Old 01-29-2013, 12:35 PM
Bennt771 Bennt771 is offline
Mein Auto: 540i
Question 2000 540i TPS? Is there one?
Some sites say yes, like Pelican and ebay. Others no, like Summit and World Pak.
So is there one ? If so where the heck is it ???
Old 01-29-2013, 01:08 PM
I didn't look at the thread, but typing /TPS F3 found this which might help:
- How to diagnose and replace the TPS throttle position sensor (1)
Old 01-29-2013, 04:31 PM
edjack edjack is online now
Mein Auto: '97 540i 6 speed
Your car has an electronic throttle control. There is a box on the accelerator pedal, and one on the throttle body. They work together, in concert with the DME, to control throttle position, based on the pedal position. The box mounted on the throttle body has an electric motor to control the throttle plate. Either module has been known to fail, and cannot be repaired, only replaced.
Why do you ask?
Read mylo's post, and go here: www.realoem.com
Old 01-29-2013, 05:08 PM
Mein Auto: 540i
Pedal has to be pushed a fair way to respond, also my idle it around 400, and the car has stalled a few times pulling into a driveway. Its an auto.
Noticed last night if my lights are on it goes up to 520ish. Car had a new battery.
Old 01-29-2013, 06:26 PM
Round Two Round Two is offline
Mein Auto: 2000 540i6
Sameo, sameo, more or less
Don't want to hijack this tread, but I have a 2000 540i and think maybe I have TPS issues. Have noted that you can't repair, just replace. My car at 74K miles, just recently have replaced plugs, O2 sensors (front), MAF and FSR (this made some difference). There is still kind of a disconnect between the pedal and the CAR. Even to the point sometimes of mild bucking. If you are really on it, meaning say 3/4 throttle, all is good. Would love to hear someone weigh in on this. I am pretty close to replacing the throttle body and see what gives. Thanks all for your input!
Old 01-29-2013, 10:59 PM
JasonSC540ia JasonSC540ia is offline
Mein Auto: 1999 740i
99-03 M62tu's have elec throttle body as edjack suggest. TSP sensor is inside. I believe there is 2 TSP sensors in it. Also as edjeck suggest you have to replace throttle body. Did one on my 540 about 2 years ago. I think it was $175ish for new one from EAC. Fixed symptoms you discribe.
Old 01-30-2013, 04:51 AM
Mein Auto: 540i
Eac?
Old 01-30-2013, 08:30 AM
Mein Auto: 540i
Originally Posted by jasonsc540ia View Post
99-03 m62tu's have elec throttle body as edjack suggest. Tsp sensor is inside. I believe there is 2 tsp sensors in it. Also as edjeck suggest you have to replace throttle body. Did one on my 540 about 2 years ago. I think it was $175ish for new one from eac. Fixed symptoms you discribe.
eac ?
Old 01-30-2013, 09:50 AM
Google is your friend, and will find EAC for you.
Old 01-30-2013, 04:40 PM
Topaz540i's Avatar
Topaz540i Topaz540i is offline
Agnostic Priest
Mein Auto: 2001 540i/6
Eactuning.com
The electronic drive by wire throttle body has plastic gears in the servo box on the side which wear out on occaison.
Remove the intake elbow and check to see if there is slop in the throttle body plate. I believe it was Justin that replaced his recently and noted better throttle response and smoother idle.
ESS Tuning m60 version software
m60 intake manifold
a.f.e. c.a.i.
3" obx catback
full powerflex urethane setup
545 ssk
cdv delete
m5 rear sway bar
M5 chassis rods
M5 3.15 lsd
Bc-r coilovers w/ swift springs
Akebono=suck
ss braided brake lines
coming soon:
Jb lwfw
Old 01-31-2013, 08:46 AM
Mein Auto: 540i
If the cam shaft position sensor goes, does it always throw a code ??
Old 01-31-2013, 04:34 PM
If it fails, yes.
Old 02-03-2013, 12:16 PM
Mein Auto: 540i
Originally Posted by Topaz540i View Post
Eactuning.com
What kind of play? Mine seems to move like its connected to a spring then like its hitting gears (more resistance)... Is this normal?
Travel seems to be a 1/8th of an inch before the resistance of the "gear" is felt.
So... what is normal ?
If i get a new one is there sopme new programing i have to do ?
