E34 (1989 - 1995)
Closed Thread
Old 01-31-2013, 05:05 AM
Monsignor's Avatar
BMW CCA Memeber #445389
Mein Auto: M50 Big Body
I agree. The only two times my cars couldnt hold an idle at all:
350Z: forgot to reconnect the vacuum line on the intake tube = massive vacuum leak/no pressure built
E28: forgot to put the oil cap back on = massive vacuum leak/no pressure built
Both acted the same way as your car does. And one is 12 years newer and the other 5 years older!!!
Sent from Joe's Galaxy Tab 2 via BimmerApp
1995 525iA 250k mi Shifted Performance E34
2006 325i/6 48k mi
2003 350Z 87k mi Shifted Performance 350Z
Garden State Euros
  #52
Old 02-02-2013, 08:44 PM
E34_Obsession E34_Obsession is offline
"The sound of the M50"
Send a message via ICQ to E34_Obsession Send a message via Skype™ to E34_Obsession
Mein Auto: 91 525i
The only thing I have left to check is the ICV... All of the Vacuum lines are good, connected, and clamped down...
  #53
Old 02-03-2013, 12:57 PM
If you could perform a smoke test, do it to verify that you don't have any leaks.
  #54
Old 02-20-2013, 06:58 AM
Mein Auto: 91 525i
Today I will be working on the vehicle so I will do a smoke test and confirm that I don't have a vacuum leak. Then I will test the ICV as told by many on here.
If I stopper up and unplug the ICV, would the engine still start?
1991 BMW 525iA
1999 Toyota Tacoma Prerunner
2008 Toyota Tacoma Prerunner Sport -
1995 Toyota Tacoma 2WD DX V6 - SOLD
1992 Toyota Pickup - SOLD
2003 Subaru Forester 2.5X - SOLD
2004 Subaru Forester 2.5XT - SOLD
  #55
Old 02-20-2013, 07:25 AM
Monsignor's Avatar
Ok, so i just reread this whole thread to re-familiarize myself. As you'll be with the car today, please do stay online and keep us posted. We are your salvation. I'd also like to rattle off all of my theories, hear them out and take them into deep consideration.
  • when listing MAF, you say good. Did you check the the resistance of it? could you remove it and clean it with a tiny bit of carb cleaner, or i believe they make MAF cleaner now...
  • You end the "air" category with "yadayadayadayadayada"; that yadayadayadayada will be whats causing your car to behave this way potentionally. thorough thorough thorough.
  • be very gently with ICV as the valve itself is rather fragile
  • You said you did a compression test and all numbers were within a good running range, no need for that cylinder wash. UNLESS: cranking without firing has cause the fuel injected to eat the oil helping to seal the rings.
  • Please do check Throttle position sensor for the hell of it. I'd like that peace of mind.
  • Have you tried "manually" controlling your idle by holding the throttle at 25-35%? rather than smashing the pedal over and over?
  • results of smoke test. I'm still betting on a gigantinormic vacuum leak.
please do check back.
2006 325i/6 48k mi
Garden State Euros
  #56
Old 02-21-2013, 07:00 AM
Mein Auto: 91 525i
Smoke test complete and no vacuum leaks found, and thank you for your help, that goes to everyone on this thread...
Now, no vacuum leaks detected, the resistance on the MAF is correct via the Bentley Manual specs. TPS is good, now I have to focus on the ICV...
How do I go about testing the ICV?
I will be working on the vehicle again today...
1991 BMW 525iA
  #57
Old 02-21-2013, 07:18 AM
Monsignor's Avatar
ICV is under the intake manifold. This will probably be your only project today...
DIY ICV Cleaning via bimmerwerks
Best of luck
2006 325i/6 48k mi
Garden State Euros
  #58
Old 02-21-2013, 07:21 AM
Mein Auto: 91 525i
Right I know where it is, would a sudden jerk or bump destroy an ICV?
1991 BMW 525iA
  #59
Old 02-21-2013, 07:24 AM
Monsignor's Avatar
if i smashed it "suddenly" with a sledgehammer? sure. bumps in the road? nope. They're strong (being BMW built) but the valve is very sensitive...
2006 325i/6 48k mi
Garden State Euros
  #60
Old 02-21-2013, 07:32 AM
Mein Auto: 91 525i
Ok I will take note of that and be cautious. Now If I unplug the valve and stopper up the hoses to and from it would still start and run?!?
1991 BMW 525iA
  #61
Old 02-21-2013, 07:35 AM
Monsignor's Avatar
I'm not entirely sure. My best guess would be that it would take note of Throttle position sensor and MAF to run.
the point of doing that would be to isolate the problem, yes? you could try it and let us know, i dont see how it could damange the car, maybe throw and store problematic codes but hey, we're on a new frontier, aren't we?
2006 325i/6 48k mi
Garden State Euros
  #62
Old 02-21-2013, 07:46 AM
Mein Auto: 91 525i
Haha I guess so. I will be working on the vehicle this evening and will report back on what I find.
1991 BMW 525iA
  #63
Old 02-21-2013, 07:48 AM
Monsignor's Avatar
if you try to run it with the ICV disconected and isolated, i will be very interested in results.
2006 325i/6 48k mi
Garden State Euros
  #64
Old 02-21-2013, 08:27 AM
Mein Auto: 91 525i
I will keep you posted in what happens... Thanks for replying to my thread for so long!
1991 BMW 525iA
  #65
Old 02-21-2013, 08:28 AM
Monsignor's Avatar
never a problem. I live for diagnosing and troubleshooting. It's what we're here for.
2006 325i/6 48k mi
Garden State Euros
  #66
Old 02-21-2013, 09:40 AM
Mamij Mamij is offline
Mein Auto: BMW 320i M52 1996
Best of luck
The icv is new according to the op and no bad icv can cause those problems as seen on his video. Possibly due to either icv hose being disconnected but even then, the engine would not die quickly just sound terrible
  #67
Old 02-21-2013, 10:40 AM
it would be better and more useful if you could give the op a baseline by doing an icv unplug and an icv hose disconnect both plugged and unplugged, and posting your observations. Since your engine is working fine and is the same as his. I would help but mine is an m52
  #68
Old 02-21-2013, 11:10 AM
Monsignor's Avatar
M52 is just as close to his as mine is, so how about you go tear into your running car? Mine is a VANOS and his isnt.
Also my car is not running now, thanks though. Its not registered or insured and I have not installed my battery.
OP's "new" ICV could without a doubt be faulty and please oh please tell me how an IDLE CONTROL VALVE wouldn't be suspect in a terrible idle? Also, hose is not disconnected a smoke test confirmed, please read entire thread before posting, simple TOU...
2006 325i/6 48k mi
Garden State Euros
  #69
Old 02-22-2013, 07:17 AM
Mein Auto: 91 525i
An ICV would cause this issue, as many on this thread have said. I got busy yesterday and couldn't work on the vehicle. I will get around to it today.
Now I will remove the ICV and clean it out, plus test resistance and test its function today and get back to you later today
1991 BMW 525iA
  #70
Old 02-22-2013, 07:18 AM
Mein Auto: 91 525i
Mamij, read the forum before you post, like all the others do.
1991 BMW 525iA
  #71
Old 02-22-2013, 10:07 AM
Monsignor's Avatar
So we delete my post but let that ^ stay? Super cool...
OP please update on ICV
2006 325i/6 48k mi
Garden State Euros
  #72
Old 02-22-2013, 01:44 PM
_Ethrty-Andy_'s Avatar
E34 Converted E30 Fanatic
This thread keeps needing mod attention.
Locked
Closed Thread
