E90/E91/E92/E93 (2006 - 2013)
#51
Great write up. Oil changes are about all I feel comfortable doing nowadays. I miss lying on the driveway trying to replace a clutch in sub-freezing weather.....ummmmm maybe not.
#52
Great post!
I'm surprised the filter looked so worn... |
#54
I told him to keep it if he saw anything I should look at so I didn't get to see it. He did say it was darker than it should be for 1200 miles and it was good I changed it.
2011 335i Sedan/Space Gray/M Package |
#55
I will have my oil sent to analysis to see if they find anything.
#56
Let me know how those results come back.
#57
Good oil often gets dark quickly, it's doing its job and cleaning up the carbon and other guck. Color doesn't tell you the oil is bad unless it's milky or other than amber.
I thought I'd add a couple of notes:
The socket for the oil drain plug is 17 mm. The drain plug goes back in at 18 ft-lbs which is about 215 in-lbs or about 24 N-m. (This is such a low torque, you can probably only find a 1/4" torque wrench that will work well.) The Tischer oil filter wrench (the big silver cap) uses a 27 mm socket. (Which is quite large, btw. You may not have one.) And here are the manual pages that cover how to check oil level after you're done.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW Last edited by ProfessorCook; 03-21-2012 at 09:48 AM. |
#59
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion |
#60
Excellent DIY and well illustrated, but if I lived close to DSX I'd let him do it...quite a messy job with too many "O ring" technicalities IMO. DSX's capable technicians could handle the job as I chatted with him in the waiting room and passed haggis recipes to the Englishman and recommend unique ingredients -- The English will eventually get the taste of it. Images of rubber gloves always frighten me as I have a particularly aggressive Urologist. He should have been more sensitive about these issues.
Black Sapphire Met., Black Dakota Lthr., PP, Moonroof, convenient electronic "dip stick," Steptronic. ------------------------------------------------------------------------ E90 328i E92 335i 6MT E46 M3 6MT E39 528i 5MT MBz W140 S320 MBz W124 300E (slammed) (unmentionables in between) '71 AMC Javelin (4-Spd Stick on the floor) '67 Pontiac Firebird 'cabrio' (1st car - "the leaker") ------------------------------------------------------------------------ Member: BMW CCA |
#61
If your doctor is using gloves like those, you need to find a new doctor.
Guys over 40, if you don't have a doctor give you a DRE and check your PSA every year, you could be making a huge mistake. Trust me on this one. The O rings are easy. Doing the job yourself is satisfying. Having a cold one after is pleasant. Reserve the talents of a guy like DSX for jobs more demanding of his considerable talents.
'09 328i Coupe: MT, Monaco Blue, Black Dakota, Dark Burl, ZPP, ZSP, ZCW, CA, Logic7, HD Radio, IPod Ordered: 14Jan09; Delivered: 24Feb09 from Stratham, NH BMW |
#62
'12 E92 335is |
#63
Interns and MD's are bad enough... I don't care if DSX is qualified, he's not checking my personal exhaust!
(Man has this thread gone downhill in a hurry.)
#64
(Downhill and picking up speed. )
2011 335xi Individual 6MT - Azurite Black Metallic / Oyster & Black / Anthracite Maple + all the good stuff N47° 35' 30.13" E11° 10' 33.36" - End of break-in period. You can guess the rest. BMW CCA
#65
Reported to the significant figure police.
#66
![]() And since the dealer's service coupons and my oil changes never seem to agree on dates, we have settled for a straight $88 charge for oil service only.
-Brian "Used cars are our entry cars." - Luca di Montezemolo Last edited by Bcube; 03-22-2012 at 11:56 AM. |
#67
Hey, didn't we have this dance in this thread? http://www.bimmerfest.com/forums/sho...d.php?t=608007
Posts 14 -> 22.
2009 335i xDrive coupe, Jet Black, Black Leather, Grey Poplar, Steptronic, ZPP, ZSP, ZCW, iPod/USB, HD radio, Parking Assist. Rear Fogs, Hardwire V1, ProFit G3. ED May 12, 2009, Munich dropoff May 16, Redelivery June 22, 2009 Prior 33 years of cars: 1967 BelAir wagon / 1968 LeMans Tempest / 1970 Mustang Mach 1 / 1972 El Dorado / 1978 Corvette (kept until first Bronco) / 1981 Subaru GL wagon AWD / 1983 s10 Blazer 4x4 (big mistake) / 1985 Bronco 4x4 / 1996 Bronco 4x4 / 2004 Passat 4motion Last edited by Zooks527; 03-22-2012 at 12:37 PM. |
#68
1/29/2013 UPDATE: The above feed was excellent in helping me do my first oil change on my 2011 328xi. I would like to add some things.
(1). Jacking up the car was the most difficult part of it(and it was not bad at all). I recommend using a wood block on the jack(esp for the rear) and for the jack stands. The points on the car for jacking are square and plastic, the the rear had no specific jack point, so I used the frame. This required the wood block as the car is so low. (2). The washer indeed was stuck to the oil pan and needed some gentle persuasion with a small screwdriver. (3). The drain plug is 17mm. (4). The car drained 6 quarts and took the same amount of oil(mobile 5-30W). (5). The car had 7500 miles, but the oil was "mud" like. I couln't imagine waiting for the prescribed 15,000 mile change. |
