Old 01-27-2013, 08:33 AM
mateforrest mateforrest is offline
Mein Auto: BMW F10 530D SILVER
Originally Posted by hamfei View Post
Ok, i've found that. It's on a different location.
Check from 0x7F, modify the data to FF until 0x8F. It stores the full VIN there.
I did this,
check the attached file.
Now i´m waitng for the second part of the vin.
Regards
160D-35160-0127(28)EEP(PPPPPPP).BIN.pdf
Old 01-27-2013, 08:41 AM
i´m thinking in the next steps
Could some body help me with this:
The procedure to reprogram a used KOMBI is
1. Use R270 to clear up the mileage (which is the purpose for R270) Ok
2. Modify the VIN bytes from the binary. Write the modified binary back to the EEPROM Ok but waiting for the information about secondary vin address
3. After doing the above steps, the CPU will treat itself as a brand new one.
Then, you connect the KOMBI to your car,
upgrade the program by using WINKFP Is this for Exx only or also is ok for Fxx, in this case where is WINKFP stored and how to use it
, write VIN by using Tool32 How to do this? i´m new with Tool32
and code it by using E-SYS Ok i know do this
I hope you can understand what i'm talking about. Enjoy!
I´m afraid about version of the this Speedometer, i don´t want to lose Entertainment list and Telephone contacts on HUD because Version less than 47.5
Regards
Old 01-27-2013, 01:07 PM
lycos lycos is offline
Mein Auto: 2007 e90
Originally Posted by shawnsheridan View Post
Only thanks to you and Lycos my friend.
Thanks to all people; and **** the bmw coding mafia!!
Old 01-27-2013, 01:17 PM
shawnsheridan's Avatar
Mein Auto: 2011 535i M-Sport
Amen to that.
- 2011 535i M-Sport (Born 10/10) - AW/BLK/DW - /ZMP (w/ARS & AD) /ZPP /ZP2 (w/ZPS & ZPT) /ZCV (w/SCAD) /6FL /6VC
- 2006 530i (Born 10/05) - SG/BLK/DW - /ZPP /ZCW /NAV (Returned to Mothership 05/11)
- BMWCCA #446923
- flick
Old 01-27-2013, 06:54 PM
hamfei hamfei is offline
Mein Auto: 2012 E90 CLI
Regards
I'm not sure but upgrading firmware would be a easy job.
The first priority is to clean up the VIN and make the KOMBI working with your car
I realized that the KOMBI was on a F01 car. Do you believe it will be working with your F10?
Old 01-28-2013, 01:56 AM
Yes Hamfei is the same for this models :
F01: Detalles de F01
F01 730d Limusina, Europa
F01 740d Limusina, Europa
F01 740dX Limusina, Europa
F01N: Detalles de F01N
F01N 730d Limusina, Europa
F01N 730dX Limusina, Europa
F01N 740d Limusina, Europa
F01N 740dX Limusina, Europa
F01N 750dX Limusina, Europa
F02: Detalles de F02
F02 730Ld Limusina, Europa
F02N: Detalles de F02N
F02N 730Ld Limusina, Europa
F02N 750LdX Limusina, Europa
F06: Detalles de F06
F06 640d Gran Coupé, Europa
F07: Detalles de F07
F07 530d Gran Turismo, Europa
F07 530dX Gran Turismo, Europa
F07 535d Gran Turismo, Europa
F07 520d Gran Turismo, Europa
F07 530d 155kW Gran Turismo, Europa
F07 535dX Gran Turismo, Europa
F10: Detalles de F10
F10 520d Limusina, Europa
F10 520d ed Limusina, Europa
F10 525d Limusina, Europa
F10 525dX Limusina, Europa
F10 530d Limusina, Europa
F10 530dX Limusina, Europa
F10 530i Limusina, Europa
F10 535d Limusina, Europa
F10 535dX Limusina, Europa
F10 M550dX Limusina, Europa
F11: Detalles de F11
F11 520d Touring, Europa
F11 525d Touring, Europa
F11 525dX Touring, Europa
F11 530d Touring, Europa
F11 530dX Touring, Europa
F11 535d Touring, Europa
F11 535dX Touring, Europa
F11 M550dX Touring, Europa
F12: Detalles de F12
F12 640d Cabrio, Europa
F12 640dX Cabrio, Europa
F13: Detalles de F13
F13 640d Coupe, Europa
F13 640dX Coupe, Europa
Old 01-28-2013, 01:58 AM
Ok i have change to FF the two memory address, the short and long vin.
But how to continue?...
Before install it could some one tell me how to use the tool 32 software?
Regards
Old 01-28-2013, 04:32 AM
Regards
I am not sure you need Tool32. If you install in car, add 6WA to VO, and VO Code KOMBI, it may take VIN at that time.
- BMWCCA #446923
- flick
Old 01-28-2013, 06:12 AM
Regards
Try Shawn's suggestion
Old 01-28-2013, 02:01 PM
Ok tomorrow i will try.
But, what do you think about the set to FF the two memory addresses ?
Old 01-28-2013, 02:07 PM
snj1013 snj1013 is offline
Mein Auto: 2011 528i
Shawn, is there a need to ensure the production date is set to a certain timeframe?? I am not sure about this, but just checking.
Old 01-28-2013, 02:14 PM
If it was me, I would blank the Short VIN too , but maybe the short VIM comes from the Long VIN, so when it is powered up and coded, it could be the Short VIN updates to match.
- BMWCCA #446923
- flick
Old 01-28-2013, 02:15 PM
Ok i will do.
Regards
Old 01-28-2013, 02:29 PM
I think 6WA became available with HUD beginning 0311, so I think to VO Code KOMBI with 6WA, the Production dates needs to be >=0311.
- BMWCCA #446923
- flick
Old 01-30-2013, 02:33 PM
So did the VO coding do the trick?
Old 01-31-2013, 05:10 PM
no works.......
It's to late, tomorrow more info
Old 02-02-2013, 04:35 PM
I think is impossible, i don´t know what can i do.
i erased the vin, but it does not work.
my advice is not buy a used Speedometer still.
Regards
Old 02-02-2013, 07:10 PM
Regards
We just need to figure out how to write the VIN to it.
@hamfei, any ideas? What Tool32 .prg may work?
- BMWCCA #446923
- flick
Old 02-03-2013, 12:43 AM
Shawn Thanks million for all your help.
This is the proof of vin erased:
No CAFD.
And this problem:
com.bmw.esys.domain.psdz.PsdzException: Failed to get CAFs for SWE "swfl_000003c1-004_054_006". [C111]
at com.bmw.esys.domain.psdz.Psdz.getCafsForSWE(Psdz.j ava:2088)
at com.bmw.esys.domain.svt.SvtLogic.getCAFsForSWE(Svt Logic.java:395)
at com.bmw.esys.gui.svt.SvtCompareController.callActi onGetCafsForSWE(SvtCompareController.java:695)
at com.bmw.esys.gui.svt.SvtTargetView$ActionGetCAFFor SWE.doActionPerformed(SvtTargetView.java:549)
at com.bmw.esys.gui.AbstractView$AbstractGuiProgressA ction$1.init(AbstractView.java:389)
at com.bmw.esys.gui.component.DialogProgress$2.constr uct(DialogProgress.java:136)
at com.bmw.esys.gui.component.SwingWorker$2.run(Swing Worker.java:145)
at java.lang.Thread.run(Unknown Source)
Caused by: KIS error: Die technische Einheit 000003C1 konnte in der KIS-Wissensbasis nicht gefunden werden.
Timestamp: Thu Jan 31 23:32:05 CET 2013
SessionId: default
ErrorCategory: SYSTEM_ERROR ID: 1283
Class: com.bmw.psdz.uc.LogicImpl
ExecutionContext={category=KIS, ecuid=(UNKNOWN,?)}
at com.bmw.psdz.uc.LogicImpl.getCAFsForSWE(LogicImpl. java:1173)
at com.bmw.esys.domain.psdz.Psdz.getCafsForSWE(Psdz.j ava:2085)
... 7 more
Please friends, any advice?
Old 02-03-2013, 07:36 AM
This is a good start.
The VIN is showed as 00 but i'm not sure if it's correct. To me, a empty VIN should be all FF. Maybe you emptied them in a wrong way...
If you have already written FF, you may consider recording the new VIN by using Tool32. Go to Tool32, load KOMBI??.prg (i've uploaded komb01.prg coming with the ecu folder of F10 data files), then, you will see the command as c_fg_xxxx. First, try c_fg_lesen to see if you can read the VIN out. It should be showed as all FF. Then, use the command c_fg_schreiben to write the VIN back. Note that you need to input a 18 bit VIN which means an additional checksum bit after the normal 17bit VIN.
I hope the above steps help. Good luck!
Old 02-03-2013, 08:07 AM
Hamfei, how can i calculate the checksum bit?
Regards
Old 02-03-2013, 09:04 AM
You should be able to find it from the vo file. In E platform, you can read VO through NCS and get the 18 bit VIN. I have no idea about F platform in E-SYS. Maybe you should check the VO xml file...
Old 02-03-2013, 09:08 AM
Hamfei, with my actual Kombi could i do this? c_fg_lesen to see if you can read the VIN ? with this i supouse that i can see the VIn 18 bit. is correct?
Old 02-03-2013, 10:27 AM
I have a Checksum calculator. I will upload and send you a link in a few minutes as soon as I locate it.
- BMWCCA #446923
- flick
Old 02-03-2013, 10:31 AM
Ok. I have PM'd you the link. Good luck!
- BMWCCA #446923
- flick
