Intermittant Bog-down / miss - New fuel pump already tried. - Bimmerfest - BMW Forums
E36 (1991 - 1999)
Old 01-27-2013, 03:13 AM
pimpin.dre pimpin.dre is offline
Sucker for the 3 Series
Mein Auto: 1995 328i, 1980 323i
Hey guys...
it's been a while, but i'm back with another issue....
Car's been bogging down heaps bad lately, but only intermittently and once it's warmed up. Hitting the throttle (either in gear, or free spinning, from idle - 2k rpm it seems to be choking, and then >2k rpm it's fine). If I drop it quite low in rpm, it seems to misfire, fart and carry on unhappily.
Fuel consumption is a bit worse than normal, but the really weird part is that when the car is mis-behaving, I can simply turn the key off, then back on and it runs perfectly for 5 mins or so. That's a good temporary fix, but not really a solution.
When it's playing up, it will quite often stall (instead of idling), and make me look like a dick at the lights / in a carpark.
I've read through the bogging down thread, and yesterday threw in a new fuel filter and fuel pump. Whilst that has made the car feel awesome, the problem still remains (and is still able to be masked by turning it off then back on.)
so... any hints? I'm not sure what to try next... help ultra appreciated
Member of the Non-M Bumper by Choice Club Member of the Official Secret Bimmerfest Text Club
Old 01-27-2013, 05:47 AM
TheFinanceGuy's Avatar
TheFinanceGuy TheFinanceGuy is offline
still learnin'
Mein Auto: 1998 328i / 99 540iA
What have you tried aside from the filter and pump?
I'd start with plugs, check the boots, check your battery/alternator to make sure you getting enough "juice" to make spark.
Any compression issues? Or lights (CEL)?
Patrick ///04 330i ZHP///BMWCCA#465139
99 540i TiAg
98 328i hellrot (sold)
96 318iC black (sold)
Old 01-27-2013, 10:11 PM
Cheers for the reply.
I threw in a new set of NGK's today but no better. Battery tests up good, and Alternator throwing out a solid 14V.
Next up i'm thinking injectors, or possibly ECU?
Old 01-27-2013, 10:19 PM
TRaV MaNN's Avatar
TRaV MaNN TRaV MaNN is offline
Somebody stop me....
Mein Auto: EW/// 86
No vacuum leaks? Unplug the battery and let it sit for about 30 minutes to reset everything.
You canít spend all your time worrying about where your next Twinkie is going to come from, so follow rule #32 and Enjoy The Little Things.
Old 01-27-2013, 10:25 PM
bimmerbarbie's Avatar
bimmerbarbie bimmerbarbie is offline
Official Queen of E36 OT
Send a message via AIM to bimmerbarbie
Mein Auto: 93ish 325ish
It sounds like a vac leak to me. I know that's how mine acted when I had a pretty massive vac leak.
Originally Posted by E36 Phantom View Post
... We all kinda just ignore Amber (barbie) anyway. She's sort of our attitude and eye candy here, that's why we keep her around...
Old 01-27-2013, 10:28 PM
jonesin's Avatar
jonesin jonesin is offline
The Canadian Prick.
Mein Auto: '96 328is Cosmos
Not throwing any codes?
Originally Posted by hnaz View Post
I grew up in a time when the internet was just a baby. Grammar back then versus now... holy cow. You could watch the degradation of society as the internet became more mature.
HAS KEN HAD HIS MEDS YET?
Old 01-28-2013, 02:39 AM
Thanks all,
Tried the reset while I was doing the plugs, no luck.
I spent a while chasing down a hissing noise about a year ago, but it never amounted to anything, however maybe this is what it was hiding all along. Admittedly it sounds really dumb to not have looked at this first, but I spent days looking for it last time (along with my mech) and we decided that it was nothing.
As for fault codes, I've got OBD2 and no scanner.
I guess tomorrow night i'll go hunting the hiss again...
thanks again everyone
Old 01-28-2013, 03:16 AM
still learnin'
Wait, isn't the car a 95? That's OBDI should be able to use the stomp test.
Hunting for vac leaks can be tough. But this sounds like the problem.
99 540i TiAg
Old 01-28-2013, 11:05 AM
hunter94 hunter94 is offline
Mein Auto: 1993 BMW 325I
Try spraying a bit of brake cleaner where you think the vac leak is. Once the cleaner hits the leak your engine will rev up. Also check on the underside of the air intake I had a leak there one time. The only reason why I found it was because I used the brake cleaner method. Be careful where you spray and be conservative. Keep us posted.
Old 01-28-2013, 11:06 AM
jonesin's Avatar
The Canadian Prick.
Guys, he's in Australia. They've different OBD requirements than you do in the States.
EDIT:
It's also the reason he's got a '95 328.
Old 01-28-2013, 11:10 AM
^ Duly noted. Do none of the parts stores out that way offer free OBD2 code reading?
Old 01-28-2013, 11:09 PM
Free? Nothing down here is free! Registration alone is $770 for 12 months down here!
Nah, i'm good friends with my mechanic, it's just that he's on the other side of the city to me. I'll have a spray with some brake cleaner tonight.
cheers!
Old 02-09-2013, 02:14 PM
So thanks again for your help guys. I took it in to the shop the other night and had it plugged in and got all the codes reset. Drove it for a few days, then plugged it in again...
Turns out it was the cam position sensor. Left it there for them to play with, and now it's fantastic!
Car's running the best it ever has since I owned it! So much happy!
Old 02-09-2013, 05:34 PM
Kdoherty's Avatar
Kdoherty Kdoherty is offline
bimmerfest Supporting Member
Mein Auto: A redhead E90
dang i was just about to chime in and say that you should check the CPS. good work, glad it worked out for you.
Originally Posted by Los View Post
^He's been drinking beer and destroying pumpkins with brake rotors and sledge hammers.
So, pretty much just doing man stuff.
  • '06 325xi 6MT
Old 02-09-2013, 09:03 PM
jonesin's Avatar
The Canadian Prick.
Glad she's sorted
bogging, fuel pump problem, miss, stall
