Old 01-16-2013, 04:19 PM
schpenxel schpenxel is offline
DIY'er
Mein Auto: 2004 545i
Originally Posted by Jay25 View Post
Schpenxel,
I posted the code that was given to me by BMW. Any idea what to make of it? Thx
Hey sorry, very late reply here. That was one of the same codes I got prior to changing out the solenoids. Can't say that will fix yours for sure, but it did on mine.
Originally Posted by chuckecoleman View Post
I had a small leak on my Tranny and after about 1/2 to 1 qt leaked out the surging stoped. Well it stopped until I had the trans serviced. My mechanic said that surging is caused because of a leak in one of the internal seals in the valve body. Not sure but it I would have to see a scematic to tell for sure if that makes sense or not. Good luck
Changing the mechatronics seems to nearly always fix that particular issue. I still haven't decided if it's an issue with the EDS solenoids or a seal somewhere as you suggested. Any way you could get your mechanic to tell you exactly what seal it is? I'd love to know.
Old 01-16-2013, 04:51 PM
Jay25 Jay25 is offline
Mein Auto: 2004 BMW 530i
I took my 530 in today to bmw of Manhattan dealership to have the trany replaced for $ 7,300. Anyone who has a trany surge, be prepared to put that cash. No BMW dealership will replace trany parts. It's what it is. Unless a good reputable Indy can do the job.
Old 01-16-2013, 05:16 PM
DIY'er
Funny, I fixed mine for $400.
Old 01-17-2013, 12:25 AM
Are u kidding me $400? Never buy another BMW, my first n my last.
Old 01-17-2013, 02:17 PM
DIY'er
Yup.
Solenoids are a common problem and can be replaced for that. Mine shifts like new now.
Worst case you could have replaced the mechatronics for 1500 + fluid/labor. It's pretty easy to do yourself though.
Really sucks that I (we) even have to do that though.. I had a civic that had like 250K miles on it and I haven't done anything to it except oil and timing belt once
Old 01-18-2013, 02:39 AM
Yes it sucks. 7K is no pennies. I wonder why there is no action law suit against BMW. If BMW is taken to court, I am pretty sure, they will fix this issue. From what I learn, GM, Benz & BMW have the same transmissions. Is that correct?
Old 01-27-2013, 09:17 AM
Vapiano's Avatar
Vapiano Vapiano is offline
Mein Auto: Dinan E60 M5 & 2014 550ix
Hey Guys,
Today for the first time I felt what everyone else has been talking about, around 34-40 mph the car seems like it doesn't know what gear to be in 4th or 5th. It gently switches back and forth between the two until I get to about 42 mph or step on the accelerator a bit harder then it goes away. There is also a slight delay when I put the car in reverse before it begins to move. The car has 60k miles on it; this allowed me to purchase a B2B New Car warranty from my credit union when I purchased the car this past December. It covers everything as if the car was new and seals are included!!!
I put the car up on a lift and saw no leaks at all coming from the tranny. I am dropping the car off this week to an Indy to get it checked out. Based on what I have read; it appears to be the valve body seal needs to be replaced. Is this the same as the mechatronics sleeve?
Also, for you guys that are doing this job yourself, how in the hell are you getting the oil back into the tranny?
Old 01-27-2013, 09:27 AM
DIY'er
Originally Posted by Vapiano View Post
Hey Guys,
I would recommend you try to get them to just replace the whole mechatronics assembly with at least a rebuilt one from ZF (via thectsc.com) unless they're willing to just replace the whole transmission--that would be even better!! No, the mechatronics sleeve and valve body seals are not the same. If you did not see any fluid leaking, then the mechatronics sleeve is fine, although I would have it replaced as well if at all possible while they're working on it. It's relatively cheap and known to fail.
There are a couple of different terms people use regarding seals on these transmissions that are hard to distinguish between. The "mechatronics seal" is what people usually refer to the seal between the electronic connector between the mechatronics unit and the plug from the car. It is #2 in the drawing below. It is accessible and it is common before it to begin leaking. It basically keeps the oil in the transmission but lets the electrical connectors out.
As far as the "valve body" seal, that could be many different things, although technically I would think it is one of the seals actually inside the valve body. I have read about these transmission extensively and would recommend just replacing the whole mechatronics assembly if possible unless you have a transmission shop that really knows what they're doing on these. There are shops that will rebuild the valve body portion for under $1K, but since you're under warranty, hopefully they'll go the "easy" way and just replace it.
How much longer do you have on the warranty? It sounds like you have a while, so at least you won't be bad off if they put a patch on it this time then it fails again later and they have to change some expensive parts.
As far as getting fluid in, it depends on which model you have for the specifics, but on mine there was a plug on the passengers side of the transmission. I had to buy a hand pump and snake a hose up into that fill hole. You first fill it up until it overflows with the car off, then start the car and let it get to I believe it was 104* and add more until it overflows again. Yes, being under the car, right beside the hot exhaust pipes is not a very joyful experience. Once the fluid is slowly dribbling out and the temperature is in the recommended range (104 to 120 I believe it was), then you put the bolt back in and you're done
Also, for the record, I doubt that picture is of your actual transmission. It was just the first one I found googling that showed something similar, so don't take the picture too literally as far as how the layout goes
Old 01-27-2013, 09:44 AM
Vapiano's Avatar
Thanks schpenxel,
I have 5 years (2018) or 39,000 miles left on the warranty or which ever comes first. I only put around 6,000 miles per year on my DD, I have a feeling I maybe upgrading in a few years anyway. I truly love this car and hope the newer models still keep that Ultimate Driving Machine feeling!
Old 01-27-2013, 09:47 AM
DIY'er
Cool, hopefully they take care of it then.
Old 01-27-2013, 09:52 AM
Vapiano's Avatar
If the mechatronics sleeve was leaking, wouldn't I be able to see this leak externally?
Old 01-27-2013, 09:54 AM
DIY'er
Yes. The purpose of that seal is to keep oil in the transmission while letting the electrical connectors pass through.
Old 01-27-2013, 10:01 AM
Vapiano's Avatar
Got it, maybe the leak is just beginning and this may explain the sudden symptoms I am having. I will post an update later this week.
Old 01-29-2013, 05:46 PM
Guys, by the way i forgot to mention that I wrote to BMW customer relations headquarters in the northeast about my situation, they agreed to pay for half of the cost. The dealer still has my car. I am not sure when I am going to get it back. I will up date.
Old 01-29-2013, 06:00 PM
Vapiano's Avatar
$3,500 for a new tranny?! It's better than having to foot the entire bill. I'd be curious if the solenoid change would have fixed your problem. Either way you are getting a new tranny and that is sweet.
2014 550i xDrive, Alpine White, Black Merino, Anthracite Wood, M Sport, Premium, Executive, and Cold Weather Packages, HUD, Ceramic Controls, Comfort Access, Sport Automatic Transmission, 4 Zone, Soft Close Doors, Power Trunk, Fully Coded, M Performance Spoiler and Black Grilles, 28% Tint, Charcoal Filter Delete, BMS Stage 1, Dinan Performance Springs, Bavsound Stage 1 Premium Kit w/subs, Beltronics STiR+
Old 01-29-2013, 06:14 PM
DIY'er
Indeed. I wish there were enough cases out there where we could say for sure the solenoids actually help in most cases.. I hate telling people to go that route when I only know 2 or 3 people who have tried it (although it helped all of them so I guess the stats are pretty good lol)
Old 02-05-2013, 04:43 PM
C///M C///M is offline
Mein Auto: 2007 'X3M'
Hey guys, I have a stupid question. In relation to the trans, where exactly is the mechatronics unit located on the 535xi?
I need to grab one off a 535xi for my swap. I found a guy with a wrecked 535xi but I need to tell him where the computer is...
Thanks in advance.
Prototype 2007 Monaco E83 'X3M' | N54 Swap | Gruppe M CF CAI | VRSF CP & DPs | CXR Intercooler | ER Dual Oil Coolers | Dual 2.5" w/X-Pipe | M3 Rear Exhaust | 20" BC Forged HB05 | Michelin PSS 265 & 305 | F10 M5 & F80 M3 Brakes | KW Variant 2 | H&R Swaybars | TMS Z4M Camber Arms | Z4 Finned Diff | BMW Perf. Grills w/Tri-Color | Custom M Body Treatment | CF Trim | M Perf. Carbon Shift & Handbrake Knobs | BMW Perf. SS Pedals | M3 Dead Pedal | V1 Hardwired | Int LEDs | Umnitza Orion v4 AE & More
Old 02-05-2013, 04:48 PM
DIY'er
Watch my video... It shows the whole thing being taken out
I'm sure that model isn't bolt for bolt the same as mine since it's the x version but ultimately it's in the same place, i.e. the bottom of the transmission. With the pan off you'll be staring right at it.
FYI, the mechatronics is the combination of the transmission computer, solenoids, and valve body. It's not just a computer.
The computer does have to be programmed to your VIN # in order to work, so you can't just pop them over from one car to the other as far as I know.
Here's a good picture of the whole assembly still connected to the transmission. Note that this is NOT your car, just a picture I found for reference
Old 02-05-2013, 05:48 PM
Thanks very much. That's what I thought. I really appreciate the thoroughness of your reply.
Yea, the programming isn't an issue. Just looking at the parts diagrams confused me. I didn't know the trans computer and mechatronics assembly would be inside the Oil Pan, but it actually makes sense now.
Old 02-05-2013, 06:19 PM
MINI+BMWtek MINI+BMWtek is offline
BMW master tech
Mein Auto: e30 318
The OP symptom is typical mechatronic valve body failure usually ZF will suggest VB replacement unless the transmission adaptation values point to an almost worn trans.
Sent from my Nexus 7 using Bimmer App
Old 02-06-2013, 07:14 PM
SFbay SFbay is offline
Account Under Review
Mein Auto: BMW 745i
You forgot about mechatronik adapter gasket, which in 80-90% will solve most of the problems!!!!
The point is not to drive a car with low oil pressure bc if that 20$ adapter!!!
But yes that 20$ gasket makes dealerships happy
Old 02-17-2013, 03:19 PM
toviasart toviasart is offline
Tex
Mein Auto: 545I
BMW technician confused
Took mine to dealership drove around with technician but does not know what is the cause? Been having the issue for the last 3 years! Disappointed with BMW service care at this point, starting to think trade in.
Old 02-17-2013, 03:44 PM
DIY'er
What is yours doing?
Old 02-17-2013, 05:17 PM
Tex
Mein Auto: 545I
Transmission pulls around 35 to 40 miles a hour. I took it to reset it it worked for two weeks and it keeps coming back. I also experienced transmission not shifting from 1st once then suddenly started shifting again. I can tell you the 545 hates cold weather..
Old 02-17-2013, 05:57 PM
Mein Auto: BMW 745i
Over and over same thing:
Mechatronik adapter, once you replace it you'll thank me a lot
advice, bmw 5 series, issues, tranny problems
