Old 01-30-2013, 06:02 AM
aja9028 aja9028 is offline
Mein Auto: 2008 328i
Standard Air Filter and Code reset
So my radio stopped working on 2008 328i and i took it in to have it diagnosed. And when i did the dealer said it was 85$ to diagnose the problem and said that i also need to replace my air filter and need to reset my code (for maintence schedule).
He said to replace the air filter that it would be 125$ + to reset the code another 64$. Is that normal? I have about 43k miles on my car.
Also could i get this done somewhere other than at a BMW dealership?
Old 01-30-2013, 06:20 AM
Phil325i's Avatar
Phil325i Phil325i is offline
Mein Auto: 325i E92 Coupe
Air filter replacement is a simple DIY, and you can re-set the service interval display yourself. There are loads of 'how-to' guides on YouTube.
E92 pre-LCI 325i - Ohlins R&T; H&R spacers; M3 strut brace; Swift thrust sheets; BMS clutch stop; BMS CDV; RE g/box mounts; Saikoumichi OCC; K&N; Cyba scoops; BMW Perf Exhaust; M3 rear spoiler; Recaro Sportster CSs; M3 white dash LEDs; LED Angels; BMW Perf black grille; CSL reps; SSDD carbon diffuser; Monster Wrap black roof/clear front
Old 01-30-2013, 06:31 AM
99328ic 99328ic is offline
95325i on bimmer*****s
Send a message via AIM to 99328ic Send a message via MSN to 99328ic
Mein Auto: 01 Z3,06 330i,08 Accord
I can't remember how much a replacement air filter was on my 330i but no where near that price I also think the reset the clock "code as they call it" can be done via the OBC or idrive depending on the system you have. Yes, the air filter is kinda a PITA to replace in its location. The $85 to have them just hook the car up to the computer and see the code for the radio issue sounds about right.
It might be time to find a indy BMW repair place now that the warranty is up on your car I would assume.
Past: 95 325i, 99 328ic, 97 540ia
Old 01-30-2013, 06:41 AM
How often do we have to replace the air filters, this is my first BMW so I am not too sure about anything
Old 01-30-2013, 08:13 AM
cwinter's Avatar
cwinter cwinter is offline
Here comes trouble!
Mein Auto: 2009 328i E90 :)
My dealer charges about $140 to change the A/C Microfilter and $50 (perhaps less) for the engine air filter. Both can be bought off of Amazon or other websites for considerably less money and install easily yourself. The A/C microfilter is a 5 minute job, the engine air filter perhaps 15-20 minutes. I wouldn't let the dealer change any of these unless they do it for free under the maintenance plan.
Again, both filters can be bought for $20-$30 each online. These are just easy money makers for the dealer to keep the Starbucks flowing...
2009 328i Sedan - Ordered: 2/24/09 .:. Delivered: 5/6/09
Jet Black | Black Dakota | Aluminum | Premium | Sport | Xenon | CA | Split Fold Seats
You will rue this day, RUE THIS DAY
Old 01-30-2013, 08:34 AM
ctuna ctuna is online now
Mein Auto: 325xi wagon
Filters are about 25 to 35
Filters are about 25 to 35 mann filters are used commonly.
You will need a T20 or T25 driver for the engine air filter most
already have a metric socket set.
You can do the job yourself and reset the CBS recall yourself.
The Diy's to do this are found in the these sub forums
http://www.e90post.com/forums/forumdisplay.php?f=16
I would be doing them every 30k and if you and checking the Engine air every 15k.
If you are in an extremely dirty environment every 15k.
All the CBS recalls can be reset from the one of the levers on the steering wheel takes less than a minute probably 30 seconds
when you familiar with the procedure.
Do you know which stereo system you have is it Hi Fi , L7 or stereo.
If they want to replace and amplifier, you might want to consider and aftermarket solution
because it will be way to expensive for what you get.
http://www.e90post.com/forums/forumdisplay.php?f=27
