Old 01-28-2013, 05:39 AM
dcocke dcocke is offline
Mein Auto: 2000 z3 2.3
z3 cruise control
I have a 2000 z3 without cruise control. Can cruise be added . If so, what type of business would do this? THX
Old 01-28-2013, 08:01 AM
Blacklane Blacklane is online now
Mein Auto: 1998 Z3 Roadster
RealOEM.com has a break-out of all of the OEM Cruise Control components. You could buy all of those and have them installed, but it looks pretty expensive.
I have added aftermarket cruise control kits to several cars and they work just fine. There are many choices available.
You can do the work yourself or have an independent shop do the work. If you buy an aftermarket kit, it will come with compete instructions.
If you really like the OEM cruise control stick on the side of the column, you can probably incorporate just that part.
For reference, the speed sensor wire to the speedometer is brown with a red stripe and is located on the small black connector on the back of the speedometer.
Old 01-28-2013, 08:18 AM
amancuso's Avatar
amancuso amancuso is offline
Send a message via AIM to amancuso
Mein Auto: 128i, 330i, Z3 2.3, R56
yes it can be done, you need the cruise control module and the cruise stalk.
Old 01-28-2013, 08:24 AM
bob lindquist's Avatar
bob lindquist bob lindquist is offline
A Clean Windshield
Mein Auto: 2000 Imola M Coupe
To be sure, Your car has only 2 stalks on the column correct?
2000 Imola Red M Coupe
Dinan suspension, M rotors /Axxis pads
Eurosport Cam Kit 1, touch lane change
Zaino polish, Beach Sand
Garys mirror adapter, S54 Oil Cooler
seat tilt coupling nuts, spare tire
"life's to short to drink cheap beer"
Old 01-28-2013, 09:30 AM
cruise
Yes, it has only 2 stalks
