Old 01-30-2013, 07:22 PM
kgorczyn kgorczyn is offline
Mein Auto: 2000 528i SP/PP
Must the aux/electric fan always run when AC is on?
2000 528iA
1.) Installed Dynavin D99
2.) AC Stopped engaging (compressor does not turn on)
3.) Removed D99 and updated firmware on ibus module of Dynavin
4.) AC still not engaging - HVAC module needs to be re-coded per Jeff (Dynavin)
5.) Connected to GT1 and somehow got it to write re-code the HVAC Module
6.) AC works fine now
Butttt the aux fan does not turn on. I ran a test from the DME module and it spun up fine, so I know it works fine, but it wont turn on when the AC is on. At what point should that fan turn on? Should I be worried that's it's not turning on when the compressor kicks on?
FWIW I had the AC on for 20 min idling - never spun up once - I was monitoring Oil/Coolant/Engine temps and they were right where they needed to be - So maybe that's why fan did not turn on?
Old 01-30-2013, 07:59 PM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
The aux fan on the early cars ran all the while the A/C was on. Later cars were smarter.
Old 01-30-2013, 08:02 PM
occhis occhis is offline
Mein Auto: 1998 528iA
Mine does not. 98 528
Either you are part of the solution, or you are part of the problem.
Old 01-31-2013, 06:04 AM
jygesq jygesq is offline
Mein Auto: 2000 528 MT
aux fan does turn on on my 2000 528
Originally Posted by kgorczyn View Post
2000 528iA
As soon as the A/C is turned on ans stays on while a/c is running, Same year /model as your car, Mine is MTranny ,but doubt that means anything different
Old 01-31-2013, 09:23 AM
Jim Rolando Jim Rolando is offline
Mein Auto: 1999 528i
Mine only comes on when the control module determines that it is needed not when the AC is turned on necessarily. Check the sensor in the bottom radiator hose. If mine is unplugged the fan runs all of the time regardless of the AC being on or not.
Old 01-31-2013, 09:34 AM
Awesome tip - I'll give it a shot - Thank you!
Old 01-31-2013, 09:55 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
M62TU/M52TU/M54 Aux Fan Info
The M52 & M62 aux fans' operated differently than the M52TU/M62TU/M54 aux fans. See the info below for the latter:
Q {BMW CCA Member #191509}
(SOLD)
Old 01-31-2013, 10:25 AM
What a lesson. Thank you gentlemen! Puts me at ease! Very valuable Info!
Old 02-06-2013, 06:41 PM
FLE39 FLE39 is offline
Mein Auto: 2003 530i 5spd Manual
Mine only comes on when I have the "MAX AC" button on. It works great. But normally I have the a/c in Auto, 72 or 73. So it doesn't work very hard unless it's summer.
DD: 2003 530i 5spd manual sport package. Conti DWS's, Llumar ATR, White LED lighting. TLC on-going.
Garage queen: '07 335i Sedan, base pkg, 6spd Manual, Procede 3 V5 w/NLS, staggered 18" 313's w/Conti DWS's, HKS Exhaust, OS Giken TCD LSD, VAC Street Diff Cover, Akebono Euro Pads, CDV Removed, Black BMW Grilles, Interior & Exterior white LED lighting, LUX Angel Eyes, Debadged, Llumar ATR Tint.
