Old 02-26-2010, 10:26 PM
jux_me jux_me is offline
Mein Auto: 1998 BMW 540i
Exclamation Squealing noise while driving.
I look around the forums and trying to find what the problem is but to no avail. Anyways, I have a 98 BMW 540i which I bought last November and been pouring money into it (mechanical work). It's driving good now but need a little more fix to it (O2 sensor replacement ... don't know which one). Just got front brake pads and front brake rotors fix last week (cost about $651) which I thought was the cause of the squealing/squeaking/tea kettle whistle sound. Nope, it wasn't. The sound still happen when I'm driving at about 25mph and up. It start to stop when I hit the brakes. I took it back to the place where I got the brakes fixed and took the mech guy for a drive and he can't determine the problem also. Thought it could be the back bearing but I notice the sound was coming toward the middle front of the car where the air vent is (the engine part maybe?). I try shutting/closing the front vent but still I can hear the sound. I don't know where or what is making the noise but its annoying when I'm driving and hearing that sound. It's doesn't happen all the time. Sometimes it happen when I hit a pothole or when I'm making a right curve exit from the freeway. Like I said, it happen when I'm driving 25mph and up.
Anyone have any ideas on what it can be. I might have to take it to the dealer and have them check it out to see if they can determine the problem.
Old 02-26-2010, 11:40 PM
scott0357 scott0357 is offline
Mein Auto: 2003 530i
Not sure if you're talking about the noise from the AC/heater blower fan. If you turn off the fan completely, do you still hear the noise?
Old 02-27-2010, 09:15 AM
edjack edjack is offline
Mein Auto: '97 540i 6 speed
My guess is that one or more of the brake pads is in slight contact with the rotor. That's why the noise goes away when you press the brake pedal.
The pads and calipers must be lubed with anit-seize compound on their sliding contact points with the caliper.
Was the mechanic a BMW specialist?
Old 02-27-2010, 10:23 AM
Waveho Waveho is offline
Mein Auto: '07 335xi 6MT 4door
Hard to pinpoint from your description. Since this happens only while driving, at certain speeds, and is exacerbated by certain wheel turns at speed, I would look to your wheel bearings.
'07 335xi 6-spd 4dr, Montego blue
'98 540i 6-spd Sport, Jet Black II(sold)
'92 325i 5-spd 4dr, burgundy(sold)
Old 02-27-2010, 01:33 PM
Yes, I turn the fan off completely and still hear the noise.
Yea, they specialize in European car (BMW, Mercedez, Audi, Volvo etc.) I might ask the mech guy to lubed the pads and caliper when I take it in on Monday again.
It doesn't happen all the time but it does happen and its annoying. Wheel bearing is what the mech guy gonna look at on Monday. But than, it could be anything.
Forgot to mention, the mech guy ask me to (when I'm driving and I hear the sound) put the car in Neutral to see if the sound still there. Yes, it still sound when I put the car in Neutral while driving. I don't know if that suppose to help trying to figure out the problem.
Old 02-28-2010, 01:31 AM
rashid rashid is offline
Mein Auto: X5 E70, 4.8 - 2010 White
Is it kind of whispering?
Old 02-28-2010, 04:24 AM
helpmyfive helpmyfive is offline
Mein Auto: 528i
does it change pitch when the engine is revved up? does it change pitch when you speed up? Most likely this isn't your problem, but my rear e brake drum shoes came loose and the retaining spring dropped into contact with the shoe/drum. It squealed and clicked like crazy. I've also heard of people 'bedding in' the pads by driving to high speed and holding the brakes until they fade. Seems like a great way to use up miles of pads and warp your rotors, but it might fix the squeak.
Old 02-28-2010, 11:20 AM
I would say a little but some times it can get loud as a Tea Kettle whistle. I can hear it when I open the window also. One day, the sound seem to be coming from the right rear side. The next, it seem to be coming from the front middle or right rear. Haven't determine what or where its coming from yet.
I haven't notice a change in pitch but the longer I drive, the louder it gets. Like, when it start it will be soft but get louder and louder. Doesn't really depend on the speed but how long I been driving after I hear the sound. Sometimes, it goes away when I hit a bump or pothole but seem to come back when I hit it again.
Hopefully, someone can help me determine the problem; that way the mech guy know what to tackle. I want to get it fix before I go trade it in for a 740 or 750 .
Old 04-10-2010, 06:47 AM
tmcj123 tmcj123 is offline
Mein Auto: bmw x3
noise
I am having the same problem. i have a 2004 x3. I hope someone can help us. Mine comes after driving a while and seems to be in the front left part of the car.
Old 04-12-2010, 07:31 PM
ecool ecool is offline
Mein Auto: 92 325i, 00 528i
Might be a hole in the intake boot.
Old 04-12-2010, 08:04 PM
GSXRYDER GSXRYDER is offline
Mein Auto: Z4M Coupe, 540i,Silverado
Posts like this
Drive me nuts...why don't you just 'throw' more money at it till it goes away! Your mechanic, should have told you upfront that is not your problem... the whistling could be caused by, bad belts, missing jack pad, bad fan pulley...etc...so get a real description....and get it to a real mechanic or a real repair shop and have them take a look at it. These are cars, not space shuttles!
99 540i-6 Sport & 07 Z4///M Coupe
Pure
Adrenalin!
Old 06-16-2010, 06:54 PM
cdawg246's Avatar
cdawg246 cdawg246 is offline
Mein Auto: 1999 540i m-sport
funny u posted this squealing noise im chasing down the exact same problem on my 540i--did u ever figure it out what causes that annoying noise? mine is in the front passenger wheel well
Old 02-06-2011, 07:01 AM
lordviking lordviking is offline
Mein Auto: 2003 540i M-Sport
Having same irritating noise, but it starts when i apply the brake. Gets really noisy after long trip, but then goes away.
Old 02-01-2013, 06:03 AM
riverarb riverarb is offline
Mein Auto: 540i Sport
540I Squealing noise
Hey everyone, I have a 2000 540i and have also experienced this "tea Kettle" whistling noise coming from the center console...so I used the ole common sense approach. I had my son pin point the noise origin while I was driving (Rear Vent, center console). Sooo put 2 & 2 together, sound coming from a vent…is there a fan in there? I looked it up on realoem (http://realoem.com/bmw/) under “heating and air conditioning” you’ll see that some models came with a rear blower (fan) and regulator…as you speed up or down the regulator adjust the fan speed. I haven’t taken mine out yet, but I bet you a beer that the blower is the culprit to our mysterious squealing noise! Spray some WD40 on that Bi!@# ....lol I’m going to take mine out this weekend…
Old 04-15-2014, 09:49 AM
snomar5 snomar5 is offline
Mein Auto: 1998 540i
Did you ever figure out the teakettle whistling noise? Was it from the blower? Was it rear bearings? Having the same exact issue described.
Old 03-29-2017, 04:32 PM
Joe422 Joe422 is offline
Mein Auto: Z3
reviving old thread... but has anyone ever figured this out?
My E39 M5 has a soft high pitch sound, almost like a warble... definitely seems rotation based.
-Sound is most noticeable around 20-25mph.. then when rolling faster, it almost disappears, (or just get higher pitched)
-Not engine speed dependent
-Not transmission (gear/clutch) dependent.
Cant pinpoint where the sound is coming from... sometimes seems rear... sometimes seems middle of car...
Maybe center driveshaft bearing?
Anyone?
Thanks~
Old 03-29-2017, 05:10 PM
mattmar1's Avatar
mattmar1 mattmar1 is offline
Wingnut
Mein Auto: 1999 5281 5 sp msport
so that tells you that its wheel speed dependent, or something hard connected to the wheels...wheel bearings, brakes,axles, diff, driveshaft etc. id start by lifting it up and looking around and checking everything for anything that doesnt feel right.
99 528i 5sp sport
be alert...the world needs more lerts
Old 03-30-2017, 12:34 AM
Chedley Chedley is offline
Mein Auto: 2001 E39 540i
For what it is worth: I had a similar sporadic "tea kettle" whistling noise on my car last summer.
I did a brake fluid flush (bleed and refill the brakes fluid), and changed the rear differential fluid. The fluids were real dirty and needed a change anyway.
But incidentally, that fixed the problem. No more squealing noise.
Old 03-30-2017, 07:51 AM
On my car (see post 15) it ended up being the center support bearing on the drive shaft. Rubber had rotted giving lots of play. At certain speeds there would be vibration through metal of bearing to underside of body causing the whistling noise.
Biggest drag was dropping exhaust to get at driveshaft.
Might be worth checking your guibo while you are there. It is a big thick rubber piece that bolts to front of driveshaft. Be careful with aftermarkets guibos though. I replaced mine since I was in there. The rubber ripped within a year. I had saved the original and put it back in since it did not have cracks or tears and all was good. So...may want to check the original but dont replace unless definitely need to. Also, if you remove it be sure to put it back in as it is supposed to. Take a pic before removing. There are some threads about the right way the bolts need to face, how it lines up, etc.
Search for forum threads on center support bearing. Follow advice on marking undersude of body at bearing bracket before removal and slightly front loading it before install (if wheels are in the air).
Old 03-30-2017, 08:08 AM
mattmar1's Avatar
Wingnut
check for the presence of the jack pads underneath as well..a missing one can cause a whistling sound while moving
99 528i 5sp sport
