Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 7 Series / 8 Series > 7 Series - F01 (2009 - current)
The new re-designed 7 series leads off the BMW Fxx chassis code!
Old 01-29-2013, 10:18 PM
dbs600 dbs600 is online now
Mein Auto: 2011 750LXi Individual
Rear Right Side Shade Does Not Work
My rear right side shade does not work. No noise, movement, etc. when trying to raise it. Is the motor simply 'timed-out'? Is there any way to reset it without a dealer visit? Tried opening and shutting the door, raising and lowering the window and moving the shade with my hand (which does not move at all), all to no avail…..
Old 01-30-2013, 02:39 AM
Leslierc's Avatar
Leslierc Leslierc is offline
Sejanus
Mein Auto: `11 MSport 750ix/`08 135i
You're under warranty...I would take this problem to the dealer. Based on the fixes you said you tried, I think you've narrowed the problem down to either a bad motor or a faulty relay.
2011 Panamera 4S...GT Silver / Espresso
2012 Mini CooperS convertible
2008 135i Convertible - Sparkling Graphite Metallic
Prior BMWs: `05 645CiC; `07 650i; `08 M6 convertible; `11 750ix MSport
2004 GX470
Old 01-30-2013, 06:01 AM
chrischeung chrischeung is online now
Mein Auto: 2012 ActiveHybrid 7 SWB
I agree. Let the warranty do its thing. No ideas beyond what you've tried. The worst thing to do is to break something while trying to fix it and making it out of warranty.
2012 ActiveHybrid 750i ED
3/12 ED 7 - thread ID 610350
1/11 ED 6 - thread ID 5767556&postcount=175
4/10 ED 5 - thread ID 453501
5/08 ED 4 - thread ID 290679
3/07 ED 3 - thread ID 201013
3/06 ED 2 - thread ID 136454
Old 01-30-2013, 10:13 AM
Okay; thanks.
Old 01-30-2013, 04:32 PM
gassy gassy is online now
BMW 7 Series Obsessed
Mein Auto: 2011 750i Milano Beige
After having window tint applied to all the windows when I first purchased my car, the shade motor for one of my rear windows was shorted out, presumably from moisture from the film application. After a day or two, I located the fuse for that motor, removed and replaced it and all has been well since then. You may want to give this a try.
2011 750i/ Milano Beige/ Saddle & Black Nappa/
Old 01-30-2013, 08:07 PM
Interesting; where was the fuse box located; right rear of the trunk? Thanks!
