Code 27
HAVE A 528i WENT INTO LIMP MODE HAS CODE 27 SERVOMOTOR ELECTRICALLY FAULTY. ANY HELP WOULD BE APPRECIATED AS WE HAVE LIMITED ACCESS TO BMW MANUALS
HELP! MY TYPEWRITER IS BROKEN! E. E. CUMMINGS
What model year is your car? 27 = Idle control valve closing coil Output digital pulse width (active low) DME final stage will set flag whenever a short to ground, a short to battery voltage or a disconnection between output transistor and component exists. I'm sure you can get a Bentley manual through Customs, n'est-ce pas?
Ed in San Jose '97 540i 6 speed aspensilber over aubergine leather. Build date 3/97. Golden Gate Chapter BMW CCA Nr 62319. |
it is a 1997 |
1997 528i thanks. I failed to mention that I am scanning through the 20 pin access. looking at the abs system which had a R.F speed sensor problem. but I am left with a code 27 servomotor electrically faulty. (reading now on scanner).
