plug. I had 2 wires that were touching! The actual plastic insulation around the wires just plain corroded off! You will have to split the rubber boot on the connector plug with a razor blade to see inside it. Just tape it back up with electrical tape. It's worth a shot.
Old 01-28-2013, 08:23 AM
No vacuum leaks. I replaced all the vacuum hoses and MAF boots. I also spray carb cleaner around items with the engine idling (cold!) to verify. I need to look at the wiring going to the knock sensor. It's not VANOS noise... or exhaust. it's spark knock. I'm 100% sure. I know what it sounds like. I've been driving modified cars for 13yrs. Sounds the same in a V8 as it does in a TT Supra, as it dones in a junky Malibu. It's spark knock. But this new of a car (yes 2003 new) should adjust for 89 gas. Brands do not matter. I drive about 30-40k year. I get to try brands all over the Southeast. How many knock sensors does the M54 engine have? 1 or 2? Approx where is it?
Old 01-28-2013, 09:05 AM
manticore33's Avatar
manticore33 manticore33 is offline
Send a message via AIM to manticore33
Mein Auto: '86 Porsche 951, '01 530i
Why doesn't your boss do like most companies and reimburse you per mile? Ala, $.55/mile to cover your gas, insurance, vehicle maintenance, and wear.
I like coffee.
My e39 is fixed and moving towards atrophy.
Old 01-28-2013, 10:11 AM
^I've done that too. It's a deal thing I have worked out. The car should run fine on 89 as long as I'm not romping it. my 335i does and it's TT. I need to at least make sure the knock sensor is good and the wiring is not shot.
Old 01-28-2013, 02:53 PM
check th knock sensor wiring,it's prob not maf wiring
Old 02-01-2013, 08:25 PM
I will never understand; especially on an FI car.
I like coffee.
