Parting Out
E39 M5 parting out
X-MAS SALE!!!!!!!!!!!!
VIN : GJ15887 e39 M5 . pics upon request!!!Prices are all USD. CAMSENSOR KIT--------------------------------------------------------125 (all 4) Engine block ------------------------------------------------------------250 Cyl. Heads/each with valves --------------------------------------- ---------175/each VANOS/both---------------------------------------------------SOLD Instrument Cluster-------------------------------------------------------------SOLD Camshaft kits with sprockets (all 4) -------------------------------------------175 Crankshaft ------------------------------------------------------------------300 Pistons(set of 8) with conrods/caps --------------------------------------------70 Ignition coils set of 4 --------------------------------------------------------- SOLD Valve covers with spark plug cover /each -------------------------- -----------50/each Transmission # 23001434517 -------------------------------------------------SOLD Differential #33102229566 (still in car)------------------------------ ------------300 Output shafts L+R #33212282116 DME+EWS ------------------------------------------------------------- ------175 Flywheel+cluch all OEM ---------------------------------------------------------75 Intake manifold upper+lower with funnels ---------------------------------------175 Throttle bodies with gaskits 1-4cyl/5-8cyl ----------------- -----------------SOLD Vanos distribution piece with conn lines #11361407486 --------------------------50 Vanos pressure accumulator #11361407879 --------------------------------------50 Thermostat housing with temp switch #11531406762 -----------------------------50 Return pipes cyl .1-4 #11531406918 & 5-8 #11531406921 ---------------------50/all Engine oil cooler#11441406695 with control valve #11441406683----------------50 Set of knock sensors ---------------------------------------------------------SOLD Fuel rails with injectors --------------------------------------------------------SOLD Throttle actuator with bracket #12727831246 ---------------------------------50 Exhaust manifolds L+R--------------------------------------------------------50/all L/R upper timing cover--------------------------------------------------------40/each Rear main seal cover----------------------------------------------------------25 Alternator Starter Oil filter housing with pipes/hoses VIN: EY73413 e36 M3 , s52b32 usa Engine with DME ,damaged wiring harness, with intake manifold, throttle body. Engine turns by hand and feels has compession. Complete front brakes (with or without rotors) ,front spindle , caliper brackets, calipers. PLEASE ONLY : email , txt (hargitaibalazs@yahoo.com or +13459381978 iMessage,Viber,WhatsApp) Last edited by caymania; 01-30-2013 at 04:40 AM. |
bump
bump
Do you have wheels?
widescreen navigation?
I am interested in the kidney grills, cd player and wind shield fluid nozzle. Thanks.
hi!do u mean the dvd navi assy+the 16:9 screen assy combo?
thank you, Balu |
hi! yes we still have the wheels.
FR is broken FL has minor dent inside Both rear looks ok let me know if u still interested thank you, Balu |
http://realoem.com/bmw/showparts.do?...30&hg=52&fg=10
part number 6, in black
00 BMW 528ia Sport M5 F+R Bumpers, M5 Mirrors with OEM setup, M5 rear sway bar, Cluster Rings, 03 Business player with AUX input, HID fogs slim, OEM 01+ Hella headlights, EAC Aluminum Adjusters, FX-R low beam retrofit, Umnitza VXX 10w LED Halos, Hella Euro Celis Retrofit Kit, Koni yellow shocks adjustable, 19" M6 Reps, Full LEDs. ![]() |
Do you have the rear sway bar?
sorry but the seat colors are NOT black. |
hi!yes still have it.only itself the bar or with brackets/links?
thank you, Balu |
Widescreen nav? If so, how much for just the monitor?
Hi! 300usd plus shipping
thank you, Balu |
Hi do you still have the aluminum left and right brake ducts that's behind the front bumper? Need both sides. Price shipped to 62269? Thanks
Sent from my DROID RAZR using Bimmer App |
Do you have the bumpers?
dash
Do you have the upper dash? I need a black upper dash for my 2001 M5. Mine has cracks by the defroster and also the air bag over the glove box. I'm looking for dash panel above the wood trim.
thanks. Rick rs@amanick.com 248-202-5104 |
thank you for ur interest, Balu |
hi! sorry but both bumper in 1000 pieces
thank you, Balu |
Sent you an email
Interested in differential and flywheel
Jetpilot10 2000 540i Sport Corporate Pilot / Aerobatic Instructor Competition and Airshow Pilot WestWind II (IA-Jet) & King Air 350 (BE-300) www.tail-wheel.com |
Flywheel and clutch?
GGC BMW CCA #443004 Join the BMW CCA! 2005 X5 4.8is Le Mans/Black/6spd Steptragic ![]() 1999 M3 Cabrio TiAg Metallic/Dove Grey/Black 5 Speed Manual ------------------------------------------------------------------- 1997 328iC Schwarz II/K/K 5 Speed Manual SOLD 5/2012 2004 645Ci Mineral Silver Metallic/Black 6 Speed Manual RIP 04/2011 |
