The latest X3 brings some added style and some new features to the BMW SUV family. Talk about the new F25 now!
Old 02-01-2013, 05:21 AM
neelkc12 neelkc12 is offline
Mein Auto: X3
Lightbulb E83 wheels on F25 did not fit
Picked up E83 wheels and winter tires from salvage yard ( nice and gorgeous tire rack sports edition wheels) hoping they would for on my 2011 F25. Many threads on this forum suggest that they should fit . I also got new bolts ( M14x1.25) from tirerack . Alas they did not fit. - Calipers were too tight ( absolutely no clearance) and the wheel did not move at all. What am I missing ? Thought about wheel spacers and asked a local BMW indy about probable size of wheel spacers. He could not help either.
Technical details :
Basic wheel specifications for the X3(F25) chassis are:
Bolt Circle = 5 X 120mm
Offset = 45mm (43 to 47mm acceptable)
Hub centering Bore = 72.5 mm (hub ring dia. = 72.47mm)
Bolts = M14X1.25 Spherical seat, 17 mm heads (Note the X3(E83) uses M14X1.5 bolts)
Minimum bolt engagement = 9.5 turns
For E83 all same except the bolt sizes
Bolt Pattern: 5x120 | Center Bore: 72.56 | Hardware:12x1.50 Bolt | Offset: 34-45mm
Also, I could see the wheel after mounting it that it not flush against the hub , where as my OEM wheels are!.
Thoughts , before I put wheel and tires on craigslist.
