Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > 1 Series & 2 Series > E82 / E87 / E88 1 Series (2008 - 2013)
BMWs throw back to the iconic 2002, with a renewed form and function. The smallest car in BMW's line up but still packs a punch. Available in coupe or convertible, powered by a naturaly aspirated inline 6 in the 128 or the turbo twin power inline 6 rocket sled 135.
Old 01-29-2013, 10:04 AM
Lpon_e82 Lpon_e82 is offline
Mein Auto: BMW 135i m sport
Need opinion on wheels for 2010 135i
I'm considering in buying some csl reps made by alufelgen wheels. The model is their cs7 the size of the wheels are 19 x 9.5 in the rear and 19 x 8.5 in the front both with a 35et my question is will they fit or do I need to make mods and what tire size will fit. Thanks!
Old 01-29-2013, 12:06 PM
SilverX3's Avatar
SilverX3 SilverX3 is offline
Mein Auto: 130i & E92 325i, E90 SOLD
35 should be ok.... Pretty closed to guard but should be ok
Residence - StarTrek Enterprise
Job - Captain
Current Starship Fleet:
06 130i - ROCK SOLID Performer
MY11.5 X1 Xdrive25i
2013 VW Golf R - Rising Metallic Blue
Old 01-29-2013, 12:07 PM
SilverX3's Avatar
9.5 rear can be a bit wide
I had 19x9 with 35 off set on mine before with 235/35/19 tires and pretty closed to the edge on rear
Job - Captain
MY11.5 X1 Xdrive25i
Old 01-29-2013, 12:48 PM
Thanks! Was your car ever lowered?
Old 01-29-2013, 01:35 PM
SilverX3's Avatar
it was a sport pack (so a bit lower than normal) and 19x9 with 235/35/19 gave me about 1/2 inch clear of the guard.... swapped back to 18" at the end as driving in heavy rain there was not enough space for water to clear out of the guard and that can be dangerous
Job - Captain
MY11.5 X1 Xdrive25i
Old 01-30-2013, 07:13 AM
pkim1079 pkim1079 is offline
Mein Auto: e90 m3
What about apex wheels?
BPM stage2 + servo tune - POS exhaust - catless - driver mod (ongoing)
Old 01-30-2013, 09:59 PM
mryakanisachoad's Avatar
mryakanisachoad mryakanisachoad is offline
Mein Auto: 550xi / 135i / M5
It might literally come down to actual shape of the tire.
Old 01-31-2013, 01:18 AM
SilverX3's Avatar
I thought tires are all round shape
Job - Captain
MY11.5 X1 Xdrive25i
Old 02-01-2013, 02:55 AM
Nope, some tires have squared off or "blocked" shoulders; some tires are more tapered.
Look on the e9x wheel and tire forum. Tons of fitiment threads...
Old 03-19-2013, 12:16 PM
ModBargains.com's Avatar
ModBargains.com ModBargains.com is offline
Mein Auto: E92 335i, F82 M4
This is a fitment that is for the 3 series specifically. It is considered very aggressive on a 1 series and will require you to adjust your camber, roll your fenders, and run stretched tires. Definitely not the optimal size. Alufelgen does not make the CS7 in the 1 series specific fitments in 19" and it's only available in 18".
18x8.0 ET45 - 225/40/18
18x9.0 ET48 - 255/35/18
If you're looking for a 19" setup, I'd recommend that you check out the VMR VB3 CSL style wheels. The offsets are slightly aggressive but will work so long as you run the correct spec tires on stock height.
19x8.5 ET40 - 225/35/19
19x9.5 ET45 - 245/30/19
Alan Wei | Alan@ModBargains.com | (714) 582-3330 ext. 8006
We Specialize In: BMW M3 Wheels | BMW Brakes | BMW Suspension | BMW M3 Parts | VMR Wheels |
Remus Exhaust | HRE FlowForm
Hours: Mon - Fri 8:00am-6:00pm | Sat 8:00am-5:00pm
Check out the Blog for daily updates!
