#76
2002 M54 engine Sucking Jet Pump
Note: The 2002 525i Realoem diagram for the F connector hoses is wrong:
Engine => Vacuum control => Vacuum control - engine The large hose coming out of the F connector connects to the metal pipe of the sucking jet pump: Here is a closeup of that sucking jet pump (with the large hose disconnected): Notice right behind it is a port with a vacuum endcap that can degrade causing vacuum leaks: Here is a picture of that vacuum port with the endcap removed. My theory is that this vacuum port 'was' used to connect to the CCV vacuum port when the CCV had a vacuum port that wasn't likewise plugged; but that's just a guess. |
#77
![]() Touring the nation, one state at a time |
#78
Fuel tank breather valve, aka EVAP purge valve ...
From this thread today:
- E39 (1997 - 2003) > EVAP Purge Valve Flow Quote:
Here is a description by JimLev: Quote:
- Might we be able to list, with pics (realoem diagrams ok) of ALL E39 vacuum lines?
Note: I'm having trouble finding an E39 charcoal canister photo, in situ. Do you have one handy? Last edited by bluebee; 11-26-2011 at 10:01 AM. Reason: Added request for charcoal canister photo. |
#79
Thanks to added value by Bomb5 today in this thread:
- M54 vacuum tubing ... what diameter ... what brand ... what material ... what length? ... we, for the first time (that I know of), have an in-situ picture of the three M54 engine vacuum endcaps that are listed in the parts list but (frustratingly) are not shown in the diagrams! Quote:
EDIT: Steve530 added additional pictures showing the SAP electrical valve taking one of the hoses that appear to be capped above: Last edited by bluebee; 11-27-2011 at 07:51 AM. Reason: Added additional pictures showing endcap locations on the M54 engine |
#80
I came here looking for a picture of the brake master cylinder under the driver side cabin air filter housing for this thread today:
- E39 (1997 - 2003) > Help with brakes and brake fluid. Quote:
- One user's example of a complete brake job with all torque figures, specs, measurements, fluids, decisions, tools, tricks, mistakes, suppliers, costs, etc., that it entails (1) |
#81
For the cross-linked record, pictures of all the parts in the engine bay would help people like this 98 528i poster today:
- E39 (1997 - 2003) > Idle Control Valve (ICV) location?? Quote:
For the record, while researching how the secondary air system (SAS) works in this thread:
- E39 (1997 - 2003) > 2001 530i question... ... I ran across this nice cn90 picture of the reclusive air valve in the back of the 528i engine over here: - E39 (1997 - 2003) > 3d Secondary Air Pump failure in 4 years! Quote:
#83
To help identify some of the more hidden components of the M54 engine, Steve530, over here today, found an excellent picture of the back of the M54 engine:
- For all to benefit, WHERE are the ends of these hoses in our beloved E39s anyway? Quote:
#84
Here is more detailed information just now from Steve530 on various hard-to-see engine parts on the back of the M54 intake manifold:
Today I cleaned out the dipstick guide tube which was wholly clogged with crud.
Since I had it open, here are more pictures of things inside the M54 engine bay that might not have been discussed prior in this pictorial identification thread. I'm not sure what the purpose of this blue twist plug is? This is the CCV lower drain hose which connects to the oil dipstick guide tube: Here is the idle control valve (ICV): Here is one of the suction jet pumps (the only one in the engine bay): Here is the vacuum port endcap where you send smoke machine signals through: Here's the rigid spacer between the MAF rubber boot and the ICV rubber boot: I 'think' this is the starter motor: And, I 'think' this is the wiper motor:
#86
The blue twist plug is a cover plug that is removed to insert the flywheel lock to lock the engine at TDC when setting the VANOS timing.
#87
As for the prior pictures above, I think I previously mislabeled the picture reproduced below: Looking it up, I find the large opening is actually the "throttle body" (TB, PN 13547502444) ... While the smaller opening is the wholly separate T-shaped idle control valve (ICV, PN 13411744713) ... What confuses me is that these must both be closely associated, yet, in the realoem diagrams, they're not even close in system classification.
Note: I unknowingly manually moved the throttle body plate to clean it (with the engine off) - but - apparently I should NOT have done so based on this thread. Quote:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 06-19-2012 at 10:41 PM. |
#88
This is not really a picture inside the engine bay, but ...
Circled is the CKP (crankshaft position sensor) ... not to be confused with the CPS (camshaft position sensor) ... from JimLev's post in this thread just now: -> E39 (1997 - 2003) > Crankshaft position sensor location
#89
JimLev kindly autopsied a power steering hose at the midline clamp to show the restrictor inside:
> E39 (1997 - 2003) > ps hose "What is this clamp in the middle of my power steering pump hose?" Quote:
#90
-> E39 (1997 - 2003) > Check engine soon -code p0443
#91
-> E39 (1997 - 2003) > Help identify blue plug-like cap off Engine or Tranny? Quote:
#92
The following I6 & V8 E39 engine photos are of exceptionally clean engine bays:
- > E39 (1997 - 2003) > How clean is it under the hood? I repost here to help newbies identify engine-bay components more easily.
#93
Post #78 of this thread came in handy today to help this newbie today identify the purge valve:
#94
Knock sensor from this thread:
> E39 (1997 - 2003) > kNOCK SENSOR 1
#95
There is a good discussion today of the two engine lift points for the M54 engine.
Unfortunately, I don't think we have a picture yet, in this thread anyway, of the rear lift point: > E46 (1999 - 2006) > Engine Removal Lift Points Quote:
- Lifting engine without special bracket and trasmission angle? What we need is a photo of the rear hook:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 12-16-2012 at 03:14 PM. |
#96
Technically this picture doesn't belong in this thread because it's a part of the M54 engine you can't see - but here's what a hydrolocked M54 looks like (5 bent rods!) from this thread:
And, here are some more pictures of the bottom end of the M54 engine from that thread:
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-05-2013 at 10:20 AM. Reason: Added pictures |
#97
I'm confused about the location of the crankshaft position sensor ckp in the V8 versus the I6 but I'll report what I see in the threads.
In post 88 above, we have a photo of the V8 CKP location. In this thread below, we have a photo of the I6 CKP location (M52B25): - > E39 (1997 - 2003) > Missing CRANK position sensor!?
Note: Your mission, should you decide to accept it, is to add value to those threads, either by pictures or by descriptions, so the next person with the same problem stands on your shoulders. See also: E39 Bestlinks & How to easily find what you need, in seconds! Last edited by bluebee; 01-11-2013 at 05:35 AM. Reason: Added recall information for the CKP in the M52 |
#98
A clarification of the CKP location for the M54 engine was made here today:
> E39 (1997 - 2003) > Missing CRANK position sensor!? See also: - Technique Tuning Stage "PEI330Ci" 330i Turbo Street Car - Bimmerboost M54 photos
#99
It doesn't look like the CPS (camshaft position sensor) is covered yet.
Here is a thread with some very nice M54 pictures: > E39 (1997 - 2003) > CAmshaft Position Sensor DIY And, this CPS R&R shows some nice pictures of the cam position sensor in situ: - > E39 (1997 - 2003) > BMW 528i 1998 Replace camshaft position sensor - DIY More intake CPS pictures here: And here: And here:
#100
Location of the Dual-Temperature Switch, DTS, from this set of threads:
- How to replace the M54 dual temperature sensor (DTS, aka double temperature switch) in the M54 (1) (2) (3) (4) & how to make your own short DTS removal tool out of a 22mm or 7/8" box wrench (1)
