Pedal Differences: Factory vs OEM Stainless Steel - Bimmerfest - BMW Forums
Old 01-26-2013, 03:21 PM
Sean's Avatar
Sean Sean is offline
Mein Auto: '01 Z3
Factory vs Stainless Steel (from the M Performace Pkg - Kit p/n = 35 00 0 410 100). Factory = Week 49 2013
The factory pedal is a newer design and in my opinion is superior in build, design, pedal travel, and kick down (passing gear).
Pic 1. Stainless M Performance Pkg accelerator vs Factory accelerator
Pic 2. Stainless M Performance Pkg accelerator vs Factory accelerator
Pic 3. Backside of Factory accelerator (metal connects with passing gear button, flexes upon contact)
Pic 4. Factory accelerator passing gear button (kick down)
Pic 5. Factory accelerator p/n & production date
pic 6. Stainless M Performance accelerator extended further (length) & rod connecting the pedal to main assembly (newer, factory accelerator has neither)
Name:	X5 50i Pedal.1.png
ID:	359265   Click image for larger version
Name:	X5 50i Pedal.2.png
ID:	359266   Click image for larger version
Name:	X5 50i Pedal.3.png
ID:	359267   Click image for larger version
Name:	X5 50i Pedal.4.png
ID:	359268   Click image for larger version
Name:	X5 50i Pedal.5.png
Name:	X5 50i Pedal.6.png
Old 01-26-2013, 03:22 PM
Sean's Avatar
Mein Auto: '01 Z3
More photos...
Pic 1. Stainless M Performance Pkg accelerator p/n & production date
Pic 2. Side profile of Stainless M Performance accelerator
Pic 3. Backside of Stainless M Performance Pkg accelerator vs Factory accelerator
Pic 4. Install complete
Name:	X5 50i Pedal.7.png
ID:	359272   Click image for larger version
Name:	X5 50i Pedal.8.png
ID:	359273   Click image for larger version
Name:	X5 50i Pedal.9.jpg
ID:	359274   Click image for larger version
Name:	X5 50i Pedal.10.png
Old 01-26-2013, 04:15 PM
5seriesHB's Avatar
5seriesHB 5seriesHB is offline
2 Bimmers R better than 1
Mein Auto: 12 MSPT 535 & MSPT X5 5.0
Wink
Great write up big Sean
It will all work out in the end....and if it hasn't worked out yet, its not the end!
2012 Msport X5 +Prem Sound+Cold Weather+Top/Side Cameras+Soft Close Doors+BMW Apps
Old 01-26-2013, 04:29 PM
Sean's Avatar
Mein Auto: '01 Z3
After install test drive to make certain the stainless accelerator was fully functional.
Old 01-26-2013, 05:01 PM
5seriesHB's Avatar
Smile
Looking dope my man!
great color combo
Next up permormance black grilles
Easy mod
http://www.bimmerfest.com/forums/sho...516&highlight=
Old 01-28-2013, 01:09 PM
v_x35d v_x35d is offline
Mein Auto: 2012 X5 xDrive35d
Looks great. I have done Black kidney upgrade already. looks like pedals and foot rest is next on the list. will this upgrade work for October 2012 production X5 xDrive35d?
Old 01-28-2013, 01:20 PM
5seriesHB's Avatar
Smile
Yes Siri bob
Go for it!
Post pics when done!
Cheers
Ps I tried to push Sean into doing the black grills
He won't do it even if I pay for them
Oh well
Cheers Sean ...lol
Old 01-28-2013, 07:14 PM
Sean's Avatar
Mein Auto: '01 Z3
I highly recommend www.getbmwparts.com Formerly Tischer BMW, now BMW of Silver Spring.
Direct link: http://www.getbmwparts.com/partlocat...catalogid=4462 ($120 + s/h)
FYI, the photo in the direct link is incorrect, but the part # is correct (35000410100).
PS I tried to push Sean into doing the black grills, he won't do it even if I pay for them. Oh well.
Cheers Sean ...lol
Old 01-29-2013, 05:59 AM
Thanks for the link. will be ordering soon.
Old 01-29-2013, 02:10 PM
Sean's Avatar
Mein Auto: '01 Z3
I installed another set (a la, 335is). The clutch & brake went on a lot easier than the X5 brake pedal. The accelerator was a breeze the second time as well.
ID:	359755   Click image for larger version
Old 01-29-2013, 04:07 PM
ard ard is online now
Resident Curmudgeon
What a silly "performance" upgrade...
Did you dyno this?
And you all know that the 'kickdown' is one of the worst ways to abuse your transmission, right?
Old 01-29-2013, 04:16 PM
Sean's Avatar
Mein Auto: '01 Z3
Did you dyno this?
Added at least 5hp for $120
As far as the 'kickdown' goes, in my opinion, no need to use it if you have the V8. We used it frequently in the former 3.0si X5.
Old 01-30-2013, 09:51 PM
sagood sagood is offline
Mein Auto: 2013 X5 35i SportActivity
I did not get the M performance package but I have the M sport pkg. I ordered the stainless steel pedals from the parts dept and tried to have my service advisor put them on but he said it was a different connector and the pedal was too big. They said they will look into it. Does anyone have any advice?
Old 01-31-2013, 01:43 AM
5seriesHB's Avatar
Lightbulb
it should be the same exact fit....SA wouldn't exactly be the authority on this!
These are the exact instructions i followed..worked well
12 and 13's r the same
give it a try
http://www.1addicts.com/forums/showthread.php?t=209687
Old 01-31-2013, 06:57 AM
Sean's Avatar
Mein Auto: '01 Z3
I researched this after the install. Apparently the accelerator was changed sometime during the 2009 model year. It is believed it was done as a cost cutting measure. The older design will mount as the mounting bracket on the floorboard & wiring harness connector have not changed. As far as operation, it is the same with exception to how the kick down (passing gear) performs (pictures above explain).
Save yourself some money and install it yourself. Follow the link 5SeriesHB posted above.
Old 02-11-2013, 09:11 AM
Got the pedals from getBMWparts.com and installed last weekend. Instructions were great. Getting accelerator pedal unplugged and changing break pedal were challenging. See pictures below.
ID:	361806   Click image for larger version
Old 02-11-2013, 09:12 AM
Now I need to get footrest upgraded. Suggestions?
Old 02-11-2013, 11:35 AM
Sean's Avatar
Mein Auto: '01 Z3
Missing the cap that covers the torx.
It is doable, but you have to literally break the factory one off & from what I have read the M footrest does not fit properly after breaking the factory part free. I would prefer to install the M footrest in the E90, our E70 has it from factory, but it is not worth it if it is not going to fit properly.
Old 02-11-2013, 12:06 PM
Awesome eye sight. Cap was replaced after the picture was taken :-)
