Old 11-09-2010, 03:27 PM
z3-o1 z3-o1 is offline
Mein Auto: bmw z3 1997 1.9l Auto
Unhappy HELP PLEASE Reset Z3 oil service light
Just done a oil change
so need some advice on how to reset oil light inspection on dash
thanks all
Old 11-09-2010, 03:54 PM
its ok
ive done it , it was simple
Old 11-09-2010, 06:11 PM
rtsuggs rtsuggs is offline
Mein Auto: 02 z3 roady
How did you do it?
2002 Z3 2.5i
Old 11-10-2010, 01:04 AM
Originally Posted by rtsuggs View Post
How did you do it?
Simple
Turn the ignition switch to position two (2). Connect the clip end of the jumper tool to a good ground in the area of the data link connector. Connect the pin end of the jumper tool to pin seven (7) of the data link connector and remove it after the appropriate time, depending on which reset you are doing. Replace the data link connector cap and turn off the ignition switch. Check to see if the reset worked by starting the car and seeing if the lights go out. If they do, good job!"
10 secs should do it let me know how you get on
ID:	254013   Click image for larger version
Old 11-10-2010, 05:09 AM
What year model is yours? Mine is an 02 , Would it be the same?
2002 Z3 2.5i
Old 11-10-2010, 06:33 AM
mine is a 1997
all the same
Old 01-23-2013, 08:50 AM
Waldvogel45 Waldvogel45 is offline
Mein Auto: Z3
thanks again: this time the system had also blocked the starter, but your method sorted it in 10 seconds; 1996, 1.9.M44
Old 02-01-2013, 04:47 PM
DreamnZ DreamnZ is offline
Mein Auto: 2001 BMW 330ci VERT
Originally Posted by z3-o1 View Post
Simple
I'm a bit confused, and therefore have to start by apologizing.
What to you connect? A wire? What's a jumper tool? Is this like my jumper cable?
This is a really good trick and I would really like to know how it's done.
Thanks in advance for clarifying.
Old 02-02-2013, 11:41 AM
vintage42's Avatar
BMW CCA 1405
Originally Posted by DreamnZ View Post
... What to you connect? A wire? What's a jumper tool? Is this like my jumper cable?...
A jumper is any conductor used to connect two points. To reset the indicator the two points are terminal 7 in the data port and the grounding nut on the adjacent passenger strut tower about a foot away. The simplest jumper for this is a stiff wire, ideally 2 feet of 12 gauge house wire with the insulation stripped back 1/2 inch on each end.
Or you can buy a "tool":
http://www.ebay.com/itm/120830233463...84.m1497.l2649
The tool means you don't have to use the wire for the right two lengths of time. Like, if you want to rest just the oil, and use the wire too long, you will reset the whole service interval. The tool has a button for each (and evidently a time chip).
See more:
http://www.unofficialbmw.com/e36/ele...ce_lights.html
http://forums.bimmerforums.com/forum....php?t=1933465
Old 02-02-2013, 05:11 PM
Ron Stygar's Avatar
Ron Stygar Ron Stygar is offline
19,585 Miles
Mein Auto: Z4 M Coupe 6LL93033
Simple
That's my picture!
Old 06-06-2013, 12:10 PM
jafcorrea jafcorrea is offline
Mein Auto: 760i and Z3 1.9l
nt
Old 06-06-2013, 12:12 PM
my is 1997 Z3 1.9l .. guy in video connected 7&19?
19 is ground?
or do I connect 7 and ground to reset?
Thanks all for the good info.......
Correa
Old 06-06-2013, 01:12 PM
BStanton BStanton is offline
Mein Auto: 1998 BMW Z3
Has any body purchased this tool? Does it work?
For the price I just purchased it.
This is my toy. 1998 (2.8)
Old 06-06-2013, 02:28 PM
mbarnesz3 mbarnesz3 is offline
Mein Auto: 1998 z3
I bought a peake research r5 off ebay for $40. it works great and very simple. i just feel safer using the tool. just count the light flash. 7 flashes for oil and 23 for inspection. mine is 98 z3 1.9.
Old 06-06-2013, 03:54 PM
nfunk nfunk is offline
1998 BMW Z3 2.8L
Mein Auto: 1998 BMW Z3 2.8L
I bought one of those tools off EBAY and it works great! Can't go wrong for the price.
Old 06-06-2013, 04:30 PM
vintage42's Avatar
BMW CCA 1405
Originally Posted by BStanton View Post
Has any body purchased this tool? Does it work?...
I bought it on eBay a few months ago. I will use it for the first time after the first oil change I do, in another 200 miles.
Old 06-06-2013, 04:36 PM
vintage42's Avatar
BMW CCA 1405
I would be afraid of miscounting all those flashes. Then what might happen?
I feel safer with the $9 eBay tool. Just push the button once.
How to use:
Plug it in with the ignition off.
When the lights on the unit remain lit, turn the ignition on but do not start the engine
Press the button on the function you wish to reset.
The lights will all turn on to indicate success.
Old 06-06-2013, 08:16 PM
dougpaulburdic dougpaulburdic is offline
Mein Auto: 2000 z3/2.5
Thumbs up
Originally Posted by Ron Stygar View Post
Thanks! I had just changed my oil too. It reset just like you said! how many miles does each green block represent?
Old 06-07-2013, 05:11 AM
vintage42's Avatar
BMW CCA 1405
The green blocks represent usage, not miles. If you just drove back and forth across the country, a block might go out every week or 5,000 miles. If you drove around town all day doing errands, a mile between each store and an hour in each one, especially in cold weather, a block might go out every 3 months or 1,000 miles.
Old 06-07-2013, 05:20 AM
Good info
Think ill just change my oil based on milage though.
Old 06-07-2013, 07:01 AM
vintage42's Avatar
BMW CCA 1405
Me, too. I had the dealer change the oil when I bought the car last October, and they put in BMW 15W-40. After about 2,000 miles one green bar went out, but I don't want to wait until the last green bar goes out at 8,000 miles. I bought Mobil 1 0W-40 on sale at Walmart and will change at 2,500 miles, then maybe go 5,000 miles on the synthetic.
Old 07-11-2013, 01:50 PM
Vincestigator Vincestigator is offline
Mein Auto: 1997 Z3 2.8
Hey, just wanted to say thanks for this DIY info - it worked like a champ and I'm in the green :o)
Old 03-18-2016, 06:00 AM
Haschish's Avatar
Haschish Haschish is offline
Mein Auto: 1999 Z3 2.3 Roadster
19 is ground?
Mine (1999 Z3 2.3) is 7 to 19 for ~10 seconds- this resets oil and maintenance lights. I followed instructions in video.
