Old 11-29-2011, 10:27 PM
Ultraman 68 Ultraman 68 is offline
Mein Auto: 5series
yellow check engine light
How worried shoold i be that my check enginesoon yellow light just came on?
Old 11-29-2011, 10:36 PM
- Where to point newbies who ask why their SES/CEL light is on or why they have a misfire or stumbling, hesitation, rough idle, etc., but who don't post codes with their question (1)
Old 11-30-2011, 06:47 AM
JimLev JimLev is offline
Mein Auto: 540/6, S60 Volvo, Tribeca
Probably time to park it on the side of the road and take the plates off.....j/k
Take it to one of the auto parts stores that does free code readings, get the Pxxxx code and post it here.
Make sure you tell us what year and engine you have.
Old 11-30-2011, 08:16 AM
QSilver7's Avatar
QSilver7 QSilver7 is offline
I see "Burbank"...hopefully it's not Burbank CA...if so...then the auto part stores don't read OBD II codes. California is one of the few states that don't allow places like AutoZone to scan for OBD II codes.
But I should have started with...if you have a warning light come on and you don't really understand what it means...the first place you should go is your owners manual for an explanation. If you don't have an owners manual...you can download one in PDF format directly to your CPU so that you can have 24/7 access to the information it contains (plus it's much easier to search) You can find manuals at the bottom of the left column at www.e38.org/e39 . If your model year is NOT listed...then download the manual that is CLOSEST to your model year...you won't miss a thing.
Q {BMW CCA Member #191509}
(SOLD)
Old 11-30-2011, 09:00 AM
What I'll do is add the helpful posts from this classic newbie question thread to the poolman thread designed t answer the question at the highest level.
That way, the next person who asks about his CEL w/o knowing how to test for codes, gets the same educated answers from those who helped above.
I'll continue to do that until/unless more specific information is posted by the OP as a result of that, into this thread.
At that point, this thread can take on it's own specific life depending on the results of the code scan.
Old 01-31-2013, 11:29 AM
bmwmanz2 bmwmanz2 is offline
Send a message via MSN to bmwmanz2 Send a message via Yahoo to bmwmanz2
Mein Auto: E39 528i
Mine is on and only has from my Peake scan tool the following: O2 adaption limit cyl 1-3 and O2 control limit cyl. 1-3. Any suggestions? ICV has been cleaned, MAF cleaned and tested, O2 sensors only have ~30k on them, new intake/throttle body boot, new spark plugs, etc.
-Tony
