Go Back   Bimmerfest - BMW Forums > BMW Model Discussions > M5 & M6 > F10 M5 (2012 - 2016)
The 5th generation M5 has the V8 S63 TU engine with twin turbos under the hood producing 550hp. The engine and DCT gear box pusses the M5 0-60 in just 4.2 seconds.
Old 01-31-2013, 05:49 AM
BLACK MARKT BLACK MARKT is offline
#PML CERTIFIED
Mein Auto: ALPINE WHITE BMW F10 M5
ECU TUNiNG ... WHAT ARE YOU AFRAID OF?
I've become a little bored of my M5 so now I'm looking to increase the HP!!
I'm already running the MEISTERSCHAFT GTC + LXR PIPE which I'm extremely happy with ...
So I'm thinking about doing a stage 1 ECU tune with the factory DP's ...
However I've been going back and forth whether I should do the ECU tune or not but honestly I'm afraid of the following :
1. Can my dealer detect it the tune?
2. How reliable is the ECU tune?
3. Will there be a engine light?
4. In California we run 91 octane - will that be a problem?
5. Will I really FEEL a substantial difference?
6. What's the actual power increase?
Old 01-31-2013, 06:46 AM
milkyway's Avatar
milkyway milkyway is offline
Mein Auto: F10 M5
Hello!
Greetings from Germany. I drive at the moment a F10 550i with a ECU tuning from Noelle Motorsports. For your information, Noelle was the former motor specialist from Alpina. To delete the speed limiter and for 495 hp and 690 nM the DME und CAS moduleshad to be changed. (Vmax now 305 km/h = ca. 190 mph).
End of February I'll get my new M5. On the EMS (Essener Motorshow, a Motorsports fair in Germany) I'd contacts with the tuning companys. 640 hp are at the moment the way to increase the power and to avoid problems with tempratures a.s.o.
1.) Due to this every dealer can detect the tune
2.) I'd no problems with the tuning. But my dealer made a software upgrade and I'd to recode the modules (a service free of charge from Noelle)
3.) No engine light or somehting else
4.) You need 98 octane to feel the power. 91 octan is not high enough (minimum is 95 octan)
5.) I can only speek about the 550i. You have a new car after the tuning. 80 hp more in a M5 is not quantum leap but perceptible
6.) As I wrote above, 640 hp is the best solution - step 1. The maximum her ein Germany is at the moment 740 hp for an ECU tuning
You need DP for that. The DME coding is not breakable with an ECU tuning. You have to change the DME and CAS modules. Not only one tuner in Germany is able to switch of the speed limiter with a software tuning. Only with the DP your VMax will be appr. 310 km/h (so only 5 km/h more without tuning). More is not allowed in Germany due to the speed index of the tires.
Hope it was helpful.
CU Oliver
P.S.: Sorry, but I speak a famous accent without the slightest english :-)
Old 01-31-2013, 11:35 AM
#PML CERTIFIED
Danke for the information!!
Originally Posted by milkyway View Post
Hello!
CU Oliver
ecu flash, ecu tune, ecu tuning, meisterschaft
