E46 (1999 - 2006)
Old 01-30-2013, 10:54 PM
adamsarnovsky adamsarnovsky is offline
Mein Auto: 2000 BMW 328i
328i condensation issues
My 2000 328i is fogging up every night that it rains. My floor mats are slightly damp on the drivers side, but I checked for leaks and it doesn't look as if there can be an issue anywhere. What else would cause this? aircon?
Old 01-30-2013, 11:10 PM
heztheone heztheone is offline
Mein Auto: ///M
this kind of leak will not show visually, check if the draining holes are clogged.
Give a man a fish and you feed him for a day. Give a man a Chef and he feeds him for a lifetime
Old 01-31-2013, 10:58 AM
Where are the draining holes located?
Old 01-31-2013, 07:09 PM
SJBimmer's Avatar
SJBimmer SJBimmer is offline
Living Life At The Beach
Bottom of door. You may also have a failed door seal. Door panel has to come off to see. Anyone do any work inside the door before this problem showed up? Could also be A/C drain plugged up. Do you see water dripping under the passenger side of the car?
Old 02-01-2013, 02:57 AM
I don't see any water at all dripping period. I feel like it's an AC issue. There are no visible leaks anywhere and there's condensation on the windows every time it's cold out. It's to the point that I have ice inside of the windshield that I have to dry off with a towel. The car is perfect other than this issue. How do I go about checking to see if the AC drain tube is clogged? Because that's my gut feeling as to what it is since the water is spread out throughout the car. there are no spots of water, just light condensation on floormats and a high amount of condensation on the windows.
Old 02-01-2013, 09:28 AM
SJBimmer's Avatar
http://www.bimmerfest.com/forums/sho...d.php?t=446447
