F10 / F11 (2011 - Current)
The new chapter in the highly successful story of the BMW 5 Series Sedan (F10) and wagon (F11) |
#51
Yeah, the residual value is 48% after 3 yrs.
F10 535i Jet Black/Cinnamon Brown |
#52
Times like this is when I enjoy have 555hp and xDrive. Buh-bye
BMWUSA 650i xDrive Build Link ...................................BMWUSA X5M Build Link 2013 X5M ........ 2013 650xi ...... 2011 550xi (ret) 2011 335d (ret) ![]() ![]() ![]()
#53
hows the x5? hows the handling when you've really pushed it through corners? The 50i and 35d I've spent time in I'd be terrified to push it hard in corners.
#54
Anyway, the X5M handles pretty well for such a heavy vehicle. I've been pushing it in clover leafs and there's a tendancy to understeer, but it's controllable. The bigger challenge is controlling the power under wet conditions; today the torque was transferred to the rear, then to the front, and then back to the rear as the Xer accelerated like a banshee.
#55
~ 13 M3 coupe "new" daily beater ~ 13 x5M Hers - Previous BMW's - Way too many to list here (15) |
#56
#57
It's hard to not seem like a Luddite when criticizing any true M, but are these cars supposed to have better gadgets than steering?
I think in 10 years BMW historians may regard the E9x as the last true M series. All this turbocharging was destined to kill the mystique of the moniker. I, for one, welcome our new BMW-Lexus overlords. Resistance is futile. |
#58
The m5 is a little bit of a fcuk you car. It's the sort of car impulsive football players buy with their signing bonus. I bought mine from a ny giant who apparently decided that M5 wasn't getting him nearly enough attention. He took an almost 30k depreciation hit in just a little over 7 months...
#59
#61
I am not a big fan of turbos either but the EPA regulations moving forward have made turbos popular. Look at Mercedes, their AMG and non-AMG V8s are now turbos. Gone are the NA big block engines. DI and Turbos will become more and more popular.
2013 BMW X5 35i Alpine White | Cinnamon Brown | M Sport 2013 BMW 550i Titanium Silver | Black | M Sport |
#62
1. Increase displacement. Larger combustion chambers will load more fuel per engine cycle. 2. Forced induction. More fuel is forced into the combustion chambers per engine cycle. 3. Increase rpms. More fuel is combusted per time unit when more engine cycles are executed per time unit. Now, how does these technologies rate in terms of fuel efficiency? The trick is to use minimum fuel when you don't need all that power or to reduce the power needed to move the vehicle. A turbo engine is normally more efficient than a NA engine that delivers the same power per engine cycle since it's displacement is smaller, i.e when you feather the throttle or cruise it drinks like a NA engine of it's relatively smaller size. When you are running full boost it is likely not more efficient than the larger NA engine that can burn the same amount of fuel per engine cycle as is forced into the turbo engine. However a high rpm small NA engine with the same displacement as the turbo engine should be able to be nearly as fuel efficient but instead of feathering the throttle the efficiency is achieved by keeping the rpms low. Also I don't think the race should be lost for a bigger NA engine with low end grunt either. There are technologies to cut out a number of cylinders while going easy on the throttle and thereby provding a turbo like efficiency where the discplacement used is smaller when going easy on the throttle or cruising. You can also lighten the cars and make them more aerodynamic etc. The transmission can be more efficient by "sailing", i.e no engine breaking and KERS like systems can be used for energy savings. One obstacle I see for a high performance NA engine is that it requires a lot more skills, have lower tolerances and is in general more costly to develop and manufacture. Now when the genie is out of the bottle on easier and cheaper M turbo power the BMW bean counters can be reluctant to put it back. Last edited by solstice; 02-01-2013 at 03:45 PM. |
#63
Nope, but he won a prize: First buffoon added to my Ignore list in 2013. Kind of impressive I made it through the whole month of January without any other fanboi irritating me that much. I must be mellowing with age.
![]() Sent from my HTC Inspire using BimmerApp
Current BMW's: 2011 535xi M Sport TiAg / Black, ZPP, ZP2, ZCV, ZCW, ZDA, 2TB, 6NR, 465, 5DL, and a Partridge in a Pear Tree 2011 X5 35D Deep Sea Blue / Oyster, PP, SP, PSP, CWP, Tech, 20" 214's Prior BMW's 2008 ///M3 Vert 2008 X5 3.0 2007 X5 3.0 2006 X5 3.0 2006 550iA SP 2003 540iA M-Sport |
#64
You have persistently been praising your E60 (535i) saying that it was sporty was that not turbo??And if enthusiast cars should/must be NA, then the new M3, M4, RS6 soon, E63 are all not enthusiast cars! Last edited by bm323; 02-02-2013 at 05:46 AM. |
#65
Everyone on the planet realizes that the F10 is overweight and doesn't handle well. BMW went too far to the 7 side of the equation with the F10 and strayed too far from the E90 feel of the previous generation. That's essentially the problem with all of the F10 models from the 528 all the way up to the M5. Theres no reason to defend the M5, practically every auto mag says the same thing...the M5 is no longer the best sport sedan in the world. it's too heavy and the electronic steering which was used to save fuel sucks. Theres really no debate on this...Ive owned 2 E92s and now the F10 Msport and the F10 drives more like a good GM car than it does my E92.
Sounds like you'd be at least a slightly happier camper if you would have waited to get a 2013 with the passive M Sport suspension (not the higher riding, softer Active suspension which wasn't exclusive to M Sports in 2012). Makes a fairly good difference in tightening up (and lowering) the F10's ride.
'13 F10 BMW 535i ///M Sport : Jet Black/Black-Anthracite : Premium & Technology Packages/Sport Auto Trans/Camera/Park Distance Control/Heated Seats/Tinted Windows/Blacked Out Markers/Performance Spoiler. Ex M-B's: '11/'10/'06 E350's w/ AMG Sport Package, '02 S500 w/ Every Option.
#67
The same steering wheel vibrations are there with my 535i since day one. Feels like there is a wheel balance issue but it is not the case because it goes away at times - randomly. Very annoying but I don't think that the service can fix it.
13 BMW F10 535i RWD - 3.0 L 221 kW (300 hp) Bone stock except NAVI, PDC, Camera, Tint, Coded, HID Kit, Debadged 2007 BMW E64 630i - 3.0 L 200 kW (272 hp) 03 BMW E65 745i - 4.4 L V8, 242 kW (325 hp) 98 BMW E39 535i - 3.5 L 183 kW (245 hp) 95 BMW E34 540i - 4.0 L V8 210 kW (282 hp) 89 BMW E30 M3 non-cat 147 kW (200 hp) 12 MB W221 S550 4-Matic 10 Infiniti G37x Sedan 2009 Mercedes C 350 08 Infiniti G35x Sedan 04 Mercedes CLK 350 01 Mercedes C 230 98 Ford Crown Vic Police Interceptor |
#68
The M5 is a beast. But it comes down to this.
The extra cost gets you a limited production high performance 500HP+ engine and tranny (about $15k) and forged wheels (another $5k). I would never be able to open up that kind of power. As it is, I can't open up a 535 all that much. ![]() To me, the key to the M5 looking awesome is the color and wheel choices. Some of the color and wheels choices are just nasty.
2011 535i 2008 VW GTi |
#70
