Old 01-30-2013, 01:44 PM
neeeeo neeeeo is offline
Mein Auto: E46 - 318i N42
Tell you what it can be:
Vanos is driving by oil passing selenoids. Once selenoid is switched, oil is passing other direction in Vanos.
Default position of vanos on cam shaft is mechanicaly locked inside. Vanos is driven to this position by coil spring (and oil) and other direction by oil.
So now, if there is something blocked inside vanos (or maibe thick oil...) vanos can be sticked or not locked when back in default position...
I had 1 Vanos off shaft and try to open it. But didn't have hammer screw driver. Its torx bit. Its too tight (or glued)
I know that by driving vanos, the engine can get some exhausts gases back for combusiton. Can it be the lost of compression?
Old 01-30-2013, 02:01 PM
JakuLuka JakuLuka is offline
Mein Auto: E46 316ti
Darn... not sure if you can open at all vanos adjustment units from n42... And ofcourse they are expensive -.-
Old 01-30-2013, 02:25 PM
Hey, i just remembed that i found this :
http://www.bimmerforums.co.uk/forum/...rried-t122549/
from my car too. just wondering if piece or couple found their way to vanos units...
My car had some issues with cylinder head past year and i think they didn't clean it well when they fixed it..
Old 01-30-2013, 03:38 PM
No, all plastic bits should stop at oil filter. Those there was found in oil cooler, so its on a way to oil filter.
BUT in a moment, when presure valve open, because the filter is blocked, some things can pass throught.
Definitely vanos will be a good place for them to stay in.
Vanos can be open. They are not any special. But the screws are tight. Without hammer screwdriver it can not be open. (Then also new screws are in need)
Old 01-31-2013, 12:51 PM
Okay. Now im close it is vanos problem.. just dont know wich part is broken. I just changed cross solenoid valves and it started to work. But.... i left accidentally lower valve about 1-2mm out. You dont see it if you dont look really close but it is not in its place. Now motor doesn't even sound funny... little loss on power thou. It's just... Vanos parts are so expensive... should narrow down the broken part before start to change them -.- .. i don't know how to narrow them. Any ideas?
Old 02-01-2013, 12:26 PM
Want to see whats inside?
Google for this file:
mfp-brk-n42-de.pdf
Its in german, but its very helpfull.
Old 02-01-2013, 12:31 PM
Thank you so much! have tried to find something like that about 3 days straight!
Old 02-01-2013, 01:00 PM
No problem mate. Just, if you decides to open the vanos, do some photos and share them. I like to see, how is the look on inside in real, after few thousand km...
I am also interesting in wear of the parts inside.
Old 02-04-2013, 12:49 PM
Any thing new about your problem?
Old 02-04-2013, 01:25 PM
Waiting for new solenoid valves and new vanos adjustment units and timing tools... i will open vanos units, if i can, just to see how they look , when i get new units. Will inform more when i get forward.
Old 02-14-2013, 01:06 PM
Did you get in touch with new components?
Old 02-15-2013, 03:29 AM
Actually got them yesterday but our garage is full now... I should be able to try them this weekend.
Old 02-15-2013, 10:35 AM
Good luck. Hope it will fix the problem forever.
Old 03-03-2013, 11:07 AM
Did you replaced the parts?
Old 03-03-2013, 11:58 AM
A4driver A4driver is offline
I'm following this thread, with all the same symptoms as described here. Have been giving up finding the issue on my n42.
Here in Norway its always cold, so I do this to being able to start cold engine:
Disconnect valvetronic motor
Start the engine
Reconnect valvetronic.
Then after engine is warm, I restart and valvetronic is working juddery, but drivable
(if this is not done, it stalls when valvetronic is supposed to take over for throttle operation after cold start)
Old 03-03-2013, 12:12 PM
Yep.. timings now right and parts have been replaced.. guess what. issue still here.. F*ck... Double checked timing and losing my mind now -.-
Old 03-03-2013, 12:36 PM
Can anyone tell me how hard the eccentric shaft is supposed to turn when valvetronic motor is off? Mine is so hard, that i need to use a spanner to turn it. The spring in the end off the shaft is not having any function than to decorate, so I have started to suspect that the shaft sits to hard. The spring don't push it to a kind of stop position when switching ignition off. In idle or while driving and gives throttle slow, there is no misfiring, but if I hit the floor, its several misfires and judders before it accelerate.
Old 03-03-2013, 12:41 PM
mine starts
But i think i can turn eccentric shaft up pretty easily.. haven't test how it turns on the other way..
Old 03-03-2013, 12:49 PM
Seems like the same problem I have. I'm also having the traction control lamp blinking as you do when the start problem is there. Cant understand why... When valvetronic is of, this lamp don't light up. When engine is warm, start up works just fine.
Old 03-03-2013, 01:05 PM
Oh F*ck... Haven't notice that before thanks for pointing that up.. But i wanted to ask you did you have something done to your motor before problem started?
Old 03-03-2013, 01:33 PM
It came sneaking over time. Just periodically in beginning. After last summer, the problem has been all the time.
Old 03-05-2013, 01:51 PM
Sounds like the shaft is sticked. My was moveable (not by hand), but the spring moved it from 3/4 of way to end (4/4) a keep it there.
The shaft is siting on needle bearings (4x no.13). If there are some bits inside bearing, the needles can be blocked.
I think the shaft can be removed without dismantling the cam shafs. (but not shure, because its some time ago I done it...)
Old 03-06-2013, 12:48 PM
Not sure if it means anything but i think my valvetronic gets the end points in different order than in this video :
Old 03-07-2013, 11:35 AM
What you mean different?
Make a video if you can.
Did you open the old vanos?
Old 03-07-2013, 03:00 PM
this is mine...
i didn't open vanos units yet coz don't really have time for that yet .. have to get bmw to everyday use first....
