Complete list of all o-rings (by size & by part number) to buy when ordering parts
I was ordering oil filters today when I realized I should have a ready-made list of o-rings by part number to get while I'm already ordering other stuff (not just for oil changes but for all maintenance jobs).
Here's my starter list below - but the point of this thread is for others to ADD other necessary maintenance o-rings (& rubber o-ring-like gaskets) for adding to existing orders and to keep in stock in the garage. NOTE: Please make sure the part number and the size & quantity needed is listed!
By way of example, here are current prices from 4wheelsautoparts (which I assume are typical out there): Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-25-2013 at 08:40 PM. Reason: Added detail... |
Injector O-ring lower (Injector-to-engine) p/n 13641437486
Injector O-ring upper (Injector-to-fuel rail) p/n 13641437487
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby |
CPS to engine O-ring p/n 12141748398 (Item #9)
![]() CPS O-ring (Intake & exhaust) p/n 12141748398 (Item #6)
Looking for a DIY? Parts? Check this out, it might be your ticket TMS underdrive pullies - Stewart WP - PSS9 - Beisan Vanos seals - Zimmerman cross-drilled & Akebono Euro - Deka 649 MF - 55w HID headlights - 35w HID foglights - Hualigan double din - ACS (rep) alu pedals - Euro central storage console - Breyton Magic Racing staggered wheels - M5 bumper - M5 steering wheel - Tint Stable: e39 M54, e53 N62 & Tribby Last edited by doru; 01-22-2013 at 08:15 AM. |
WP O-ring p/n 11511711484
Water inlet/outlet pipe O-ring p/n 11531435808 (Item #7) ![]() Distribution piece O-rings p/n 11617502761 ICV grommet (big soft "O-ring") p/n 11611437453 DISA valve O-ring - check German Auto Solutions (Gary)
Thanks!!!
2002 530i
This isn't really the thread for that; the right thread for that would be found by typing /power steering F3 in the bestlinks, which comes up with this:
- How to remove and replace the power steering cap o-ring (1) (2)
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! |
Interesting thread.
They do deteriorate in time, sometimes it's a leak (like the oil leak by the CPS). Sometimes it's vacuum leak (DISA). BTW, Gary's O-rings work well, BUT: make sure you lube them lightly, then when you re-install the DISA, be VERY GENTLE in pressing it in. You have to actually rotate it back and forth and press it very gingerly in. Otherwise, the new O-ring will shear. Ask me how i know. The PS O-ring, once you start seeing ATF on the canister - it's a dead givaway. I always thought it's soiled because of the vent hole. I was wrong. Since I change that sucker, I never had a drop of the red stuff staining the canister.
- How NOT to change your oil! I doubt anyone does it that frequently - but it's apparently in that TIS. All I have is this screenshot ... so if you have the TIS - let us know what it actually says.
It's too cold right now to mess with any further so I'll try again later.
2002 530i
That's the way for most of us.
In fact, this is a picture (from this classic priming-oil-filter thread) of my very first oil change (please ignore the embarrassing $18 STP filter! I've since learned my lesson.) Given this picture from this thread, I doubt my o-rings have EVER been changed (since I'm only the 2nd owner): According to cn90, those two o-rings don't seem 'all' that important, functionally, though: -> E39 (1997 - 2003) > DIY: E39 Changing engine oil made simple (how to do it in 30 minutes and not crying!) Note: The diagram below is from this thread. Note: The diagram below is from this thread. EDIT: Doing research as to WHAT each of these o-rings does, I find this interesting comment and video:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-23-2013 at 05:57 AM. |
Interestingly, here is a picture of a reputed CPS o-ring gone bad just now reported today: These photos from this thread show the M54 intake CPS & exhaust CPS locations: A good picture of the CPS o-ring is in this thread:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-23-2013 at 01:59 PM. |
Having had no experience with the camshaft position sensor (aka CPS) or the crankshaft position sensor (aka CKP), I'm a little confused about how many CPS o-rings are needed, as three seem to be listed - but they're all the same part number???
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-23-2013 at 10:59 AM. Reason: Added diagram for clarity of the question. |
For the record, this entire thread is on the M54 engine DISA o-ring, for folks coming here the first time.
The conclusion is to use a #139 Viton O-Ring. The reason is shown below:
I just remebered last year when I replaced the PS hoses. There are 2 small O-rings p/n 17211742636 (item #11) that go to the heat exchanger.
i am too lazy to replace large o-ring on oil filter with every oil change
normally it lasts forever ( if you dont screw it ) , never oil leak from it Last edited by champaign777; 01-23-2013 at 03:13 PM. |
I searched realoem for O-ring. The search returned a list parts with the term "ring" in the description. I edited the list to include only the descriptions with the term "O-ring". Hope this helps.
Here's the list: Part 12141748398 (O-ring) found in: Engine Block Mounting Parts Part 11361703713 (O-ring) found in: Cylinder Head Vanos Part 12141748398 (O-ring) found in: Cylinder Head Vanos Part 11511711484 (O-ring) found in: Waterpump - Thermostat Part 11431717666 (O-ring) found in: OIL PAN/OIL LEVEL INDICATOR Part 11431740045 (O-ring) found in: OIL PAN/OIL LEVEL INDICATOR Part 11421741000 (O-ring) found in: Lubrication system-Oil filter Part 11421744001 (O-ring) found in: Lubrication system-Oil filter Part 11427549573 (O-ring) found in: Lubrication system-Oil filter Part 11531435808 (O-ring) found in: Cooling System Water Hoses Part 11417507429 (O-ring) found in: Lubrication system/Oil pump with drive Part 11411722837 (O-ring) found in: Lubrication system/Oil pump with drive Part 13621743299 (O-ring) found in: Intake manifold system Part 11617502761 (O-ring) found in: Intake manifold system Part 12141748398 (O-ring) found in: Sensors Part 12141748398 (O-ring) found in: Sensors Part 13711720540 (O-ring) found in: Intake muffler Part 13641437487 (O-ring) found in: VALVES/PIPES OF FUEL INJECTION SYSTEM Part 13641437486 (O-ring) found in: VALVES/PIPES OF FUEL INJECTION SYSTEM Part 13531720251 (O-ring) found in: Fuel filter, pressure regulator Part 13531720252 (O-ring) found in: Fuel filter, pressure regulator Part 17211742636 (O-ring) found in: TRANSMISSION OIL COOLING Part 24201423387 (O-ring) found in: A5S325Z lubrication system Part 24311422806 (O-ring) found in: A5S325Z lubrication system Part 24201217321 (O-ring) found in: A5S325Z Output Part 24341421736 (O-ring) found in: A5S325Z wiring/oil filt./pulse generator Part 24101423176 (O-ring set) found in: A5S360R/390R ctrl unit with mount.parts Part 32321094182 (O-ring) found in: STEERING LOCK/IGNITION SWITCH Part 17211742636 (O-ring) found in: HYDRO STEERING-OIL PIPES Part 33117525064 (Screw plug with O-ring) found in: Final drive, gasket set Part 34311165092 (BRAKE MASTER CYLINDER O-RING) found in: BRAKE MASTER CYLINDER/EXPANSION TANK Part 34311165092 (BRAKE MASTER CYLINDER O-RING) found in: Power brake unit depression Part 64118385686 (O-ring set) found in: HEATER RADIATOR AIR CONDITIONING EDIT: added files, remove .pdf.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 Last edited by Steve530; 01-27-2013 at 05:29 PM. Reason: added files |
Thanks for that list.
It would be nice if a supplier puts together a kit for our E39s. I can see them making a profit because, in bulk, the o-rings are pennies, whereas they can charge us a buck or so, and the kits won't take a lot of room on the shelf, and can be easily adapted for other vehicles. By way of update, my rubber "kit" arrived today, complete with a few extra sets of the hard-to-find 441 (61610154441) wiper blade inserts and a spare oil bolt & crush washer, in addition to the list of o-rings earlier discussed in this thread, each in their own labeled baggy.
Looks like you got a new HID lamp, too.
I've attached the list I posted above, supplemented with parts listed as gasket seals and sorted by application. It's a PDF file. If anyone needs the spreadsheet, PM me.
Steve 2001 530i/5 S+P CDV delete/Akebono ceramic pads M5 SSK/RedLine MTL/M5 rear sway bar/Bilstein HD OSRAM CBI BMWCCA Member #337964 |
For example, when doing the CCV, we could do the CKP and CPS o-rings, in addition to the lower dipstick tube o-ring. You're observant! I sat down to open the box that came in the mail, and as I laid everything out to compare to the invoice, I snapped the photo, so I hadn't thought of mentioning the bulb. I bought the bulb because my low beam indicated it was out. Funny thing - the moment I pulled the old bulb out, it lit right up in my hands. So now I have an extra H7 bulb, just in case, to stock along with my o-rings. Oh well, it will eventually get used (as long as I don't lose it, which I am wont to do). Hmmmm... Maybe we can open a separate thread, that references this thread for o-rings, that lists all the "stuff" that we can stock to put on the shelf - that our ten year old bimmers are gonna eventually need. EDIT: I opened this thread for all "stuff" that we probably should stock in our garage: - Complete list of E39 stuff (parts, tools, fluids) to stock for handy eventual use
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-25-2013 at 09:32 PM. |
Updated post #18.
> E39 (1997 - 2003) > Injectors replacement and/or servicing DIY
#25
I don't know if anyone has suggested this yet, but for the DISA, you can get square-cross-section o-rings of almost any material you like.
For example https://www.mfpseals.com/catalog/cat...trong-nitrile- And, of course, you can get round-cross-section o-rings at lots of places too, for the VANOS or for other parts 1. (easy to use oring warehouse calculator) 2. the o-ring store 3. mfp seals 4. orings usa What we need is a list of the "trade sizes" for each of the replacement orings, and the material. 1. http://www.allorings.com/size_cross_...nce_framed.htm 2. http://www.marcorubber.com/sizingchart.htm 3. http://www.broadleyjames.com/o-rings-size-chart.html |
| Tags |
| o ring, o-ring, oil change, oring, parts ordering |
